Go Back   MitsuStyle > Hosted Support Forums > Primo Performance
Old 03-06-2010   #41
mx3twinturbo
mx3twinturbo's Avatar
Drives: StarQuests>>>>>>
Re: Powder Coating Pricing
Normal powder coating processes will effectively make the metal more brittle because of the high temperature. The wheel will still be rigid, but it will not be able to withstand forces like it originally did. There are low temp powders that cure at around 375 degrees that are meant to be used for wheels and other parts that see stress.
As far as this goes,( there is a debate but most metallurgy finds this to be untrue)
To weaken or change the metals structure, you would have to heat it much higher and much longer to do anything to it, also when you get into tempering and such, the way it cools down is also a huge part.
So yes this is untrue, (in our case anyway,)
Thanks,
Jesse
1987 Conquest- 2.1 project started...
1986 Dodge D-50- S.C. truck 2.6 turbo swap started
1992 Mazda Mx-3- Rear mount twins in progress
1989 Suburban- Project for too Long!!!
"Just Remember, I HATE Drama"
mx3twinturbo is offline   Reply With Quote
Old 03-06-2010   #42
Well, I can stop by with it sometime, and show ya, or snap photos. It's definatly seen better days.
Old 03-06-2010   #43
blackrosenova400
blackrosenova400's Avatar
Cast aluminum and magnesium parts may experience out-gassing and or bubbling in the finished powder coating caused by porous coatings.
20g Mafia
Old 03-06-2010   #44
Thanks,
Jesse
I read on a couple metallurgy/engineering/machining sites about this and while it can/does happen it probably isn't necessarily something to worry about. I'd personally just rather err on the side of caution and use a lower temp application with a short heat and cooling cycle.
http://www.pfonline.com/articles/cli...06cl_pwd2.html
http://www.eng-tips.com/viewthread.cfm?qid=151053
Old 03-07-2010   #45
mx3twinturbo
Did you mean porous CASTings?
yes we usually out gas parts when we feel this could be a problem,
Old 12-18-2010   #46
my2cent
my2cent's Avatar
Drives: 99 gsx
Can you guys powder coat o2 housing and exhaust manifold? If so how much?
my2cent is offline   Reply With Quote
Old 12-18-2010   #47
GsXtUrBo98
GsXtUrBo98's Avatar
Drives: 98 GSX, 04 is300
You would want that stuff ceramic coated and yes they do it.. maybe ill post up a pic tonight of my manifold they did. They do great coating work there!
98 GSX (built)
03 BBY EVO dd
GSX 463awhp 363awtq on DB!
Old 12-19-2010   #48
GsXtUrBo98
GsXtUrBo98's Avatar
Before and after shots of my SLS manifold that I had cermanic coated by Primo.
ID:	11172   Click image for larger version
98 GSX (built)
03 BBY EVO dd
Old 12-19-2010   #49
my2cent
my2cent's Avatar
Drives: 99 gsx
That looks nice! Do they doing any porting services?
Old 12-19-2010   #50
GsXtUrBo98
GsXtUrBo98's Avatar
They would have to chime in on that one.. I'm not 100% on that one.
98 GSX (built)
03 BBY EVO dd
Old 12-19-2010   #51
Yes they do porting, Jesse did an awesome job on my Turbonetics T3 manifold.
Old 12-26-2010   #52
turboimports
turboimports's Avatar
Drives: DSM and Mitsu history
How much to powder coat a set of 4 Honda CRV 15" alluminum wheels? No tires, no wheel weights, etc.
Obviously will need to be stripped/prepped and powdercoated.
Old 12-27-2010   #53
blageo23
AWD4G64
blageo23's Avatar
Pm'd
1998 Spyder AWD
567hp
490tq
Old 01-02-2011   #54
b00sted_spyder
How much to powder coat an aftermarket fuel rail Dominic purple?
Old 02-17-2011   #55
turboimports
Sorry guys. Ended up selling trading in the CRV. I'll update you guys on powdercoating some new wheels.
Old 03-01-2011   #56
At-Least-It's-An-Evo
At-Least-It's-White-Again
At-Least-It's-An-Evo's Avatar
Drives: 98 iVTEC
How much to powdercoat IC pipes wrinkle black?
'04 Honda Ricer: stock
Old 03-01-2011   #57
OMFGeofffff
OMFGeofffff's Avatar
Drives: '90 Talon Tsi AWD
Do you guys have a color chart or anything?
OMFGeofffff is offline   Reply With Quote
Old 03-01-2011   #58
GsXtUrBo98
GsXtUrBo98's Avatar
^ they have a whole bunch of colors that they do.. if you go there they have a bunch of samples.
98 GSX (built)
03 BBY EVO dd
Old 04-25-2011   #59
gohan2058
gohan2058's Avatar
Drives: Stealth TT/Eclipse GS-T
Send a message via MSN to gohan2058 Send a message via Yahoo to gohan2058
I need an estimate for the following:
Strip and grind valve cover, removing letters, coating...
Rice...good food...shitty cars... :)
gohan2058 is offline   Reply With Quote
Old 04-26-2011   #60
blageo23
AWD4G64
blageo23's Avatar
PMd
1998 Spyder AWD
567hp
490tq
