Old 04-09-2010   #21
jhaan_dude
jhaan_dude's Avatar
Drives: a car
Re: Blue Smoke HELP
nah i rebuilt it, he blew it in less than 30 miles so he needs a new one again...sadness...
Old 04-09-2010   #22
twack
It was a auto get over it
twack's Avatar
Re: Blue Smoke HELP
why did it blow in 30 miles?
Old 04-10-2010   #23
CarPsyco84
CarPsyco84's Avatar
Re: Blue Smoke HELP
Did you actaully put parts in it or just take it apart and reassemble it?
-When in doubt, Moar RPM.
Old 04-10-2010   #24
Cammaxon
Brian Spilner called...
Cammaxon's Avatar
Re: Blue Smoke HELP
Will it need to be balanced after it's all taken apart and put back together?
I Like Cheese
Old 04-10-2010   #25
jhaan_dude
jhaan_dude's Avatar
Drives: a car
Re: Blue Smoke HELP
i rebuilt and replaced the seal so that it wouldnt burn so much smoke while he waited to put the new return on. unfortunately the seal was damaged in the 30 miles that he drove his car. if the parts would have been readily available his car would have a great oil seal and an even better running motor.
Old 04-10-2010   #26
Cammaxon
Cammaxon's Avatar
Re: Blue Smoke HELP
I just don't know how the return line could have caused it to fail so quickly.
The return line wasn't all that bad. it did have a few dings in it, but nothing that would have restricted oil all that much. and it was leaky because we didn't have a gasket going to the turbo thats understandable.
There is that dent towards the tops
It's hard to get a pic inside because of the light but there's no way that small restriction caused it to go out so quickly
this sides pretty good too
When i start the car (initial idle) and at WOT its well over 100psi. (maxed my gauge out)
Do you think possibly the oil restricter is bad? because i could understand how 100psi could blow the seal.
when you just replaced the exhaust wheel, that had a new seal on it but you said my other seal looked fine? so what else could it have been? could it have also been the compressor house or end cap oring? Im running out of ideas.
I Like Cheese
Old 04-10-2010   #27
CarPsyco84
CarPsyco84's Avatar
Re: Blue Smoke HELP
yeah, 100psi is bad. max you want to see is 60-70psi, but is your gauge after the restriction or before? And the holset's are supposed to have a 19mm(3/4") ID Minimum on the return line.
Old 04-10-2010   #28
Cammaxon
Cammaxon's Avatar
Re: Blue Smoke HELP
The gauge is before i literally took out the stock sending unit and replaced it with this one.
I Like Cheese
Old 04-10-2010   #29
123abc
wants to be sideways...
123abc's Avatar
Drives: Loud cars
Re: Blue Smoke HELP
My gauge reads up around 100 psi when I'm up above 5k. Idle is like 10-12 psi.
Originally Posted by Matt D.
Originally Posted by 93GSX5SD
Old 04-10-2010   #30
Cammaxon
Cammaxon's Avatar
Re: Blue Smoke HELP
idle idle is like 20ish its just for the 1st like min of idle. are u in winona? u wanna come watch GI joe or ninja assassin ?
I Like Cheese
Old 04-11-2010   #31
CarPsyco84
CarPsyco84's Avatar
Re: Blue Smoke HELP
If you run a restrictor. You need to measure the oil pressure after the restrictor if you want to measure the inlet pressure into the turbo. a .100" restriction is typically appropriate for a journal bearing turbo, which yours probably is.
Old 04-12-2010   #32
Cammaxon
Cammaxon's Avatar
Re: Blue Smoke HELP
Ok so as long as Julien is not too tired, he's going to come down to Winona tonight and RE-rebuild it. i would drive it to him except it honestly pisses out 1QT of oil a minute directly from the hot side of the turbo.
I Like Cheese
