Old 04-20-2010   #1
The 92 Laser
The 92 Laser's Avatar
Drives: Turbo Miata
Help with where to install oil sensors on OFH
Ok so I bought a oil temp and oil pressure gauges(premium prosports) I have a 92 laser AWD with OFH off a 90 with an external oil cooler. I was wondering where to put the sensor at? I modified the pics(sorry they are a little ghetto Im not very tech savy) Any help would be great.
Thanks Ross
Both the gauges are electrical
ID:	10046   Click image for larger version
The 92 Laser is offline   Reply With Quote
Old 04-20-2010   #2
b00sted_spyder
Re: Help with where to install oil sensors on OFH
4 is where you would put the oil pressure sending unit.
Here's what I did to install it:
http://www.dsmtuners.com/forums/arti...ure-gauge.html
Old 04-20-2010   #3
The 92 Laser
Drives: Turbo Miata
Ok so i guess your using a mechanical oil pressure gauge? Mine is an electrical so i would do the same thing but with the T right?
Thanks oss
Old 04-20-2010   #4
I would get a T BSP fitting for spot #4 and install them both there. That's the stock oil pressure gauge location.
Old 04-20-2010   #5
You could also get the sandwich plate Prosport makes. Not sure it would clear the alternator and downpipe on a 1g with the 90 OFH though
http://prosportgauges.com/oil-filter-adaptor-plate.aspx
Old 04-20-2010   #6
b00sted_spyder
Sorry to thread jack but what goes in spot 2? Mine has a plug in spot 1 and an open one in spot 2.
Old 05-12-2010   #7
b00sted_spyder
Bringing this back up because I need to get this done and didn't want to start a new thread. Using the picture from OP, I have an open thread in 1, a plug in spot 2, feed line to turbo from 3, and oil pressure unit on 4. What do I do with 1? Should I just plug it?
