Old 04-29-2010   #561
Re: Swifty's never-ending project thread!
flips McGee, I love it!
Old 04-29-2010   #562
santa
Boost Spike
santa's Avatar
So, how did the old gasket look? Could you see the point of where it was leaking?
Old 04-29-2010   #563
lol
Old 04-29-2010   #564
Constant_Project21
Constant_Project21's Avatar
Drives: E36
x2?
Old 04-29-2010   #565
It seemingly looked from the timing side when it was on the car, but once it was off, and coolant all over, the copperspray just kinda went everywhere I guess. I just cleaned all surfaces off, and threw the new one in. Also made things much easier to pull the studs out this time, so i don't worry about the washers all falling off.
Old 05-02-2010   #566
cmspaz
Walls need hugs too
cmspaz's Avatar
To bump this for Swifty's banned ass, he went through all that and it ended up being the water pump. Was still a good idea to get that gasket out of there anyway, but that wasn't the issue.
Originally Posted by Trogdor
Old 05-02-2010   #567
We told him to check that first... haha
Old 05-02-2010   #568
wow, why wouldn't you check the easiest/cheapest thing first.
Old 05-02-2010   #569
At-Least-It's-An-Evo
At-Least-It's-White-Again
At-Least-It's-An-Evo's Avatar
Drives: 98 iVTEC
Why would someone want to do that?
'04 Honda Ricer: stock
Old 05-02-2010   #570
blackrosenova400
blackrosenova400's Avatar
Ahhh, I dont believe he has it fixed. He resealed the water pump and its still leaking.
I still believe his headgasket isnt sealing. I wanted to check his head and block with my straight edge before he put his new head gasket on but it was too late, he had it all together.
20g Mafia
Old 05-02-2010   #572
Originally Posted by blackrosenova400 View Post
Now he thinks its his weep hole of the pump.
weep hole? is that like a pewp hole? lol
Old 05-02-2010   #573
cmspaz
Walls need hugs too
cmspaz's Avatar
Water pumps have a little hole that'll drip coolant. It's normally a very small amount, no more than a drop each time you run the car. Don't ask me why, I just know it's there.
Old 05-02-2010   #574
munchgsx
munchgsx's Avatar
Drives: 2004 Corvette M6 F45
The only reason coolant would come out that hole it is the bearings in the pump are shot. Get a new pump and tune the dumb thing.
Is that all thats left to be done?
Old 05-02-2010   #575
I'll be tearing it apart YET AGAIN tomorrow after work and replacing it with a pump Chad (black rosenova) is giving me that has less then 4,000 miles on it, along with another dumb paper gasket, and a THIN coat of rtv to get it to hold to the pump while i put it in place. I double checked the freeze plug on the side of the head..no leaks. Nor the teflon paste coated allen plugs behind the cam gears on that side too. No other leaks on the car, besides some stupid shit on this side. It took a damn day to get the hg done, then the water pump gasket done, and it was just fine, no leaks when I ran it in my garage, while others looked over it with me. Only started this issue when I was driving to and from cars n coffee yesterday morning. Timing belt and that side is covered in coolant..retarded.
Old 05-02-2010   #576
craig
wants to kick mark
craig's Avatar
Drives: Battery with wheels
This is no longer true on new water pumps, they are designed to release pressure to save the seals.
Old 05-02-2010   #577
Let me know if you need a hand man. I want to see this thing out n about, and could lend a hand if you need.
Old 05-02-2010   #578
Thanks bud. I won't make ya drive down from blaine though. I just need to sort it out. Once I know the issue, fixing isn't hard.
Old 05-04-2010   #579
Replaced the waterpump, and saw the oil seals for the camshafts were also bad, so I replaced those from ones Kerry gave me (thanks a ton bud!). Seems to have fixed the issues..true test will be driving it to the gas station to fill it back up with new fuel. I also tentatively set up a dyno date with Shane..May 20th, 2pm. Hopefully all goes well!
Old 05-04-2010   #580
Awesome dude!
