Old 05-18-2010   #1
santa
Boost Spike
santa's Avatar
inovate lm1 wideband
I've got a inovate wideband for sale. I've used it for about 4 years now and Its time to get a aem ugo in the car. It is a great portable device! I really like it but, I don't tune as many car's as I used to so Its time for it to find a new owner. Heres a description of it. It does have the rpm converter cable as well as the cd for logging with the lap top.
Tuning an engine for maximum power previously required long trial-and-error sessions on a dynamometer. With the LM-1, precise AFR measurement allows the user to correctly adjust many variables- including carburetor jetting, fuel injection, turbo fuel curves, etc.- without long and expensive dyno sessions. The meter’s digital signal processing technology provides data on exactly how rich or lean an engine is running at any load. The LM-1’s self-calibrating circuitry also compensates for changes in temperature, altitude, and sensor condition.
The instrument can sample and store 6 channels of data- air-fuel-ratio and up to 5 other sensor data channels- internally in operation for later analysis on a personal computer. At a sampling rate of 12 samples/second the instrument can store up to 44 minutes worth of data in non-volatile memory. The data can be downloaded to a personal computer using a standard serial port and viewed/analyzed by the included software or any standard spreadsheet program.
The RPM Kit is comprised of the basic kit plus the LMA-2 Auxiliary Input Cable. This cable contains a circuit to convert a tach signal into an analog RPM singal that can be logged by the LM-1. This cable also has 4 additional terminal screws to tap into and log other sensors in your vehicle
I've got about $450 into it and would like to see around $220 out of it. (does not include o2 sensor bung.)
Old 05-18-2010   #2
santa
Boost Spike
santa's Avatar
Re: inovate lm1 wideband
Bump for price drop $200
Old 05-21-2010   #3
santa
Boost Spike
santa's Avatar
Bump Offers??
