Closed Thread
Old 06-08-2010   #22
311evo
311evo's Avatar
Re: Modern Automotive Performance
Hmm, this thread is interesting. I haven't heard a single thing bad about them until now.
311evo is offline
Old 06-08-2010   #23
b35talon
Drives: 92 TSI AWD
This is a first for me too.
b35talon is offline
Old 06-08-2010   #24
allyoucaneat_talon
allyoucaneat_talon's Avatar
Drives: 93 Talon Tsi AWD
This is the First for me also. MAP took good care of my car. i spent like 3 grand there and till now the car is still in good running shape for 3 years. Sorry to hear about your built.
95 Talon Tsi= SOLD
92 Mitsu Gsx= SOLD
allyoucaneat_talon is offline
Old 06-08-2010   #25
So you/they used a gasket on the pump cover?
I'm pretty darn sure you arent supposed to use a gasket on that cover at all.
Super Bleeder!! is offline
Old 06-08-2010   #26
blackrosenova400
blackrosenova400's Avatar
On the small gear cover no. Im pretty sure hes talking about the oil pump front cover assembly.
But yes with a gasket there would be too much gear endplay. Also it could of had too much preload if those bolts on the small gear cover were too tight.
20g Mafia
blackrosenova400 is offline
Old 06-08-2010   #27
Mwolf83
Drives: 91 Eagle Talon AWD, 02 WRX, 97 Civic Hatch
Here are the pics of the front of the cover. And the pic of the brown seal is the original seal. I replaced it yesterday with a black one that I had laying around (new) to see if it still leaked. That was before I took the pump off the block to find that it was messed up.
The DOH lettering on the front matches the other 2 old Mitsu pumps I have laying around.
ID:	10221   Click image for larger version
ID:	10222   Click image for larger version
Mwolf83 is offline
Old 06-08-2010   #28
v8klla
v8klla's Avatar
Edit: Just spoke with Matt and it appears I took his post a bit out of context as we both agree it is very hard to determine what actually caused the failure here. Regardless, we have come to a resolution that is satisfactory to both parties. Hopefully Matt will be changing his initial post to reflect this shortly
Chris Carey, President
P: 763-545-3800
E: chris@maperformance.com
v8klla is offline
Old 06-08-2010   #29
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
Hmmm, in for MAP's side of the story...i like to hear both before i try to make a judgment.
Edit: ^ There we go.
Murlo26 is offline
Old 06-08-2010   #30
Thanks for clearing things up Chris. If he did the assembly himself there is nothing you can do, that would be like asking Mitsu to warranty an aftermarket built engine.
Kracka is offline
Old 06-08-2010   #31
mlomker
*Resting In Peace*
mlomker's Avatar
What does an oil pump cost to purchase and install? If it isn't enough to keep you from eating then I'd buy one and move on. There's nobody on this forum that hasn't had surprise expenses related to their car.
There's a reason I'm driving the `94 Plymouth right now.
mlomker is offline
Old 06-08-2010   #32
Murlo26
Murlo26's Avatar
Surprises, i haven't had one yet...
We aren't flaming you OP fyi, just saying that things like this happen in the automotive world. I still don't know how everything went down, but it seems like there was some miss communication along the way.
What you described is exactly the final reason for me going with a single shop for my motor build, because frankly i didn't want to have one build it and one tune it and then a blame game to follow if something went wrong.
Murlo26 is offline
Old 06-08-2010   #33
v8klla
v8klla's Avatar
This should have been in the good guy/bad guy section.
Anyways, I had a similar situation with MAP last year with a transmission I bought from them, the car only turned the front wheels after installation, then the blame game ensued. No discount, refund, or return because it was a used part that "worked perfectly" when it left their shop and it was "impossible" for them to warranty used parts. Buying a part that never worked in the first place, then getting refused a refund, discount, or return will leave anyone with a pretty sour taste in their mouth.
Correct me if I'm wrong but wasn't their an issue with either missing dowel pins or shifter bushings that was causing your problem? Either way, that transmission was taken from a perfectly running car just days before, and again we had no hand in the installation of the part, what would you suggest to be the proper course of action?
I bought a oil feed line for my talon. I got it very quick I was happy at first. So I went out to the garage to install the line. The oil line was to short and the fittings were wrong. So I returned the line thinking that they could get me the correct line just a fast they got me the wrong one. It took about 3 to 4 weeks. They said it wasn't there problem. It is there problem if you are sell parts that you are getting for another company you should make sure the shit is right.
I simply don't believe that anyone here said "It's not our problem" that's just not how we do business. However, we do heavily rely on other companies in some scenarios like this, if there was a backorder or something out of our control I don't know what else we could have done to rectify the situation quicker for you We would have happily refunded you in full so that you could have sourced the line elsewhere if you desired...
P: 763-545-3800
v8klla is offline
Old 06-08-2010   #34
Shifter bushings which were replaced by Alex and the car still failed to turn the rear wheels. Not sure what either dowel pins or bushings have to do with making wheels turn, but whatever. The car DID run perfectly, just only turned the front wheels.
I also drove the car down there, then was told it was not drivable for the way home. Not sure why that was either. That was also the second time I made time out of my schedule,the first was the time I had a pickup time arranged, only to see the car in pieces in the back when I got there and not one mechanic in sight.
As far as the proper course of action, make me an offer.
goodhart is offline
Old 06-08-2010   #35
v8klla
v8klla's Avatar
What I meant is that the car the transmission came from worked perfectly, rear wheels as well. With that said, being that we didn't perform the installation how do you expect me to warrant a used part that was sold in perfect working order as witnessed by several of my staff (the car in question is my fiance's cousins car that she had been driving for months prior). We didn't perform the installation, we later found errors with your installation as outlined above, and something wasn't working properly when the car made its way back to us. I don't know what happened, and I'm not willing to make any assumptions. All I know for sure is that I sold you a transmission that was in perfect working order and we didn't perform the work.
P: 763-545-3800
v8klla is offline
Old 06-08-2010   #36
Since when are IN THE CAR shifter bushings part of a transmission install? Those are the only thing that your shop replaced. It had nothing to do with any under the hood bushings or any linkage. The previous transmission never had an issue with any bushings, and the transmission after the one you sold me worked just fine also.
How are you sure that the transmission was in perfect working order anyways? Did you take it apart and inspect the internals? Did you put the car on jackstands and run the car through first gear to make sure all four wheels spun and not just the fronts? It was advertised to me as having a welded center diff, so as far as I know, that means all four wheels should turn when on jack stands correct?
goodhart is offline
Old 06-08-2010   #37
v8klla
v8klla's Avatar
I never said anything about the shift bushings having to do with the issue, I was merely pointing out errors with the install that we found upon inspection. As I outlined before the car was driven for many months before it was torn down, that includes snow, rain, etc. This isn't just a random transmission we picked up as I outlined above, which I why I am so adamant that the AWD system was in proper working order when we took the car apart.
P: 763-545-3800
v8klla is offline
Old 06-08-2010   #38
Ok, so what exactly were these "installation errors" anyways? I have done a few transmission swaps now, and we did nothing different than what we did with this one. And yes, we did install the rear bolt that most people leave out.
goodhart is offline
Old 06-08-2010   #39
v8klla
v8klla's Avatar
I believe it was missing dowel pins, and then whatever transpired with the shifter bushings. It was over a year ago now so its hard for me to remember specifics.
P: 763-545-3800
v8klla is offline
Old 06-08-2010   #40
I was told that the transmission was not removed, how exactly could you tell if the dowel pins were there or not if the transmission was never removed?
goodhart is offline
Closed Thread
