Old 06-13-2010   #81
LMFAO that is so hilarious man! Awesome you found it.
Old 06-13-2010   #82
Gotta love mitsu's. If something isn't leaking, probably means something is out of fluid
Old 06-16-2010   #83
I got the car back this morning and it turned out one of the S-AYC lines going into the rear diff was leaking rather than an actual differential axle seal so they just had to snug it down a bit and clean things up under there. They also realigned the car; the toe was a bit off which is pretty typical of the factory alignment.
Old 06-16-2010   #84
wtf leaking sayc lines! Stupid! Oh well, glad it's all happy now
Old 06-18-2010   #85
Got a care package from Scheides today!
-DB MBC powdercoated by Primo
-hood damper brackets powdercoated by Primo
-set of MitsuStyle stickers
-AFE dryflow drop-in air filter
Old 06-19-2010   #86
Sorry I didn't stick an ice cream cone and some coffee in there
Old 06-19-2010   #87
It's been a very productive morning for me! I got quite a few things installed, including:
-Mynes hood dampers
-remaining WORKS shifter bushing
-AFE drop-in air filter
-Beatrush rear differential bushings
-Whiteline rear swaybar
Stock 23mm vs. Whiteline 27mm:
Old 06-19-2010   #88
123abc
wants to be sideways...
123abc's Avatar
Drives: Loud cars
Very nice swaybar you have there.... Have you thrown it into some twisties to see the difference?
Originally Posted by Matt D.
Originally Posted by 93GSX5SD
Old 06-19-2010   #89
Not yet, I just did a cruise though my neighborhood to make sure everything was working with no strange noises. Janelle and I are heading out in a bit for lunch to this dive BBQ shack so I'll give everything a good testing then.
Old 06-19-2010   #90
craig
wants to kick mark
craig's Avatar
Drives: Battery with wheels
careful, those bbq places and white evos don't seem to mix.
Old 06-19-2010   #91
LOL we made it there and back incident-free
Old 06-19-2010   #92
mlomker
*Resting In Peace*
mlomker's Avatar
lol. At least he knows a good body shop.
Old 06-20-2010   #93
This morning I got my shifter and base bushings installed to go along with the WORKS under-hood shifter bushings that I installed last week. All I can say is: "Wow, what an improvement!" One of my biggest gripes against the stock X was the very rubbery and sloppy feeling shifter. The complete WORKS shifter package along with the AMS shifter gate pivot bushing did a great job taking up all that slack and making for a nice feeling shifter. I opted for the urethane shifter bushings over the solid metal ones like I've used in all previous cars mainly just to try something new but also to keep interior noises to a minimum. The shifter feels very precise and in the end I am glad I went for the urethane bushings over the metal ones. I made sure to lubricate everything very well with a heavy-duty lithium grease so hopefully I'll never have to touch them again (aluminum shifter bushings seem to need annual relubrication in my experience).
Install notes:
The console assembly on the X came apart even easier than the 8/9 consoles I had previous experience with. The instructions WORKS provided were decent, but I ended up following the step-by-step install guide from TWM's website since it was nearly perfect and included detailed color photos. The shifter base bushings were a bit of a bear to install since they were obviously manufactured for a snug fit...almost too snug and took quite a bit of effort to get them in. I ended up installing the front two upside down which made things easier; I see no side-effects from doing this, fitment was still perfect and everything is night and tight (I would recommend this method to anyone else installing these). I will also note that the metal sleeves from the stock rubber bushings are reused so be sure to not lose them.
Driving impressions:
The shifter feels great, nice and tight but without the chunky noise of solid metal bushings! The WORKS shifter angles the know slight rearward (similar to stock, but more aggressively) and towards the driver to center the knob in the shift boot area (similar to TWM's shifter). If I had one complaint it would be that is possible angles the knob a tiny bit too far rearward, but I have fairly long arms so it would probably be perfect for a person of more stubby stature WORKS claims a 25% reduction in throw and about .5" shift knob lowering which I think feels about perfect. Throw effort is slightly increased due to the reduced leverage but nothing to concern myself with and not enough to ever cause an issue.
Now I just need to drain out the factory-fill fluid and replace it with the Redline cocktail for the X 5-speed tranny (2-MTL 1-MT90) for what I hope will complete my "ultimate Evo X GSR shifter" setup.
Old 06-20-2010   #94
WORKS shifter in neutral:
so stock looking:
AFE drop-in with Perrin inlet pipe (BOV tube trimmed 3/4"):
Old 06-20-2010   #95
mmm....white!
Old 06-20-2010   #96
mlomker
*Resting In Peace*
mlomker's Avatar
AFE drop-in
Gonna make some posts on national forums, bitching about the install?
Old 06-20-2010   #97
http://forums.evolutionm.net/8421223-post6.html
Old 06-20-2010   #98
rose0529
Who has my man-card?
rose0529's Avatar
Drives: a red car
nice work! Good mods!
Old 06-23-2010   #99
Called DB today to confirm my tuning appt Roadtriping for a tune FTW!
Old 06-23-2010   #100
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
I bet the way back will be more fun!
My car will hopefully be getting tuned around the same time
