Old 07-01-2010   #1
v8klla
v8klla's Avatar
MAP 2.4L Drag Evo 8 makes 1053whp on Stock ECU!
After three separate 1-2 hour dyno sessions (customer cars come first and late night tuning is not looked upon kindly around here) we have reached a power level that we feel will be adequate as we continue our quest for an 8 second pass in our 3000lb street legal Evo 8. In the process we have set the bar pretty high for the stock ECU horsepower record.
Build Details
MAP Stage 2 2.4L Shortblock
- OEM 100mm Crankshaft
- MAP SpecWiseco HD Pistons
- ACL Race Bearings
- MAP Rods
MAP Stage 5 Cylinder Head
GSC S3 Camshafts
GSC Valve Springs & Retainers
Fidanza Cam Gears
Precision Turbo Billet Ball Bearing Turbocharger
Speed Density with AEM 5 Bar
Sparktech Coil on Plug
AEM CDI Ignition Box / Wideband / Gauges
ETS 5" Front Mount Intercooler
Fuel Injector Clinic 2150cc Injectors (E98 Fuel)
Magnus V5 Cast Intake Manifold & Fuel Rail
OEM replacement parts supplied by mitsubishiparts.net
QuarterMaster Twin Plate Clutch (2010 Revised Version)
Torque Solution Motor Mounts
Mishimoto Aluminum Radiator
Turbosmart Raceport BOV / 45mm Wastegates / eBoost2 / AFPR
Stock ECU Developers / Innovators
As always we can't say enough about how thankful we are to the stock ECU gurus that made this a possibility. If I try to name all of you I will most certainly leave someone out unintentionally, so I hope that addressing the group as a whole will sufficiently convey our gratitude If ever there is anything we can do to further advance the capabilities of the stock ECU please don't hesitate to let us know!
Click the image below for a larger view!
Click to watch the video!
http://www.youtube.com/watch?v=eo03R...eature=channel
Thank you to our sponsors, this wouldn't be possible without you!
Chris Carey, President
Modern Automotive Performance
P: 763-545-3800
E: chris@maperformance.com
Old 07-01-2010   #2
Nartanian
I will eat you aliiiive!!
Nartanian's Avatar
Drives: 1992 Galant VR-4
Re: MAP 2.4L Drag Evo 8 makes 1053whp on Stock ECU!
Man, all these 1000+ hp Evo's popping up. I dare not challenge an Evo to a race. Good work.
Just some corn and a MBC. Try it. You'll be amazed.
Nartanian is offline   Reply With Quote
Old 07-01-2010   #3
^ Just race it from a slow roll
Lets see some more pictures of the actual car! Thing looked like a beast, too bad you couldn't make any decent passes with it yet.
Old 07-01-2010   #4
v8klla
v8klla's Avatar
Added an engine bay pic for you, the exterior is very stock...sleeper
P: 763-545-3800
Old 07-01-2010   #5
Thanks for the shout-out guys! 1053....I'm in shock. This thing looked great going down the track at BIR, I can't wait to see it go a this power level. WOW!
Old 07-01-2010   #6
Engine bay looks awesome, get some more detailed pics up please.
Congrats, will the rest of the car get setup so you can make some passes this year?
Old 07-01-2010   #7
v8klla
v8klla's Avatar
Hopefully in time for he BR shootout in August
P: 763-545-3800
Old 07-05-2010   #8
maperformance
Drives: EVO
Send a message via AIM to maperformance
Transmission is out and going to get some upgrades!
maperformance is offline   Reply With Quote
Old 07-05-2010   #9
About time!
Old 07-05-2010   #10
98gstaherns
I need boost in my life
98gstaherns's Avatar
Drives: '14 chevy 1500
Only a 1053 WHP. Come on guys step it up! lol Great build that thing is gonna be nasty!
Tyler Aherns
-USN-
