Old 07-15-2010   #1161
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
Those pillars sell for $50 or so. Crazy what they get for plastic. If you end up wanting it then I'm sure I'll owe you for something by then. lol.
Shane surprised me by getting my car on the dyno today! He said he had to raise fueling by 10% in the higher rpms. The Bosch flows pretty well compared to two Walbros, in other words.
I'll try to go grab the Evo over lunch tomorrow. It's a PITA to transport the car around since I live alone. Will have to have my Dad help me retrieve the beater on Saturday. I was thinking of running over to that MAP event on Saturday anyway...I'll have the cool car now.
Old 07-15-2010   #1162
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
Re: Evo X upgrades
Still at 430ish I am guessing? I don't know if I have ever seen a graph at that level...do you have one? Would love to see torque, spool, all that good stuff.
Old 07-15-2010   #1163
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
I'd assume so. He said 25psi. My boost gauge read 24.2 on a pull the other day so that's pretty darn close. Shane said that the ECU pulls timing at about 7k rpm due to running out of MAF, so the graph wouldn't look very pretty.
I have a track day on the 26th but hopefully I'll have an intake and will have Shane retune with that and the ID2000's...end of the month or early Aug.
My goal is to have the car DONE by the Cookout. It's totally do-able. I just have the APR splitter and the brake upgrades to do...along with a few quick things (bushings, endlinks, corner balance, etc).
Old 07-15-2010   #1164
Re: Evo X upgrades
It's still in the 390-410 range. It's isn't running that much boost or timing yet. The fuel gets a little sketchy when it gets close to maxing the MAF. I assume we will go for more a bigger power tune once the 3.5" intake is done and the 2200s are back in. It's just something for him to drive on for now.
Old 07-15-2010   #1165
Murlo26
Murlo26's Avatar
Re: Evo X upgrades
Ah, gotcha, fair enough. I knew it wouldn't be a ton just because the MAF was going to be a problem.
Old 07-15-2010   #1166
Re: Evo X upgrades
If you need a ride or something, or someone to cart back teh beater I'm usually around my list is getting smaller everyday so that means i have more free time to help out.
Good to hear its running
Old 07-17-2010   #1167
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
Went over to Shawn's Dad's tonight. Installed the Torque Solutions driveshaft bushings, the o2 sensor, and some adjustable end-links for the rear sway.
As usual the o2 install resulted in both the o2 and the boost gauge not working. I guess I'll be fiddling with wiring, yet again.
Might be my imagination but those driveshaft bushings seems to have made shifting smoother. Even small improvements are noticeable since the 6 puck has made smoothness more difficult for me.
Old 07-18-2010   #1168
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
Got the gauges working. Now my front o2 keeps throwing CELs. Not sure what's up with that...did it the first time on my way home from DB a couple days ago. Always something.
Old 07-18-2010   #1169
Re: Evo X upgrades
For sure man, less slop in the drivetrain! See how you like the rear diff bushings when they go in, they should help a bit too
Old 07-19-2010   #1170
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
I have an appointment for Wed at Stellar Autoworks for corner balance, alignment, and Road Force balance on the tires. I went to their open house the other day...the owners seem nice.
I'm debating between -2/-1 and -2.5/-1.5 on the alignment. I'm leaning toward the former since I care more about road course than auto-x. I have a little time to ponder it.
Old 07-20-2010   #1171
Re: Evo X upgrades
Gonna daily drive it?
Old 07-20-2010   #1172
simulatedwood
Drives: 08 Evolution X
Re: Evo X upgrades
Depending on the tire pressures and how aggressive you drive will determine the "correct" number for car camber settings. The type of racing does not really matter for camber, the goal is even tire wear depending on how agressive a driver you are. No one wants to throw away a set of tires prematurely. I would focus on the rear toe and caster setting as this will determine how fast the car rotates. What are some of the track guys telling you?
Old 07-20-2010   #1173
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
Not really. The car is no fun in stop-n-go and I won't drive it in the Winter, other than to a shop.
There isn't much agreement on the alignment threads other than a difference of 1 front to back. CBRD runs -1.8 and -1.
I'm surprised that you run -2.5 considering your long commute. Most people say that it'll wear the tires.
Old 07-20-2010   #1174
simulatedwood
Re: Evo X upgrades
I showed you my tires, they have nice even tire wear @ 7000 miles most of that a 80 mile a day commute. Id say dont listen to all the interweb hype 2.5 is fine.
Old 07-20-2010   #1175
Murlo26
Murlo26's Avatar
Re: Evo X upgrades
^I agree, Robispec and some other very trusted people run -2.5/-1.5. That's what is on my car right now. But my biggest factor was trying to get as much as possible to fit my wheels, lol.
Old 07-21-2010   #1176
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
The PLX gauges are a pain. They use a .NET app and it wasn't written to use Admin permissions on Vista but yet they try to write a file to C:\. So the app crashes with the flash memory wiped out. Nice. I spent an hour getting them back to defaults again. I think I still need to upgrade the sensor database on them because they are only half seeing the AFR/Boost sensors.
The NAV is acting like the GPS antenna is unplugged. Need to find a diagram for that.
I'm dropping the car off at Stellar at Noon for the corner balance/alignment. Good equipment and friendly guys, so hopefully they have some skill as well.
Old 07-21-2010   #1177
Murlo26
Murlo26's Avatar
Re: Evo X upgrades
Wiring/electrical issues FTL!
Have you talked with Primo yet? Just curious how long they will take when they get the MAF flange...Bill@MAP said end of this week for those so I will probably drop that off on Monday or Tuesday to them hoping for something done by next friday. You can PM if you want. Did they ever give a price either?
Old 07-21-2010   #1178
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
Stellar is keeping the car overnight. They gave me an `01 A4 to drive. That's kinda fun since I'd never driven an Audi.
Old 07-22-2010   #1179
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
Picked the car up. It feels very different at -2.5 front, that's for sure.
I noticed that the black coating that Perrin put on my fmic has begun peeling off. Nice. I dropped them an email to see if they can do anything for me. Not sure how good of a fix rattle-can would be if other sections keep flaking off.
Old 07-22-2010   #1180
Re: Evo X upgrades
Yay for badass alignments! Audis are fun too, but idk...evo is so much more fun!
