Old 07-16-2010   #1
Galant409VR$
Galant409VR$'s Avatar
Drives: 1991 Mitsubishi Galant VR4 409/2000
WTB A MHI td05 turbo
My 50 trim turbo went out on my and I dont have the money for a hightech turbo at the moment so Im Looking for any td05 turbo. has to be in good condition meaning no shaft play and no cracks. Lookng for a s16g or a b16g or a e316g would be badass but a nice 14b will work. Let me know how much you want for what you have. If you have any other turbos that are a direct bolt on to a 2g maniflod let me know. Thanks Dan
Galant409VR$ is offline   Reply With Quote
Old 07-16-2010   #2
93gtpeater
Drives: cbr 1000rr repsol
Re: WTB A MHI td05 turbo
I have a 14b. 40 bucks and its yours. Iam in stillwater.
Old 07-16-2010   #3
MustGoFaster
MustGoFaster's Avatar
Drives: A big dirty V8
I have a Mutt 1. If you haven't been around that long it's a TD05/Garret hybrid turbo made by a company that isn't around anymore. Garret for every thing but the exhaust housing, that's 7cm TD05. It's just a little bigger than a Evo3 16G. The compressor outlet has a 90 to the passenger side. It won't be a full bolt on like a 14G/16G though, but since you had a 50 trim some things might match up ok.
$250 and I can take some pics if you are interested.
Old 07-16-2010   #4
MustGoFaster
I have a Mutt 1. If you haven't been around that long it's a TD05/Garret hybrid turbo made by a company that isn't around anymore. Garret for every thing but the exhaust housing, that's 7cm TD05. It's just a little bigger than a Evo3 16G. The compressor outlet has a 90 to the passenger side. It won't be a full bolt on like a 14B/16G though, but since you had a 50 trim some things might match up ok.
Old 07-16-2010   #5
Galant409VR$
Ya If you could take a couple of pics of it that would be great....
Old 07-16-2010   #6
MustGoFaster
There is a small crack above and below the WG. In decent shape, no in/out (axial) shaft play, maybe on the high side of normal side to side shaft play, but DOES NOT Hit the housing. It's been on my shelf for years (5+) so it should tighten up a bit with some oil ran through it. Had an adapter on the outlet side to I think 1/2 NTP. Sorry I didn't get a good pic of that, I can if you need it.
Old 07-16-2010   #7
^^ If he doesn't buy it, I'd be interested in the fittings off of it. If you're willing to part with them that is.
