Old 08-15-2010   #1
Garage air compresor setups, a little help.
I want to run hard line from my compressor to my air reel that is mounted in teh center of my 2 car garage.
After a lot of research I have found that I cannot use PVC pipe as when it gives out it basically explodes like glass. I also discovered that you need to run drops to let the moisture escape.
I was wondering if anyone on here has run a line from a compressor to a reel in a hidden/nice fashion.
I was thinking that I would just get some 1/2" or 3/4" HD hose and clamp it to the wall also, but I would still need a way for the moisture to escape.
Thanks
Aaron
Old 08-15-2010   #2
DSM_brother2
Drives: to the shop
Re: Garage air compresor setups, a little help.
we have copper piping in our shed/shop, its all the way to the ceiling, so its kinda hidden.
93 talon tsi/ 6 bolt swap
Mitch
Old 08-15-2010   #3
95talonracer
Finally Tuned...
95talonracer's Avatar
Drives: Spyder GSX
I used the high pressure PVC and worked great for me. Otherwise use galvanized threaded piping. That will work good.
Amsoil Dealer
