Old 09-16-2010   #21
Re: Fuel System?
Instead of the banjo bolt, use a 12x1.25 to -6 AN adapter. The 12mm threads into the top of the fuel filter, the -6 on the other side will go to the feed line to the rail. Then you just need the -6 to fuel rail adapter. BTW, I just found one in my box of parts after moving (the -6 line and rail adapter), if you want it. It's off my old talon, you would just need to buy the 12mm to -6 adapter from somewhere like summit.
http://www.summitracing.com/parts/EA...5&autoview=sku
Old 09-16-2010   #22
Re: Fuel System?
There's actually a nice tech article over on Tuners explaining it with pics if you aren't too sure about it all. Tells you all the fittings you'll need and what-not. I'll try to find it and link it here.
Old 09-16-2010   #23
Re: Fuel System?
http://www.dsmtuners.com/forums/arti...fuel-feed.html
There ya go. You can see in one of the notes which fitting works for the stock filter to adapt it to fit a new feedline. And he thanks user me612 for the tip, guess who that might be
