Old 07-15-2010   #1
Perkul8r
Perkul8r's Avatar
Drives: 91 GVR4
What to use to glue dash back down?
On the passenger side my dash cover is starting to peel off. The previous owner tried to glue it down but it didn't work. What would work to bond that back to the metal frame behind it? I have seen lots of different glues, but just am not sure what to use. Thanks.
Old 07-15-2010   #2
Chim55117
Drives: 2007 BMW 335i Coupe
Re: What to use to glue dash back down?
When I had a 1G-A, I used Gorilla glue combined with rubber bands/a heavy object to clamp them to each other. The next morning the dash was on there solid.
"We are what we repeatedly do. Excellence then is not an act but a habit." — Aristotle
Chim55117 is offline   Reply With Quote
Old 07-15-2010   #3
mitsukid124
mitsukid124's Avatar
Drives: 97 eclipse gst
if the metal is smoothe sand it down a little to give the glue a better surface to adhear to.
+1 for gorilla glue
mitsukid124 is offline   Reply With Quote
Old 07-15-2010   #4
Perkul8r
Perkul8r's Avatar
Drives: 91 GVR4
sweet, gonna try that this weekend. thanks guys
Old 07-16-2010   #5
Mighty Putty
Old 09-19-2010   #6
bertrenolds5
bertrenolds5's Avatar
Drives: 91 eagle talon GST
Mighty Putty
Are you for real? That is hilarious! I actually used gorilla glue on my dash as well, still sort of holding but I don't believe it's a long term fix. I would lean towards a 2-part epoxy and some clamps like the ones for patato chip bags but industrial strength ones. Wow this is an older post.
Old 09-20-2010   #7
3M has a couple different universal adhesives that may do the trick. Their spray adhesive works great for gluing headliner fabric back in place.
Old 09-20-2010   #8
jrohner
jrohner's Avatar
I used Gorilla Glue on my 1G, and duct taped it for a day. That was last fall and it still looks good.
Old 09-30-2010   #9
bertrenolds5
Give it a few years, it's been 3 years for me and the gorilla glue isin't holding up very well anymore. epoxy that shiz, and the 3m spry adhesive for the headliner is decent but farbic glue does the trick.
Has anyone made their own headliner?
