View Poll Results: Where do I go from here? (now that all of the children have grown up...)
Build the X 17 56.67%
No one wants a $60k evo with high monthly payments, get out now and buy a 9. 13 43.33%
Voters: 30. You may not vote on this poll
Old 10-07-2010   #1081
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
I just checked your log from the dyno day, ~82% IDC at 7500rpm and ~87% IDC at 8886rpm. 2 counts of knock @ 2900rpm on one pull, i.e. nothing.
Cool Very strange why it would be acting up on the street then ?
Glad those logs looked good, that should be enough fuel for another 25-30whp I would think, I know we can push it past 100% if needed.
Old 10-07-2010   #1082
Very strange why it would be acting up on the street then?
Because it's being loaded differently.
Old 10-07-2010   #1083
mlomker
*Resting In Peace*
mlomker's Avatar
Yeah, not enough for E98 though. Would probably have to bump the base. Hopefully DW figures out how to make a 1650ish injector behave on the X.
Old 10-07-2010   #1084
Murlo26
Murlo26's Avatar
I don't see myself doing E98 ever, but who knows, maybe I will try it. If i did that I would more than likely run higher base fuel pressure to try to get it to work...but E98 seems like a pain to try and I don't think I want to stress my motor that much...not now anyway. 550whp on Shanes dyno would be cool though
Old 10-07-2010   #1085
Hmmmm. An Evo X that is fine on the dyno, but has fuel problems that cause knock on the street, where have I heard this before.
Old 10-07-2010   #1086
mlomker
*Resting In Peace*
mlomker's Avatar
<whistling>
Old 10-07-2010   #1087
cmspaz
Walls need hugs too
cmspaz's Avatar
<whistling>
Whistle louder, none of us have heard you yet!
Originally Posted by Trogdor
Old 10-07-2010   #1088
Murlo26
Murlo26's Avatar
Looks like the oil pan was leaking a bit. They are fixing it now. Then I think they are going to bleed the clutch again.
EDIT:
Oil pan sealed now again now, clutch bleed again, we will see how they hold up.
Old 10-07-2010   #1089
311evo
311evo's Avatar
Jeebis.
Old 10-07-2010   #1090
Murlo26
Murlo26's Avatar
Originally Posted by 311evo View Post
Jeebis.
Old 10-07-2010   #1091
311evo
311evo's Avatar
These evo X's cant get away from miscellaneous issues.
Old 10-07-2010   #1092
Murlo26
Murlo26's Avatar
Ah, yea they don't seem to go as smooth as the 8/9's...but people have had a lot more time to iron out the 4g63 than the 4b11...we will get to easy street someday too
The oil pan was a used one and was bent slightly in a corner, so they reshaped it and resealed it...so should be good to go now.
Old 10-08-2010   #1093
X's will get to the point where dsm's, 8/9's are... the point where things like leaks and things needing to be fixed constantly are normal/acceptable on a daily basis.. That's just Mitsu's Style.
Old 10-08-2010   #1094
Murlo26
Murlo26's Avatar
Oh joy, I cannot wait, lol
For some X's they are there already, you just have to mod enough stuff with really complicated setups
Old 10-08-2010   #1095
mlomker
*Resting In Peace*
mlomker's Avatar
If tonight's work doesn't pan out should I go with one big fuel pump or add another? lol. From what I've read, parallel 044's is the tits setup. I would probably just do a Magnafuel though.
Old 10-08-2010   #1096
Murlo26
Murlo26's Avatar
Honestly I don't want to know this answer, I will assume your setup will work!
Godspeed!
Old 10-08-2010   #1097
cmspaz
Walls need hugs too
cmspaz's Avatar
You're telling me my car's supposed to break and leak things? Huh...
I think it's broken, everything's fine!
Old 10-08-2010   #1098
Be patient
Old 10-09-2010   #1099
Murlo26
Murlo26's Avatar
clutch pedal dropped to the floor again tonight Me and my buddy who works at Toyota inspected the hydraulic lines for the clutch and the master/slave cylinder and it looked good...so starting to think the master cylinder is bad
Sigh.
However, no knock on multiple runs tonight and shifting at 8500 keeps me in boost and its smooth to the next gear!
Old 10-09-2010   #1100
Shitty. Does the car have that Magnus CMC in it? Bleed it bleed bleed it. Does the slave cyl rod move at all when the pedal is pushed?
Tags
casual mention of an evo, cold little murlo, daves sexcapades, flip flop, flip flopppp, hotdog crank polishing, manifold butthurt?, sexy time.
