Old 11-07-2010   #161
Rmondoh
Minority of MitsuStyle
Rmondoh's Avatar
Drives: '08 OBP Evo X GSR SSS (Deadmau5X)
Send a message via AIM to Rmondoh Send a message via MSN to Rmondoh Send a message via Yahoo to Rmondoh
Re: Deadmau5X: MOAR Mods 'N Stuff
What size is that exhaust? 3" then splits to dual 2.5" ?
Yup, that's right.
08 Evo X GSR - Octane Blue Pearl
Cobb Stg1 AMS 93 OTS: 305hp 291tq 20.6psi
Cobb Stg1 93 Pro: 317hp 322tq 24.5psi
Cobb Stg2 AMS 93 OTS: 315hp 323tq 23psi (LWG map)
Cobb Stg2 93 Pro: 343hp 358tq 26psi
Cobb Stg2 93 Pro: 355hp 361tq 26.4psi (ported stuff)
Rmondoh is offline   Reply With Quote
Old 11-09-2010   #162
Rmondoh
Rmondoh's Avatar
So I met up with Kracka at the powercoating dude's shop and checked out the candy blue that Kracka recommended. It looks REALLY nice even under the shop lights. Couldn't really see it in the daylight...because there was none! Stupid Daylight's Saving Time. Regardless, I have to agree with Kracka when he said that in direct sunlight, that candy blue is going to shine so well and give a nice spectrum of blues. It's going to look awesome! I can't wait to rip apart the piping. Hopefully I can tackle that in 2 weeks!
Old 12-04-2010   #163
Rmondoh
Rmondoh's Avatar
Update Time!!
So I finally got around to installing my Whiteline Rear Swaybar. It was pretty easy to install except for the fact that I didn't install it.
I had a problem getting one of the bushings and saddles to line up properly and no matter what I tried, they would not line up. After 45 minutes of trying, I gave up and put the stock one back on.
I then told Kracka about it and he kindly went out to his car and took some pictures of his Whiteline bar and sent them to me. Everything fit nicely and looked good. So the next day I decided to try again after seeing his pictures. I knew exactly how to orient the bar and everything. Yeah well no such luck. I had the exact same issue. So I was even more pissed off and irritated because now I had failed for a 2nd time. It should only be like a 20 min job at most...but not for me.
I reported back to Kracka and he didn't believe me. I told him I quit on it and didn't want to put a rear swaybar on anymore. I was sick of it. He told me to come over on Tuesday night and he would get it on there for me. So I said sure, obviously my noob self can't put it on and he has the EXACT same bar so why not.
Come Tuesday, I go over and we start doing the swaybar. We get to the point where I was having trouble and he looks at it and goes "Hmm." He tried for a bit to make it fit. Pushed it over to get more room. Wiggled it to make it sit better. Nope! Wasn't going on. The only way it would fit is if the bushing was all open looking and on the bend on the bar. If we could even tighten it down like that, I'm sure the bushing would have snapped in half in a day easily. So we put the stock bar back on.
I managed to take pictures when I tried putting it on the 2nd time. I ended up sending those to Bill @ MAP and he forwarded on my email to Whiteline. They are going to send me a new swaybar and it should be here on Monday (12/6/10). So I'm all happy again.
Well I get an email from Bill yesterday saying that Whiteline sent him an email. As my luck would have it, the swaybar they already sent me is ALSO defective for some reason. So now when that one arrives, I will have to put the old one I have into that box and have BOTH of them shipped back to Whiteline. What a complete disaster this has turned into...
So after emailing with Bill @ MAP, I looked at their other swaybars and decided to go with a 25mm Perrin instead. After doing some research I found the following:
Whiteline:
Soft setting - 148%
Medium setting - 181%
Hard setting - 220%
Perrin:
Soft setting - 127%
Medium setting - 153%
Hard setting - 186%
Kracka tells me that for his driving style, the Whiteline Medium setting is perfect. Given my driving habits, I would probably have chosen the Whiteline Soft. I may do the Medium, but I would never go with the Hard setting. Given the numbers above, the Perrin bar gives me a better offering than the Whiteline bar as I'm more likely to use all those settings. The max for the Perrin is the Medium of the Whiteline, which would be my max. So the Perrin bar seems to be a better fit for me and my driving style and it does offer a slightly softer setting than the Whiteline.
So I told Bill to quote me the difference and it was a done deal. I should be getting it this coming week and I'll be installing it on the weekend. Hopefully nothing retarded stupid is wrong with this one.
Old 12-04-2010   #164
Rmondoh
Rmondoh's Avatar
Also today, I rode in Kracka's X as we went to Cobb to pick something up. During the drive he asked me how I liked the Prokits. I turn to him and say "I haven't put them on yet. You should know that." He looks at me and says "My car has the Prokits remember?"
OHHHHHHHHH! Yeah I had a total noob moment there. If he had not said anything, I would not have even remembered that his car has Prokits. I guess that's a good thing because I didn't notice any difference on the drive. They seem to be a LITTLE bit softer but not a whole lot so I think they are going to be perfect for me.
Old 12-04-2010   #165
mlomker
*Resting In Peace*
mlomker's Avatar
I have the Perrin bar on medium. Haven't felt a need to adjust it.
Old 12-04-2010   #166
Rmondoh
Rmondoh's Avatar
I will most likely run the Perrin on Medium as well as that's the rating I would have run on the Whiteline.
Old 12-04-2010   #167
simulatedwood
Drives: 08 Evolution X
Perrin on Meduim is what I run for AutoX, if you run the Perrin on hard setting, the car feels a bit to loose to be fast on the course (this is with the stock suspension). The hard setting does make for some rather fun drift action, Yo! ;P
Old 12-05-2010   #168
Rmondoh
Rmondoh's Avatar
That's good to know!
Old 12-05-2010   #169
That, and Super Jackass Mode.
Old 12-05-2010   #170
Whoah , swaybar drama! They're a PITA like anything else, I'm with you on the '...except for me' stuff, as stuff always seems to happen. Never had a swaybar not fit though, that is def a first!
Also, I think your car should be 'DeadmauX' (pronounce it dead moux or whatever), seeing 'Deadmau5X' always throws me into 'dead mau 5 X and that is just blargypoo.
Old 12-05-2010   #171
Rmondoh
Rmondoh's Avatar
\/\/311 +h4+ ju5+ /\/\34/\/5 j00r /\/0+ l33+ 3/\/0ugh +0 54y /\/\y c4r'5 /\/4/\/\3.
LOL!
Old 12-05-2010   #172
Hah, or you could not just steal techno dude's name for your car, what if he owns an evoX? What will he call it?
Old 12-05-2010   #173
Rmondoh
Rmondoh's Avatar
I think he will be just fine...I mean he named his cat Meowingtons. I can't even imagine what he would name his evoX, lol!
http://www.facebook.com/album.php?ai...&id=9980651805
Old 12-07-2010   #174
Rmondoh
Rmondoh's Avatar
UPDATE!
So UPS delivered the defective Whiteline rear sway bar yesterday. I took the 1st one out of my trunk, opened up the box I got, and stuck it in there so they could come back and pick it up today. As it turns out, they delivered my Perrin rear sway bar today AND picked up the return package! Awfully nice of them.
So I open up the Perrin and it looks great. Nice, red, and shiny. So I open up the bushing and saddle kit and process to assemble it to see how it will all look. Check it out below!
This looks nice!
So does this end!
Wait, that doesn't look right...
This side looks perfect!
So what's wrong with this side?
This looks good to me!
....FML
But at least this side looks good!
There is no way I'm even going to try and put this bar on. If that one side doesn't even let the bushing sit flush with me just putting it on there and moving it to hit the stopper tab, there's no way it's going to fit properly on the car. It looks like that stopper was welded on at an angle, thus not allowing the bushing to sit flush. *sigh*
Looks like another email is going out to Bill at MAP with pictures showing that this one is not going to fit either. Now I know I haven't tried putting it on, but honestly with pictures and fitment looking like that, I really don't think I should even waste time trying to put it on.
You guys running the Perrin RSB on the X, did yours fit or look like this? Do you remember at all? Should I at least try to put it on once before I write Bill back?
Thoughts and comments please?
Old 12-07-2010   #175
Just put it on, not like a ton of torque is going to be put against that stopper. I bet you'll forget about it once its on and you drive the car
Old 12-07-2010   #176
simulatedwood
Mine must have been an older version as it didnt even have the stops welded on each side. Honestly when you bolt this thing down the one side will straighten out I bet you wont even notice its static state. The bar will move a bit side to side, so the tightness may not matter much. I say try it at least.
Old 12-08-2010   #177
I would just elongate the holes in that bushing holder with a dremel until it bolts up. Screw quality parts that fit right away. Working for the prize is so much more enjoyable.
Old 12-08-2010   #178
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
Edit...
Last edited by Murlo26; 12-08-2010 at 12:20 PM.. Reason: Sounded funny and made sense when I was drinking :)
Old 12-08-2010   #179
I vote we at least try installing it. Wouldn't hurt to shoot these pictures to Perrin though and see what they have to say about it.
Old 12-08-2010   #180
I bet it was designed that way. Bushings on the bar without even attaching it, arent going to line up perfect the way you think it willl. The car will suck the bushing into place if its supposed to be up against that flat side.
Most sway bars dont even have that welded flat side on the bar at all.
