Old 12-10-2010   #741
Re: beaterX project thread
Nice. How much do you expect to gain from those cams and headwork then? Maybe 25-30whp? I'm excited about this thing man, it's a shame it seems any X's that make decent power need a built motor though.
Old 12-10-2010   #742
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
There are a lot of higher powered X's still on stock blocks with t3 kits...its the guys like us that try for big power on stock frame turbo's that have problems. Lag and less torque seem to be they key to a high powered X.
Old 12-10-2010   #743
IDK if this will work just yet but should soon:
http://www.youtube.com/watch?v=qgiFLefQUlc&hd=1
Old 12-10-2010   #744
awd-drifter
'2of9'
awd-drifter's Avatar
Drives: Racer Van V6
Shit's diesel! lol. Sounds nice man. Hopefully all goes well after the MAS fix.
ლ(ಠ益ಠლ)
Old 12-10-2010   #745
cmspaz
Walls need hugs too
cmspaz's Avatar
rotella triple protection, maybe a 5w40 if I can find it. Then at 1500 miles I'll change to a synthetic and get tuned.
The Rotella 5w40 is synthetic only. 15w40 and 10w30 are their conventional offerings. I happen to know where you can find them.
Originally Posted by Trogdor
Old 12-10-2010   #746
adam at MAP
FAill...
edit: figured it out.
You should just look at it Schiedes. Just look at it.
http://www.youtube.com/watch?v=EF8GhC-T_Mo&hd=1
2004 Yukon XL SLT
571whp/621wtq
adam at MAP is offline   Reply With Quote
Old 12-10-2010   #747
^lol.
Old 12-10-2010   #748
GsXtUrBo98
GsXtUrBo98's Avatar
Drives: 98 GSX, 04 is300
That does sound like a diesel.. Congrats on the car running!!! I should suck it up and just get mine running too... Even though mines not my daily.
98 GSX (built)
03 BBY EVO dd
GSX 463awhp 363awtq on DB!
Old 12-10-2010   #749
Tonight I got the car back on the road. It sounded like a diesel for about the first four miles. I did some 2nd and 3rd gear vacuum pulls to seat the rings immediately. Parked it, troubleshooted the maf sensor some more, and murlo came over with his MAF. Swapped it in, and it did the *exact* same thing. So not sure what the deal is, BOO!
BUT, the car idles, revs, and drives about 90% fine with the maf unplugged! Its pretty amazing really, there is a slight hesitation around 2500rpm but nothing aweful, I'm sure the map scaling tables need some tweaking.
We drove all over, put another 11 miles on it. Drove to roseys, some freeway time, and side streets, plenty of vacuum pulls the whole way. When we got back to my place, I kept thinking, 'man, it SOUNDS so much better! I thought it was a big exhaust leak but it is breaking in I guess as the engine sounds perfect now.
Anna and I are off to SuperTarget to stock up before the storm
Thanks for the help Murlo!
Old 12-10-2010   #750
mdost03
Sonic Champion!
Drives: VA STI
Congrats on getting it back on the road scheides!
Old 12-10-2010   #751
311evo
311evo's Avatar
WOOOOOOOOOOOOOOOOOOOOOOOOOOOO!
Now give it a rip.
Old 12-10-2010   #752
notsostockgalant
3g camaro owner
Drives: 88' camaro 400hp 327 sbc
I was just thinkin about this on my way home after reading it earlier today, did the maf sensor wiring get pinched at all while setting the motor back in? just a random thought.
notsostockgalant is offline   Reply With Quote
Old 12-10-2010   #753
After talking with Shawn (simulatedwood) I am convinced this is a grounding problem. The ecu is seeing voltage from the maf sensor, just not sure it is the correct voltage. I'm going to double-check more tomorrow, and possibly pull the exhaust manifold off the head to try and get the turbo properly bolted to it.
Did a boost leak test, holds 5psi like a champ! Good enough for now.
Took anna for a drive to Target for pre-snow shopping, did more vacuum pulls along the way, she drives so nice! God I missed this car!
Old 12-11-2010   #754
SuperTarget off Central/694 correct? I was coming online to ask if you/your car was there last night. Figured it was a good sign the car was out and about.
Old 12-11-2010   #755
Wahoo evoX spotted in public! Ya dude that was Anna and I, stocking up before the storm and taking the car on its first drive 'away' from the house, other just kinda was making bigger and bigger circles before that.
I ordered spark plugs and that little trans hole cover from Brookdale today. No idea where that thing went but no way in hell am I driving through the snow without it.
Old 12-11-2010   #756
Wahoo! Figured it out!!! I had put one thick, main ground just above the starter, when in fact it went below the starter. It was on the block, but the spot I put it on above the starter also held a small bracket (to hold the harness off the starter), and I had put the grounding wire on the outside of that--it must not conduct very well. I moved the ground to the correct spot (the manual actually has diagrammed where each one is), fired it up w/o maf to confirm it was working, then shut it off, plugged in maf, fired it up, voila!
Put my original rom back on there and she idles pretty nice right around 900rpm. I was super excited! Didn't spend the time to futz with it any more tonight, I'll play with it this week after the snow goes away.
My back is just wrecked from all the shoveling so that turbo bolt will stay off for now.
Old 12-11-2010   #757
311evo
311evo's Avatar
Nice!
Grounds can do so much more than anyone expects, it's crazy.
Old 12-11-2010   #758
Awesome!!
Old 12-12-2010   #759
I attempted bolt #4 on the manifold-turbo with no luck, all but pulled the manifold off the car. I gave up, bolted it back down, it'll drive fine for a while longer. After shoveling for hours and hours and everything else I've done with the car, I'm just ready to drive the thing. Just going to continue to tweak and put some miles on it
Old 12-12-2010   #760
The first 20 miles of driving need to be burnout miles. No joke, it's the only way to break in engines properly.
