Old 01-25-2011   #1
awd-drifter
'2of9'
awd-drifter's Avatar
Drives: Racer Van V6
BOV Fluttering?
Is this fluttering? This is all under vacuum and not on boost. It spent a good 15 minutes getting warmed up.
http://www.youtube.com/watch?v=LW3H3XH2I2A&hd=1
Car is not tuned yet, I just started it up because it hasn't been started during these cold winter nights. When I was putting the 2g mas+intake in, the turbo had EXTREMELY small in and out play, probably not even notable. No side to side either. I know it isn't recirculated and I probably won't recirculate it till the snow melts because that's when I'll get it tuned.
EDIT:
Here's the second video
http://www.youtube.com/watch?v=NCtcz9SSbMY&hd=1
ლ(ಠ益ಠლ)
Old 01-25-2011   #2
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Re: BOV Fluttering?
link doesn't work. Malformed video I.D. was the message I got.
Old 01-25-2011   #3
awd-drifter
'2of9'
Re: BOV Fluttering?
try it now. ....tried to embed it but probably used the wrong code.
ლ(ಠ益ಠლ)
Old 01-25-2011   #4
Re: BOV Fluttering?
Is the BOV return hole on the intake blocked off and I can't see it? It looks open in that video.
Old 01-25-2011   #5
19TsiAwd90
2stepadepaaadepaaadep
19TsiAwd90's Avatar
Drives: myself crazy
Re: BOV Fluttering?
thats some serious flutter man check your hoses going to the bov
doesn't look like it is to me =/
Originally Posted by 311evo
Old 01-25-2011   #6
awd-drifter
'2of9'
Re: BOV Fluttering?
there's 2 of those vacuum hoses on the bov and i have the top hose from the bov connected going to the intake manifold and just left the bottom one open. as for the intake pipe itself, I also haven't plugged the 2 other holes so nothing else is connected to the intake pipe.
ლ(ಠ益ಠლ)
Old 01-25-2011   #7
19TsiAwd90
19TsiAwd90's Avatar
Re: BOV Fluttering?
Originally Posted by awd-drifter View Post
there's 2 of those vacuum hoses on the bov and i have the top hose from the bov connected going to the intake manifold and just left the bottom one open. pipe.
thats where the issue is they both have to be connected and im pretty sure you can just connect them both to the same source
Old 01-25-2011   #8
GsXtUrBo98
GsXtUrBo98's Avatar
Drives: 98 GSX, 04 is300
Re: BOV Fluttering?
^ or block one off.. Pretty sure I blocked off the Greddy S that I had..
98 GSX (built)
03 BBY EVO dd
GSX 463awhp 363awtq on DB!
Old 01-25-2011   #9
awd-drifter
'2of9'
Re: BOV Fluttering?
hmm, yeah, that would make sense to block off the lower one.
ლ(ಠ益ಠლ)
Old 01-25-2011   #10
19TsiAwd90
19TsiAwd90's Avatar
Re: BOV Fluttering?
one might be for a higher boost setting so try it on the other one too
Old 01-25-2011   #11
Re: BOV Fluttering?
You have to plug the BOV return on the intake pipe otherwise you are letting in unmetered air. Even if you dont recirc the BOV you have to plug that hole in the intake.
Old 01-25-2011   #12
Re: BOV Fluttering?
Leave the lower port open, so that the diaphragm can move up and down freely. And you need to plug that open hole in the intake after the MAF.
Old 01-26-2011   #13
123abc
wants to be sideways...
123abc's Avatar
Drives: Loud cars
Re: BOV Fluttering?
That's all compressor surge. Where do you have the BOV vacuum hose hooked up? The BOV isn't even moving.
Originally Posted by Matt D.
Originally Posted by 93GSX5SD
Old 01-26-2011   #14
Re: BOV Fluttering?
Is it an ebay bov?
Old 01-26-2011   #15
Re: BOV Fluttering?
What? No it's not.
http://www.youtube.com/watch?v=nCj6Spwl1CU&hd=1
Old 01-26-2011   #16
awd-drifter
'2of9'
Re: BOV Fluttering?
Is it an ebay bov?
yep...yep it is this is possibly a reason why also.
I really doubt it is compressor surge because if it was, i'm quite sure i can play with the compressor wheel but thankfully it isn't like that.
ლ(ಠ益ಠლ)
Old 01-26-2011   #17
Re: BOV Fluttering?
Originally Posted by Kevin 1G Drummer View Post
x a million. Does nobody know what true compressor surge is??????
Old 01-26-2011   #18
Re: BOV Fluttering?
That is not compressor surge. Compressor surge only happens under load when the turbo is near peak efficiency. See Kevin's video.
Your BOV is fluttering, but it's nothing to worry about as long as it holds boost. You can screw down the bolt on top of the BOV to give it more tension and that will help prevent the fluttering and cause it to only be open or closed. To be honest, as long as the car runs fine, drives fine and the BOV doesn't leak then it can act however it wants.
Old 01-26-2011   #19
munchgsx
munchgsx's Avatar
Drives: 2004 Corvette M6 F45
Re: BOV Fluttering?
It doesn't appear it is opening at all. You sure you vac reference is hooked up correctly.
Old 01-27-2011   #20
s1ngletracker
s1ngletracker's Avatar
Drives: A BMW
Re: BOV Fluttering?
doesn't having a non-opening BOV still put unnecessary stress on the turbo?
Style's automotive engineer
