Old 02-07-2011   #1
Brandito93
Brandito93's Avatar
Drives: 1989 Nissan 240SX RB20
Send a message via Skype™ to Brandito93
50 rpms?
Went into little boost in 1st gear, let the rpms come down a bit, heard the car go pop now try and start it and the rpms are at like 50. And hardly revs and doesn't shake at at all (solid motor mounts).
Any ideas?
Brandito93 is offline   Reply With Quote
Old 02-07-2011   #2
Jungy
Jungy's Avatar
Drives: 10' Sierra Denali & 99' beatervette
Re: 50 rpms?
So are you saying that it wont start after the incident?
Jungy is offline   Reply With Quote
Old 02-07-2011   #3
Brandito93
Brandito93's Avatar
Re: 50 rpms?
Oh it starts...kinda. It literally runs. At like 50rpm maybe, just won't move, doesn't even sound right and hardly revs when the gas is pushed in.
Old 02-07-2011   #4
Jungy
Jungy's Avatar
Re: 50 rpms?
Are you getting spark on all 4 cylinders?
Old 02-07-2011   #5
Brandito93
Brandito93's Avatar
Re: 50 rpms?
I do not know. It just happened and I left...It was cold as fuck out and I didn't have any tools. Me and Chris will probably go back later and check on it. It's in the tech parking lot right now.
Old 02-07-2011   #6
Re: 50 rpms?
All the intercooler pipes attached? Mass airflow sensor, cam angle sensor and throttle position sensor plugged in? Alternator fuse okay? Any check engine lights?
Old 02-07-2011   #7
GsXtUrBo98
GsXtUrBo98's Avatar
Drives: 98 GSX, 04 is300
Re: 50 rpms?
Sounds like you blew a intercooler pipe off to me.
98 GSX (built)
03 BBY EVO dd
GSX 463awhp 363awtq on DB!
Old 02-07-2011   #8
cmspaz
Walls need hugs too
cmspaz's Avatar
Re: 50 rpms?
^ +1.
Did it a million times on my old Talon, does the exact same crap yours does.
Originally Posted by Trogdor
Old 02-08-2011   #9
Re: 50 rpms?
Now regarding your issue, check your intercooler piping as mentioned above, most likely you have a giant air leak.
Old 02-09-2011   #10
Brandito93
Brandito93's Avatar
Re: 50 rpms?
Thanks guys. I will be checking those things as soon as I can get out to my car...it's frickin cold out hahah.
Old 02-15-2011   #11
Brandito93
Brandito93's Avatar
Re: 50 rpms?
Jungy we checked and only running on 2 cylinders. Brought it to presicion and they said it was the computer...doubtful. Got a new coil something, I forgot what it really was. But got a new one of those and that didn't fix it. Any other suggestions on what might it could be?
Old 02-15-2011   #12
Jungy
Jungy's Avatar
Re: 50 rpms?
You replaced the coil and still no go? How about the power transistor?
Old 02-15-2011   #13
Re: 50 rpms?
I'd verify what's causing those two cylinders to not be running. Fuel or spark (most likely spark). The follow that back until you find the problem. If it's spark, start checking plugs, wires, coil, ignitor... If no fuel, start checking injectors, injector plugs/wiring, resistor pack...
Old 02-16-2011   #14
Re: 50 rpms?
Which two cylinders aren't working? The DSM runs a wasted spark system, if they share a coil, your problem is ignition. If they don't share a coil, something else may be wrong mechanically.
I am leaning towards a coil/transistor/wiring concern.
Old 02-16-2011   #15
Brandito93
Brandito93's Avatar
Re: 50 rpms?
Ok this should probably go in the WTBorrow section ha but I already have a thread setup for this, but anyone in/around the Alexandria area have an Ignition Control Module that I could borrow asap to see if thats the part I need, that would be EXTREMELY helpful.
