Old 03-31-2011   #21
Re: 1G Talon Build or at least the start of it.
post up a picture of the numbers on the casting of the compressor cover (intake side of turbo) and we can more than likely tell you what it is.
DB sells MBC's for like $35. Cheap and they work great.
Old 04-06-2011   #22
1G4g63t
Drives: 92 Eagle Talon TSI AWD
Well I have bad news. Looks like my stock exhaust manifold is starting to crack. so I guess I'm gonna start to look for a tubular Header for it. does anyone know if I can remove the ABS without causing a ton of issues? I want a set of hard pipes but all the kits I've found are for the cars without ABS.
1G4g63t is offline   Reply With Quote
Old 04-06-2011   #23
Get one of those aftermarket cast iron manifolds if you are looking to daily drive it. It will be more than enough for what you want, plus it's indestructable.
Old 04-06-2011   #24
Unless you're planning on spending good money on a manifold (which honestly wouldn't do a whole hell of a lot seeing as your car is stock) don't bother with a tubular. Find a 2g manifold or the FP Race mani. Both are cast, durable, and won't cause any issues.
if you are deleting the ABS, you will either need the lines from a non-ABS equipped car (what I did, the easiest if you can find some) or bend your own lines, and get a non-ABS proportioning valve. I believe there is a total of 4 lines you need to replace, then you can throw away your giant octopus of an ABS module.
Old 04-06-2011   #25
19TsiAwd90
2stepadepaaadepaaadep
19TsiAwd90's Avatar
Drives: myself crazy
i have hard UICP its hks let me know if your interested
http://mitsustyle.com/forums/showthr...light=hks+rare
Originally Posted by 311evo
Old 04-09-2011   #26
1G4g63t
here is the turbo pic. I think it's a 16G after doing some reserch but I'm not sure it that's stock or not
Old 04-09-2011   #27
1G4g63t
On a side note I think I'm mildly retarded. I've tried everyway I can think of to post my pics from flickr to this forum and nothing works. is there something I'm doing wrong?
Old 04-15-2011   #28
1G4g63t
Ok time for an update....
I fixed my boost drop issue, the BCS stuck open so my wastegate was open most of the time. Wrote my to-do list last night, it's gonna be spendy but then again what DSM isn't. Made friends with a kid in my town that has a Black 95 GST. Still waiting on an answer as to what turbo I have, no one seems to know.
Old 04-15-2011   #29
LingLing
AznKraut
LingLing's Avatar
You should stop by my place on Sunday man. I can take a look at it. Or if you take off the intake tube and get a good shot of the compressor wheel we can tell you more.
Old 04-18-2011   #30
1G4g63t
Well my boost leak is fixed. I really need to get an MBC I'm not happy with the 12psi I'm putting out. but soon the major upgrades are gonna start just came across a friend who has a 4g63t sitting in his garage that I'm going to tear down and build up. I'll post more after work
Old 04-25-2011   #31
1G4g63t
Well Picked up a set of GSX rims the other day, I'm gonna polish them and paint them before mounting them on the car. so if someone is looking for a set of stock Talon rims let me know. once I swap my tires on to these new rims I'm going to be looking to off load them.
Old 06-03-2011   #32
1G4g63t
ok so I went and got a TD05 16G last week, and installed it. WOW! the car has more go and I love it. I'm still looking into changing my ABS out for a non ABS setup.
Old 06-03-2011   #33
Alpha D
Got Boost o_O'' m
Alpha D's Avatar
DO IT! Gives you so much room. I did the swap overnight. The only issue i had was fishing the brake lines back through the holes in the frame and getting the fittings to thread into the proportioning valve and master cylinder. I had to be really carefull since they strip easily! Once you get that figured its a cake walk really.
Old 06-03-2011   #34
Fyi, if you want to do it the factory way, Mitsubishi does no sell two of the 4 or 5 lines you need to remove the ABS. I just went to a junk yard and got them or you can make your own.
I'm slightly jealous of your car... I had a one just like it!
Old 06-11-2011   #35
1G4g63t
well it might end up for sale soon. I found my next project and this one is starting to cost a lot to build up
Old 06-27-2011   #36
1G4g63t
Well it's for sale now. I just bought a 300M and don't have space for the Talon anymore. $1400 or Best Offer.
