Old 04-30-2011   #1
justinhill
BetHiLow Streak Un-Censored Champion! League Bowling Champion! Snowboard Champion!
Drives: 98 gst eclipse
Send a message via AIM to justinhill
Power to coil,but no spark 2g
i clean/degrease my motor it ran fine.. So I decided to take it around the block the car turned off and would not start.. So I check to see if i was getting spark no spark. I check to connector to the coil with a test light and I'm getting power there could it be a bad coil or power transistor pack from the water hitting it? also I'm getting gas pressure.
justinhill is offline   Reply With Quote
Old 04-30-2011   #2
backwoods
Drives: talon tsi
Re: Power to coil,but no spark 2g
Sounds like you got water damage. I would replace coils.
backwoods is offline   Reply With Quote
Old 05-01-2011   #3
justinhill
Different coil pack still no spark different power transistor still no spark anymore idea's?
Old 05-01-2011   #4
95talonracer
Finally Tuned...
95talonracer's Avatar
Drives: Spyder GSX
CAS? or ECU
Amsoil Dealer
Old 05-02-2011   #5
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
You need a new cas. If your check engine light comes when you turn key, then shuts off after 5 secs. Its not the ecu.
Old 05-04-2011   #6
justinhill
Put in a new cas still no spark.....
Old 05-04-2011   #7
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Is your ecu powering up? Did you check for spark on all 4? Did you hook it up to the ac? They have the same triangle plugs on the harness.
Old 05-05-2011   #8
justinhill
Found the problem crank sensor is not reading FML.... thanks for the idea's guys.
