05-10-2011
#1
Drives: 98 GSX, 04 is300
Stripped oil feed from head..
I was just tightening up my oil feed line from the head and there was nothing there.... My old setup was fed through the oil filter housing so this was never used before.. The bolt just kept spinning and didnt even get snug. I did NOT over tighten this bolt. The threads just came off... Like I said the bolt never even got snug..
What are my options? Do I tap it? if I do, do I worry about the shavings getting into the head? what would be the best thing to do? do I need to remove the head?
98 GSX (built)
03 BBY EVO dd
GSX 463awhp 363awtq on DB!
05-10-2011
#2
Drives: 2007 BMW 335i Coupe
Re: Stripped oil feed from head..
Maybe have someone come over and weld the oil port shut if you're never going to use it again? Just a thought.
"We are what we repeatedly do. Excellence then is not an act but a habit." — Aristotle
05-10-2011
#3
This is where I am going to run the feed from.. I used to run it from the oil filter housing and while tightening the bolt onto the head for the new feed it stripped out.
98 GSX (built)
03 BBY EVO dd
05-10-2011
#4
Gotcha. Possible to block off the head, and then use a restrictor on the feedline from the OFH for your needs?
05-10-2011
#5
I don't know... I wanted to run it from the head so..
98 GSX (built)
03 BBY EVO dd
05-10-2011
#6
Finally Tuned...
Drives: Spyder GSX
Helicoil or re tap a different size. Vacuum that shit outta there.
Amsoil Dealer
05-10-2011
#7
^ that bolt it 1 size... what would I use then for a feed line?
98 GSX (built)
03 BBY EVO dd
05-10-2011
#8
Drives: 04 evo
I told you we would retap it tomorrow or tonight. You provide the beer, and I will provide the tap. I dont think it was that bad
03 as evo-sold
04 bby ssl-sold
05 ww mr-sold
03 tb evo- current
05-10-2011
#9
It looked pretty bad to me... Worst case I think it will just carve up the hole with the tap and just make it bigger..
98 GSX (built)
03 BBY EVO dd
05-10-2011
#10
Use a helicoil.
Originally Posted by Tachyon
05-10-2011
#11
SHIT SHIT SHIT! I'm SO sick of this car and all the problems I'm having with just putting it back together..
98 GSX (built)
03 BBY EVO dd
05-10-2011
#12
Helicoil it, problem solved.
05-10-2011
#13
Mine did the same thing, was a real pain in the ass. When i ended up doing was getting a longer bolt then having a place drill out the center and putting the two holes in the side like the stock bolt.
Maybe that might work for you too if the threads aren't stripped all the way back and just at the front?
05-10-2011
#14
I believe its all the way..
98 GSX (built)
03 BBY EVO dd
05-10-2011
#15
If I heli coil it wont I have to worry about the shavings getting into my head still?
98 GSX (built)
03 BBY EVO dd
05-10-2011
#16
If you retap it you'll still have to deal with shavings.
05-10-2011
#17
Chris, I was a n00b and did this too once before.
I helicoiled the head. I used grease on the drill bit, used grease on Q-tips to get them out, and cranked my engine over with the line disconnected to ensure all debris was out of the passage and would not have a free ride to my turbo.
Don't know what a Heli-Coil is? youtube, google
#18
^ I youtubed how to do it last night. Would you mind assisting me today on this project?
98 GSX (built)
03 BBY EVO dd
05-11-2011
#19
I actually typed Helicoil last night when you posted this thread. but then got to thinking.Do they make helicoils in that size though? I would look into that before doing anything. The first time i did a helicoil i was amazed at how easy and great it worked, but i was using on a regular bolt, not a feed line.
Its going to have metal shavings no matter what you do, Pack the hole with paper towel prior to drilling then use needle nose after to get the towel out, should cut down on the shavings.
05-11-2011
#20
Drives: 04 evo
weld the fitting on the head
03 as evo-sold
04 bby ssl-sold
05 ww mr-sold
03 tb evo- current
| Thread Tools |
| Display Modes |
Linear Mode
