Old 05-13-2011   #401
Re: Project Lex
2.25 should be just fine I would think.
Old 05-13-2011   #402
Re: Project Lex
2.25 fo sho.
Old 05-13-2011   #403
Re: Project Lex
I vote 2.25. Plenty of flow and it will look moar sleeperish.
Old 05-13-2011   #404
Re: Project Lex
Cool, I think that's what I'll do. I do have a left over 3" resonator from my old talon turbo back I'll used. If it still ends up being louder than I wanted, there's enough room under there to later add a 3" muffler underneath.
Old 05-13-2011   #405
Re: Project Lex
I have a 3" in/out resonator pipe, a little over 20" long, you can have it for free if you want it.
Old 05-13-2011   #406
19TsiAwd90
2stepadepaaadepaaadep
19TsiAwd90's Avatar
Drives: myself crazy
Re: Project Lex
you could keep the stock exhaust and put a e-cutout in the down pipe thats what i got on my talon i love it.. nice and quite when i dont feel like being loud and obnoxious. just fuel for your thought, figure all you would need to buy then is a 3inch downpipe with a 3inch cut out welded to the end then a flange to the stock exhaust
http://shop.quicktimeperformance.com...ct_detail&p=36
or
http://shop.quicktimeperformance.com...ct_detail&p=30
and weld on of those on to a 3inch downpipe
Originally Posted by 311evo
Old 05-13-2011   #407
Re: Project Lex
Well ended up finding 2.5 mufflers that are cheaper than 2.25, so I'm going to do dual 2.5".
So it'll be the ebay 3" downpipe that I got with the manifold kit. Going to a custom 3" midpipe I'll make out of my Talon's old turbo back using the flex section and the 3" resonator from it. Then it will split to dual 2.5" using this:
http://cgi.ebay.com/ebaymotors/3-INC...item3cb49ded6c
Then two offset in/out 2.5" mufflers in the rear. Will have to find some tips for them. Look just like the magnaflow one I had on the Talon. Got my fingers crossed they end up being great. They are cheap as fawk:
http://cgi.ebay.com/ebaymotors/OFFSE...item3a63fe6a7d
Old 05-13-2011   #408
Re: Project Lex
Thanks for the offer man. I'll let ya know but I'm thinking I'll be OK.
Old 05-13-2011   #409
Re: Project Lex
Woot back to building it custom, me likely. Buy some tips though, you now have a luxury car, it needs SS tips! haha
Old 05-13-2011   #410
Re: Project Lex
Yeah, thinking tips just like was on the talon. 4" tips, angle cut with a rolled edge. Got the one for the talon down at the local Pap Boi
Old 05-13-2011   #411
Re: Project Lex
Clutch is in. Big thanks to Andy @ Elite for lending me the Clutch Allignment Tool.
That's right, 8-bolt mufukkas:
Egay 6-puck:
Stock PP back on:
ID:	11647   Click image for larger version
ID:	11648   Click image for larger version
Old 05-13-2011   #412
93gtpeater
Drives: cbr 1000rr repsol
Re: Project Lex
Why you going with a stock pressure plate?
Old 05-13-2011   #413
Re: Project Lex
Because I was recommended this as a cheap option for the power level I'm aiming for this year.
Old 05-13-2011   #414
GsXtUrBo98
GsXtUrBo98's Avatar
Drives: 98 GSX, 04 is300
Re: Project Lex
Without reading back 21 pages... What is your power level your going for?
98 GSX (built)
03 BBY EVO dd
GSX 463awhp 363awtq on DB!
Old 05-13-2011   #415
Re: Project Lex
This year is 350-400hp. Just going to run WG boost levels to get used to the car, get kinks worked out, and also the current drivetrain can't handle much more.
And more updates
PP torqued to 14lb/ft. Tranny is back in, woo woo. Driveshaft and all that stuff is back in. Thanks for letting me borrow the tranny jack Aaron. I don't think I coulda done this job without it.
SO with that being done, what's next? Manifold. Thanks again to Andy at Elite for chopping off the old WG flange and tacking my new one in place.
Test fitting everything up. Brand new exh. mani gaskets Going to chop the end off the comp housing and get a 90* welded on that. Mo lemme know when you got your welder all setup!!
Onto the pics!
Collector. Seen better, but seen worse. It'll do just fine for me
Exh. Housing on, and downpipe halfass installed just for me to see how it lines up.
More test fitting:
Extended Tip Son!!
ID:	11650   Click image for larger version
ID:	11651   Click image for larger version
ID:	11653   Click image for larger version
ID:	11654   Click image for larger version
ID:	11656   Click image for larger version
ID:	11657   Click image for larger version
Old 05-13-2011   #416
Re: Project Lex
More pics:
ID:	11660   Click image for larger version
ID:	11661   Click image for larger version
ID:	11663   Click image for larger version
ID:	11664   Click image for larger version
Old 05-13-2011   #417
GsXtUrBo98
GsXtUrBo98's Avatar
Re: Project Lex
I'm liking it!
98 GSX (built)
03 BBY EVO dd
Old 05-14-2011   #418
95talonracer
Finally Tuned...
95talonracer's Avatar
Drives: Spyder GSX
Re: Project Lex
How far is the turbo from the hood? Cant tell in the photos. Looks great!
Amsoil Dealer
Old 05-14-2011   #419
Re: Project Lex
I must have missed it, but what are you doing for an intake manifold?
Old 05-14-2011   #420
Re: Project Lex
Stock intake manifold. Again, trying as much as possible to go 1 by 1. Change as little as possible. Get that working as good as possible before changing anything else.
