Old 06-01-2011   #1
s1ngletracker
s1ngletracker's Avatar
Drives: A BMW
Leaking oil from CAS... stumper
So i have a slow but steady stream of oil coming from my CAS area. The O-ring on the CAS is new, and I even pulled the valve cover and put sealant on the cam cap nearest that area on both sides to help seal it up.
Still leaks. Any suggestions?
Style's automotive engineer
Old 06-01-2011   #2
cmspaz
Walls need hugs too
cmspaz's Avatar
Re: Leaking oil from CAS... stumper
Hairline crack in the VC or god forbid the head?
Originally Posted by Trogdor
Old 06-01-2011   #3
s1ngletracker
Drives: A BMW
I looked real close at the VC, didnt' see a crack, I dont believe the head either, but I will look at that. Its a rebuilt head.
I'm pretty sure the CAS o-ring I got was for the 1g 7 bolt, I wouldn't think they'd be different but the head is a 1g 6 bolt. I may call the dealer to see if its a different part number. I'm grasping at straws here.
