Old 06-22-2011   #261
GsXtUrBo98
GsXtUrBo98's Avatar
Drives: 98 GSX, 04 is300
Re: GsXtUrBo98's 2G project thread
I have a date with Shane on July 14th at 3! Just need to buckle down on the car and get it there so I can at least make it to the Import vs. Domestic.
98 GSX (built)
03 BBY EVO dd
GSX 463awhp 363awtq on DB!
Old 07-02-2011   #262
GsXtUrBo98
GsXtUrBo98's Avatar
I installed my cut off switch last night and today I got my fuel pump rewire kit installed along with my boost a pump wired up too! BIG THANKS TO BRAD ( C3L1CA ) for swinging by and telling me which wires needed to be cut and connected! I also cleaned the car and this is how it sits now.
ID:	11852   Click image for larger version
ID:	11853   Click image for larger version
98 GSX (built)
03 BBY EVO dd
Old 07-02-2011   #263
DSMINMN
Mitsus for days!
DSMINMN's Avatar
Drives: '08 Chrysler 300C
Car looks sick man!
Old 07-02-2011   #264
Car looked super clean and really made me miss my dsm! Glad I could be of some help. Hope you hit your goals with it!
Old 07-03-2011   #265
Lookin sexay.
Old 07-03-2011   #266
Chim55117
Drives: 2007 BMW 335i Coupe
Looking good Chris! When are you off to Shane for tuning? Any more little bugs to get sorted out?
"We are what we repeatedly do. Excellence then is not an act but a habit." — Aristotle
Chim55117 is offline   Reply With Quote
Old 07-03-2011   #267
GsXtUrBo98
GsXtUrBo98's Avatar
Thanks guys! I have some bugs to take care of still. Need to do my head studs, throttle body seals, uicp needs bead rolling, and my exhaust needs finishing up.
Off to see shane on the 14th and bir on the 16th
98 GSX (built)
03 BBY EVO dd
Old 07-03-2011   #268
Good luck man, i hope u get it done in time i want to see u make some good passes up there.
Old 07-03-2011   #269
GsXtUrBo98
GsXtUrBo98's Avatar
I hope so too
98 GSX (built)
03 BBY EVO dd
Old 07-07-2011   #270
GsXtUrBo98
GsXtUrBo98's Avatar
Dropped my car off at primo yesterday for the exhaust and dump tube to be finished up.
98 GSX (built)
03 BBY EVO dd
Old 07-07-2011   #271
GsXtUrBo98
GsXtUrBo98's Avatar
Still have to do the head studs and throttle body seals but everything else is done! Hope I can get my car back from Primo asap
98 GSX (built)
03 BBY EVO dd
Old 07-12-2011   #272
GsXtUrBo98
GsXtUrBo98's Avatar
I replaced the seals in the 1g throttle body and picked up a new gasket today from mitsu and got that on the car. Jesse said my exhaust and dump tube should be done tonight and I will be picking it up tomorrow and doing the headstuds at my house if all works out well... Things that have to be completed by tomorrow night.
Head studs
exhaust welded up
dump tube welded and mounted
uicp welded and mounted
I think that this is it! hope all goes well and I can get everything done for Shane on thursday at 3
98 GSX (built)
03 BBY EVO dd
Old 07-14-2011   #273
GsXtUrBo98
GsXtUrBo98's Avatar
OK so, I brought my car to Shane today and we gave it our best. I am running into ignition issues about 27psi so we had to stop at that mark... With the ignition issues being fixed he said I would have no problem getting over 500awhp on his dyno.
He also recommended running speed density with a AEM 5 bar. My GM MAF is all over the place. My main problem with the spark is that I'm not getting enough volts from my alternator to my battery. But I'm also throwing a alternator CEL. Any how here's the graphs.
ID:	11885   Click image for larger version
98 GSX (built)
03 BBY EVO dd
Old 07-14-2011   #274
Awesome!
Old 07-14-2011   #275
GsXtUrBo98
GsXtUrBo98's Avatar
http://www.youtube.com/watch?v=mncpX5O16Qw&hd=1
98 GSX (built)
03 BBY EVO dd
Old 07-14-2011   #276
blackawdtsi
Drives: 2G DSM
Internal gate? And update your sig .
Old 07-14-2011   #277
Nice numbers!
Wish I would've been able to stick around and watch.
Old 07-14-2011   #278
Chim55117
Nicely done Chris, glad to see things worked out for you. See you around man!
Old 07-14-2011   #279
GsXtUrBo98
GsXtUrBo98's Avatar
Thanks guys!
Tial 44 external
98 GSX (built)
03 BBY EVO dd
Old 07-14-2011   #280
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
good job dude!
