Old 06-10-2004   #1
Emcee gsxtc
Emcee gsxtc's Avatar
It looks like the waterpump is shot. I add coolant/ water and it just leaks right out. On the other side above the transmission its leaking oil. I'm not sure if its also leaking oil by the exhaust manifold or if its just running and dripping from there. I will post the pics and try to explain best I can.
Note: I just replaced head gasket and all the ones above that.
Run your car not your mouth!
Pick Two: FAST CHEAP RELIABLE
Old 06-10-2004   #2
Emcee gsxtc
It doesnt even look like the head is all the way on...
Old 06-10-2004   #3
Emcee gsxtc
sonofabitch...
Old 06-10-2004   #4
WHOA, THAT IS NOT GOOD hmy:
Besides stating the obvious, I would say it's time to take it back apart. Which is also obvious. Hard to really tell anything from the pic of the corner of the head.
Did you use the correct size head bolts/studs?
Old 06-10-2004   #5
PSI2HI
That center exhaust manfiold boltis actually an open hole into an oil gallery. W/o a bolt in there its gonna spew oil everywhere.
Nick
Old 06-10-2004   #6
joem
Drives: 1991 Talon awd auto
Is the head gasket on backwards?
joe
And it is possible.
Old 06-11-2004   #7
joem
Sorry
Old 06-11-2004   #8
520Talon
joe
And it is possible.
Thats the best thing I've heard all day!! :bounce: :toast:
520Talon is offline   Reply With Quote
Old 06-11-2004   #9
joem
:drool: Not when it happens to you. j/k
joe
