Old 10-28-2011   #1
Boomdeeze
Boomdeeze's Avatar
Drives: 97 GSX
LF timing belt tool for 6 bolt
I am going to be switching my cams out and need to borrow/rent the tool. If anyone has the tool, I will buy/rent it from you just let me know. It is the completely threaded rod which is 8mm x 1.25 and however long, not 100% sure but its something like that.
Old 11-05-2011   #2
Boomdeeze
Boomdeeze's Avatar
Drives: 97 GSX
Re: LF timing belt tool for 6 bolt
Does no one have the tool to take the tension off the belt so I can swap out my cams?
Old 11-05-2011   #3
I always make one when I need it. Simply take your long battery hold down bolt, grind off teh ears and pull out your handy tap and die set and double the length of the threads. It's kinda a one-time use cause the threads get chewed up, but it does the job.
