Old 04-11-2012   #1
gsxvince
the dsm mechanic!
Drives: 1991 talon tsi 1ga
1991 eagle talon big project
so i picked up a nonturbo fwd talon shell pretty much perfect body.
swaped a turbo engine, the harness, ecu, exhaust, and gauge cluster into it from a running crap shell and now it isnt running right at all
idk what happened in the process.
i idles very low about 500-700rpms and sounds like its fireing wrong.
it has a cop setup that was working before the swap.
anyone some ideas before i call map??
Old 04-11-2012   #2
93gtpeater
Drives: cbr 1000rr repsol
Re: 1991 eagle talon big project
Check all you wires and connection. Could be a bad ground. You getting enough fuel? Did you change ecus? Only way map can help you is if you bring it to them and have them work on it. Iam sure they would be glad to sell you some stuff. If the car ran fine before the swap and now it doesnt. Means you missed something or you fucked something up.
Old 04-11-2012   #3
gsxvince
the dsm mechanic!
yeah i checked all the wires and its the same ecu
how do i check to see if i have enough fuel??
i would be bringing it to them if i cant figure it out.
Old 04-11-2012   #4
93gtpeater
Fuel pressure gauge. You could have bad gas. do you have a Check engine light? Do you know if you are getting spark on each spark plug? You getting correct voltage to the injectors?
Old 04-11-2012   #5
gsxvince
the dsm mechanic!
ill check spark
actually it most likly is bad gas in the tank
ill have to get a fuel gauge
Old 04-11-2012   #6
It takes a while for gas to go bad, I'm driving around on last year's gas with no problems. E85 is a different story.
Old 04-11-2012   #7
gsxvince
the dsm mechanic!
oh and oil pump is leaking from the top bolt area now too...
Old 04-11-2012   #8
So you did a complete turbo swap into a non-turbo car, you tell us it's not running well without much detail, and want us to diagnose the cause over the internet?
I say swap it all back to the turbo shell and see if it runs better
Old 04-11-2012   #9
gsxvince
the dsm mechanic!
that wouldnt make a difference, i havent gotten into it too much wanted a place to start
Old 04-11-2012   #10
dsmghost
dsmghost's Avatar
Drives: 1gb Talon TSi AWD
Make sure you have strong spark at each cylinder. Check fuel pressure at the rail. Make sure all the harness connectors are connected securely.
Old 04-11-2012   #11
Did you swap fuel pump and fuel pressure regulator? Also, ditch the cop for stock ignition. Simplify things. Did you do the wiring for the fuel pressure solenoid and knock sensor? I found a page the other day with a complete list of what's needed, it will take forever to search for it on my phone though.
Old 04-11-2012   #12
gsxvince
the dsm mechanic!
i didnt do fuel pump or regulator wouldnt the stock ones be the same
and i have a turbo wire harness in
Old 04-11-2012   #13
gsxvince
the dsm mechanic!
its most likly a fuel issue im thinking
Old 04-11-2012   #14
Regulators are different for sure. Nt ones are higher pressure. Could be your problem.
Old 04-11-2012   #15
gsxvince
the dsm mechanic!
sweet ill swith them right away and check it.
Old 04-14-2012   #16
gsxvince
the dsm mechanic!
well the regulator is switched and it helped some but still running bad.
map will be looking at it on 4/19/12
Old 04-14-2012   #17
Did you do the fuel pump yet? n/a ones are smaller/flow less
Old 04-14-2012   #18
gsxvince
the dsm mechanic!
when i did thr swap map never said i needed to switch that but if soo ill get it done
Old 04-15-2012   #19
Everything I have read says they are different. Like I said, just what I have read though.
Old 04-15-2012   #20
blackrosenova400
blackrosenova400's Avatar
Out of curiosity what year turbo ecu did you install, and was it the matching harness that you installed?
20g Mafia
