Old 05-10-2012   #1
Dalton C
Dalton C's Avatar
Drives: currently a kia rio :/
Gas Mileage
So i got this kia rio and it should be getting 25 mpg, 275 a tank, and im getting more like 14-19 mpg. I dont get it, Its only got 50,000 on it, anyone know what may cause this? I drive like im 90 years old so that cant be the problem
Dalton C is offline   Reply With Quote
Old 05-10-2012   #2
Tachyon
Tachyon's Avatar
Drives: Icarus
Re: Gas Mileage
If the MPG is that bad, my first though would be faulty front o2 sensor.
-Sebastian Vettel
Old 05-10-2012   #3
Trogdor
Trogdor's Avatar
Drives: people crazy
Re: Gas Mileage
Its a pretty common problem with kias
Old 05-10-2012   #4
Dalton C
Dalton C's Avatar
Re: Gas Mileage
Well thats easy to get at, what should i look for to know if its bad
Old 05-10-2012   #5
Dalton C
Dalton C's Avatar
Re: Gas Mileage
Heard it could be breaks too, it is a little jumpy from start and shifts funny sometimes
Old 05-10-2012   #6
Re: Gas Mileage
Do a scan and see if any codes come up. Check engine light? O2 is the first bet.
Brakes you mean? A stuck caliper would slow you down.. but youd notice the sound and a really hot wheel, as well as your brakes probably ground down to the metal on the pad..
Old 05-10-2012   #7
Re: Gas Mileage
Do a A/T fluid flush and replace the filter...along with a new front o2 sensor. Take care of all the other regular tune-up and maintenance items too.
Old 05-14-2012   #8
Dalton C
Dalton C's Avatar
Re: Gas Mileage
Got the car lifted up no stuck brakes, air filters good, no check engine light, I'm baffled.
Old 05-14-2012   #9
Tachyon
Tachyon's Avatar
Drives: Icarus
Re: Gas Mileage
What are the AFR's at cruise (NB voltage)? Does the car feel sluggish at WOT?
I had a Kia once that the catalytic converter got clogged and mileage tanked. The only tell tale problem I could find was reduced performance at higher RPM and load.
-Sebastian Vettel
Old 05-14-2012   #10
Dalton C
Dalton C's Avatar
Re: Gas Mileage
It is slow as hell but I always just figured it was the car. I have a obd scanner comin in the mail so i can get some readings soon
Old 05-14-2012   #11
Dalton C
Dalton C's Avatar
Re: Gas Mileage
What do u mean by nb voltage
Old 05-14-2012   #12
Re: Gas Mileage
You can rent scanners at autozone and other auto parts stores, not worth it to buy one when you can check things for free.
Old 05-14-2012   #13
Re: Gas Mileage
I bought one a while back. and have used it very many times, on friends cars, my cars etc. I feel its paid for itself on gas i would have spent going to and from the parts stores to check it each time. plus it was only like 30-40 bucks
Old 05-14-2012   #14
Dalton C
Dalton C's Avatar
Re: Gas Mileage
I found one for 16 bucks uses bluetooth to my phone with a free app
Old 05-14-2012   #15
Re: Gas Mileage
NB = narrow band O2 sensor
Old 05-14-2012   #16
dsmghost
dsmghost's Avatar
Drives: 1gb Talon TSi AWD
Re: Gas Mileage
Clean your throttle body and run an intake cleaner through a vacuum source. Change your spark plugs. Air filter dirty? If your o2s are bad enough to effect fuel economy it would set a code and turn on the check engine light. Make sure your tires are at least 30 psi.
For the funky shifting do like said above, flush the trans fluid and replace filter, if you can drop the pan and replace the filter on a Kia Rio idk.
Old 05-15-2012   #17
Dalton C
Dalton C's Avatar
Re: Gas Mileage
So i talked to a guy today, he said on his the gas light comes on theres still 4 galloms left in the tank lol, so next time i fill up im checkin how much i actually use so bein wrong with this i aint even mad haha. Thanks for the help tho guys, at least this puts me in good numbers
Old 05-16-2012   #18
Re: Gas Mileage
LOL, you weren't actually checking your gas mileage? Go to a pump and fill it all the way up. When it gets close to full, then put the pump on the slowest setting. Reset your trip meter, then do your driving. When empty go back to the same pump and do the same thing. Take the miles on your trip meter and divide by the gallons you just put in, that is your gas mileage.
Old 05-16-2012   #19
Re: Gas Mileage
Really? wow.. lol
Old 05-16-2012   #20
Dalton C
Dalton C's Avatar
Re: Gas Mileage
I have been using the trip meter but i just estimated gas in the tank 11 gallons so i figured i used 10 of it i just gotta check how much gas i use next time i fill up
