Old 05-15-2012   #101
Re: Lucky #13...Back in the saddle....92 rt/tt
Update:
New 6 puck XTD disc is in with southbend pressure plate. Car clutch feels lighter now! I also found real E-85 so time to re-map with my designated co-driver, Ryan, tomorrow. We'll see what it does, probably make a high/low boost cut off at 16psi so I have a "cool" and "die 9b's die" setting.
Old 05-16-2012   #102
Clyne
Clyne's Avatar
Drives: 96 Eclipse GSX
My old ones were definitely on DIE DIE mode. Blue smoke all the time haha... I always gotta gawk when I see a 3S in town now. I miss my VR4.
3000GT VR-4 - Sold Fall '11.
Current ride: 96 Eclipse GSX - FP-T28 etc.
Clyne is offline   Reply With Quote
Old 05-16-2012   #103
Yeah I need valve stem seals, but 155,000 miles on the motor will do that. This winter, assuming everything holds together fine, will be that update.
Old 05-16-2012   #104
bring that die setting so we can see new turbos and 10s!
Old 05-16-2012   #105
Doubt it. We'll see how tweaking goes with Ryan tonight on real E-85. Then dial in the 2-step and NLTS setup and its as good as its going to get by the track date. I may rent a hour of dyno time to just validate a few things prior to the event if the virtual dyno numbers are close to the record. Problem is the car is still very heavy and will be as it will retain creature comforts, over time it will lighten up, but I don't foresee it dropping below 3500lbs. Sub 12.5=happy. Sub 11.99=goal achieved.
Then I'll start to think about cam gears and larger turbo's. Problem is I can't decide if I want to start with a mild upgrade, like 13t's (can get into a low mileage set ready to bolt on for $1000ish) or HT12 wheels with clipped turbines (rebuilt for $900, with bolt-on), or save the $2200+ for DR650's that have been known to put down 500awhp on pump....
Maybe I'll just throw nitrous at it.
Old 05-17-2012   #106
Project took a step sideways last night. With 155,800 miles on the motor, it spun a bearing. We heard a slight clank after a pull to where power was dropped down, thought it may have been the TOB being a little loose as tension on the slave cylinder was weak, and then did another quick pull to check. Well that pull resulted in a smoke screen, hole in the oil pan, and probably the need for a 4-bolt upgrade.
With this amount of miles, I am not disappointed, just a forced upgrade to a 4 bolt motor. Still plan on going to the proving grounds to support John LaCroix's Galant, and hopefully will hit the track with this car end of season.
Plus side is the car was making 368hp@4300rpm and 480tq!
Old 05-17-2012   #107
Ouch that sucks! So much for keeping it low budget. :/ At least your labor is free, still a bummer not to have it running for the summer.
Old 05-17-2012   #108
Evo time?
Old 05-17-2012   #109
I agree. It was in the plan, but not until this winter. That is the problem with a high mileage motor somewhat "prone" to spun bearings already.
Old 05-17-2012   #110
Nice on the power, i want a ride in that.
Evo time?
x2 for race car, or step your game up and get a nice infinity or something!
Old 05-17-2012   #111
Holy Torque. Jeebus! Are you going to build the engine with forged internals now? stock rebuild?
Old 05-17-2012   #112
T.B.A Going to continue with side work, tuning, engine work, mechanical labor, and let the car sit for a few weeks, probably won't have time to pull the motor until AFTER the proving grounds. Then I"ll decide.
If things work out, very good chance it won't be TD04's anymore, unless I do just toss in a stock motor to get it up and running. The cost of a stock motor is so close to a monster build...might as well just spend the 25% more is my current train of thought.
Old 05-17-2012   #113
Yea might as well. That's what I like about having a project AND a daily, you can let the project sit if need be while you're pissed or whatever, then get to it when you have the time/patience/money. Unlike a Daily project which you are forced to fix ASAP.
Old 05-17-2012   #114
Exactly!
I may rip out the wideband and toss it in the truck to see what I can get for MPG out of it though May be worth the few bucks.
Old 05-17-2012   #115
Fuck man, you cannot keep one of these running to save your life!
Sorry dude.
Old 05-17-2012   #116
Sorry dude.
For now I am blaming this on the mileage on the motor, 155,800. Now.... next month, I'll figure out the forced upgrade spin on this minor setback.
Old 05-17-2012   #117
Sorry dude.
ouch.
it ain't no DSM. They love mileage.
Good luck whatever you decide.
Old 05-18-2012   #118
ouch.
Torn between a well balanced 3.0 setup at 50-60% power rating and a 3.5 setup I can utilize at 40% capacity...
Unless I find a smoking deal on a stock one, I"ll just drop in a built short block.
Old 05-18-2012   #119
Can you guys use the 6g75 3.8L's or no. That would make some mad TQ!
Old 05-18-2012   #120
VR38 swap!
