Old 06-09-2012   #81
gsxvince
the dsm mechanic!
Drives: 1991 talon tsi 1ga
Re: 1g 6 bolt 4g63 tsi build
i got my tranny and t case if you need something now
Old 06-10-2012   #82
dsmghost
dsmghost's Avatar
Drives: 1gb Talon TSi AWD
I ordered transfer case input and output seals today. I'm also going to do the vfaq slip yoke leak fix.
Old 06-28-2012   #83
Is this sucka tuned yet? I wanna come check it out one of these days
Old 06-28-2012   #84
dsmghost
dsmghost's Avatar
not quite yet, but getting closer. I pulled the lower timing cover today to fix a oil leak. It was the top bolt of the front case seeping oil, I sealed the threads, torqued it a little tighter. I also fixed the transfer case leak this past week. Just getting the last bugs worked out, Ill be setting up a time at db really soon.
Old 06-29-2012   #85
Nice.
Old 07-19-2012   #86
dsmghost
dsmghost's Avatar
Drove down the street today for its first wash since I got it. Took some pictures afterwards, still waiting to get tuned.
ID:	12703   Click image for larger version
ID:	12704   Click image for larger version
ID:	12706   Click image for larger version
ID:	12707   Click image for larger version
Old 07-19-2012   #87
Nice and clean! Intake your next mod?
Old 07-19-2012   #88
dsmghost
dsmghost's Avatar
Im gonna get it tuned as is, and drive it for the rest of summer/fall. Then over winter I'm thinking Ill upgrade from this 14b, upsize injectors, and switch to speed density.
Old 07-19-2012   #89
dsmghost
dsmghost's Avatar
Just found this picture, it was a couple weeks ago when I put in a new LF output shaft seal and new transfer case seals.
Old 07-22-2012   #90
Love it! Just drive it and have fun. A little tuning to make sure everything is healthy and some miles is all this thing needs!
Where are you located again? I'd love a ride sometime if it ever works out!
Old 07-22-2012   #91
dsmghost
dsmghost's Avatar
Yeah for sure, im off of 62, just north of the airport
Old 07-22-2012   #92
Nice job! It's cool to see that some people can still put shells back on the road. :thumbsandtoesup:
Old 08-14-2012   #93
dsmghost
dsmghost's Avatar
Thanks, I've put a lot of hard work into this. I'm considering selling this if anyone is interested.
http://www.mitsustyle.com/forums/showthread.php?t=31924
Old 08-28-2012   #94
dsmghost
dsmghost's Avatar
Today I installed a rear strut tower brace, cleaned the bottom side of the hood. Took some pictures. I've been driving this to work the past couple days. I've put about 500 miles on it since assembly.
ID:	12780   Click image for larger version
ID:	12781   Click image for larger version
ID:	12783   Click image for larger version
ID:	12784   Click image for larger version
ID:	12786   Click image for larger version
Old 08-29-2012   #95
That makes me miss it a small amount now. I'd still like to get to see it, you should pm me your # again, I lost it when my phone went kaput a few weeks ago.
I always wanted to paint those wheels bronze since they were my backup wheels just to see how it would look.
Old 08-31-2012   #96
dsmghost
dsmghost's Avatar
I was thinking of having them powder coated black, bronze would look nice though, didn't even think of that.
Today I aligned the talon, it was way off, I'll post a picture of the printout soon. Drives way better now. Also, found 1 of the u-joints on the driveshaft has some play. Im going to swap it with my other driveshaft sitting in the garage, it has good u-joints. I also noticed a lot of backlash in the rear diff, and a howling noise around 50mph. Im going to swap driveshafts to see if it improves otherwise I'll be looking for a replacement rear LSD.
Old 09-01-2012   #97
Should get some driveshaft bushings as well, you'd be surprised at how solid it makes everything feel.
Old 09-04-2012   #98
dsmghost
dsmghost's Avatar
Alignment print-off, handles great now, all the eccentric bolts turned like butter.
Old 09-05-2012   #99
dsmghost
dsmghost's Avatar
So I just changed the rear diff oil. The magnetic drain plug had a quite a bit of metal shavings, but definitely not the worst I've seen. The fluid was pretty thin, very dark and didn't smell like gear oil at all. With the fresh 75w90 and some limited slip supplement, I'm hoping my "howling" noise improves or goes away completely. I'm going to keep daily driving it, so far about 700 miles on it since the initial assembly of the car. I'm also hoping to get the cash together so I can bring it down to DB for a tune.
Old 09-05-2012   #100
dsmghost
dsmghost's Avatar
I'm assuming you're talking about the 2 driveshaft carrier bearings, my plan is to replace those with the new u-joints for sure.
