Old 06-15-2012   #161
Re: Mark's 1G Winter Projects
Did you run a raspberry shake for fluid in your tcase?
Old 06-15-2012   #162
I remember splitting the front of my case in half at the shootout, but mine wasn't nearly that bad. You know you're supposed to get out of it when smoke and parts start flying out, don't you?
Old 06-15-2012   #163
Mark Leasure
Mark Leasure's Avatar
All tuned up! I did a roll on in second gear and spun the tires super bad. I tried again in third and the tires spun a little at 7800 RPM! This was on a flat entrance ramp with the QTP’s on it! It has never spun 3rd gear, ever. The spool is a little slower, from what I can tell about 200 RPM. It makes 40 psi by 6200 RPM from a 3rd roll on. I also raised the rev limiter to 9.5K. It’s been awhile since I drove it so it’s hard to tell from my memory if it’s faster. The only thing I could do is to compare a 3rd gear roll on run from last year. It is 0.45 seconds faster from 6K RPM to 8.5K RPM. With 3 psi less boost too. Hopefully the lazier spool will make for a little less of a violent launch off of the line and save the drive train a little. I’m now 100% excited to see if I can beat my personal best MPH and time, right off of the trailer!
Old 06-15-2012   #164
Mark Leasure
It sounded like a shotgun went off in the car, I was scared out of it!
Old 06-25-2012   #165
Mark Leasure
New great passes at MAP PG 2012, maybe I will keep it a 5 speed
I cut high 1.4 60ft on each pass
http://www.youtube.com/watch?v=-Aileo2urTI&hd=1
and
http://www.youtube.com/watch?v=TdCATTzpPEc&hd=1
Old 06-25-2012   #166
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Nice. You gonna keep the stock t-case in there now?
Old 06-25-2012   #167
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
nice runs :drool:
2006 WW IX RS 396/404 - SOLD
Old 06-25-2012   #168
awd-drifter
'2of9'
awd-drifter's Avatar
Drives: Racer Van V6
wow, that thing is moooooooooovin'!
ლ(ಠ益ಠლ)
Old 06-25-2012   #169
God damn, that is awesome. Congrats on getting some solid runs in.
Old 06-27-2012   #170
Mark Leasure
No way! I'm still looking to get an upgraded one made, a couple of companies still do the old school upgrade where they bore out the tail shaft factory gear and e-beam weld a larger tail shaft to it.
Old 06-27-2012   #171
Get the brace and rock the stocker till it breaks!
Old 06-27-2012   #172
Good job Mark!
Old 06-27-2012   #173
Mark Leasure
The shock load on everything else takes a beating when the T-Case blows up. I would rather take it safe, since the car is shifted. Auto's can get away with stock cases.
Old 06-29-2012   #174
Mark Leasure
I don't know what the guys name is, but he put his go pro in my car.
http://www.youtube.com/watch?v=G8B81d60fos&hd=1
www.maperformance.com
Old 06-29-2012   #175
Did your gauges go back in when you hit the brakes? HOly crap.
How fast was that run because the 2g was moving!
ALso I didnt know that you run a 2.3, i need to talk to you when I build a motor.
Nice run.
Old 06-29-2012   #176
Mark Leasure
Nice run.
Yep 2.3L. I was totally asleep at the line, and his car is bat shit crazy fast!
Old 06-29-2012   #177
mondale
Drives: 1g dsm
Nice runs mark! That video shows really how fast Devin's car is, because you were hauling ass in the first place.
8.59 @ 158
mondale is offline   Reply With Quote
Old 06-29-2012   #178
You are such a damn rip! Car just does work nonstop, crazy fast.
Old 07-05-2012   #179
test post.
Old 07-06-2012   #180
Mark Leasure
Time Slip:
