Old 06-19-2012   #1
blageo23
AWD4G64
blageo23's Avatar
What Kind Of Oil Do You Use/ Recommend
Ive always ran mobile one 10w30 (maybe 40 I don't remember) in my eclipse. But last year when my turbo went out the oil that was leaking out of the turbo was like water. Kind of scary. Looking to possibly switch to a new oil.
1998 Spyder AWD
567hp
490tq
Old 06-19-2012   #2
Re: What Kind Of Oil Do You Use/ Recommend
Mobil 1 10W-30 with OEM Mitsu filters in both my IX and X. Hot oil is supposed to flow very easily, this allows it into the incredibly tight tolerances of modern engines. Thicker doesn't mean better, you should always run the appropriate viscosity for the tolerances the engine was built to.
Old 06-19-2012   #3
curt_gendron
curt_gendron's Avatar
I still use Mobil 1 in all my cars. Been doing that and OEM filters for the last 13 years.
Minnesota 3/S
Old 06-19-2012   #4
blageo23
AWD4G64
blageo23's Avatar
Alright. I always use oem filters too. It just freaked me out that it was so thin. Guess I've never really seen super hot oil spewing out the engine.
1998 Spyder AWD
567hp
490tq
Old 06-19-2012   #5
you should always run the appropriate viscosity for the tolerances the engine was built to and the amount of power you are making.
fixed. Mobil1 may not be too bad for stockish cars, no way in hell you would catch me running it in a 600awhp car like yours.
I would run something like Rotella, Brad Penn, Amsoil high zinc, or similar. or one of the oils on FP's recommended oils list.
Old 06-19-2012   #6
Rotella T Synthetic and Purolator filters.
Old 06-19-2012   #7
Castrol syntec and GTX are what I usually use for synthetic vs non synth. Bosch or oem filters usually.
Old 06-19-2012   #8
The amount of power you're making doesn't change the tolerances the engine was built to, how the engine was built does though. If you don't know, follow the manufacturer's or the engine builder's recommendation, simple as that.
Old 06-19-2012   #9
Toy car - I run whatever synthetic oil is on sale (10w-30 usually), and whatever filter is on sale.
Envoy - I run whatever conventional oil is on sale (5w-30 usually), and whatever filter is on sale.
Old 06-19-2012   #10
The funny thing is, in the real-world, your method is probably just as effective as someone who buys the most expensive hyped-up internet fanboi oil out there!
Basically, my reasoning for Mobil 1 is simple: Simplicity (factory fill, I can buy it at Walmart) and price (it's fairly cheap by the 5 quart jug).
Old 06-19-2012   #11
simulatedwood
Drives: 08 Evolution X
Oil? pffffff
My engine is run on Tigers blood and Chuck Norris sweat.
In all seriousness, Kracka is spot on in his analysis, spec the oil based on bearing tolerances not horsepower. What brand of oil is used, is mostly personal preference, each oil brand specs out different additives they use, some additives are better over a short term life others additives last longer over the long haul but are not as effective.. pick your poison.
Old 06-19-2012   #12
95talonracer
Finally Tuned...
95talonracer's Avatar
Drives: Spyder GSX
I would run nothing mut the Amsoil high zinc with an amsoil filter in your car Mike. I ran it in all of my cars with nothing but great outcome. Let me know if you need any or you can probably get it from someone in your area.
Amsoil Dealer
Old 06-19-2012   #13
Also, keep in mind who's recommending what, the pyramid marketing scheme is a very powerful tool
Old 06-19-2012   #14
lol, beaters get whatever is cheapest but usually with a decent filter.
Talon gets dino oil rotella T with a Wix filter. Rotella T dino has lasted a really long time for me with no negatives.
Old 06-19-2012   #15
I agree. There is definately science to it all, and I used to love playing into a lot of that hype and internet info. But in the end I've concluded that I really don't have a clue in the grand scheme of things, so I just make sure to stick with regular change intervals, stick with recommended weights, and leave the science to the manufacturers because they know a million times more than I ever will.
Old 06-19-2012   #16
Look at the tests, Mobil 1 is usually near the top. One thing to think about is the longevity. Do you think amsoil or mobil has more research in to their additive packages? What oil comes stock in most of the super cars? I'll stick with Mobil 1 in my cars. If it is good enough for a Carrera GT/911 turbo, it is good enough for my car. I also agree that regular changes mean WAY more than the oil you use. I use the Napa Gold filters (made by Wix) or OEM.
Old 06-19-2012   #17
http://store.forcedperformance.net/m...otor%20Oil.pdf
Forced Performance oil article.
Old 06-19-2012   #18
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
AMSOIL 10w-40 high zinc and oem mitsu filter
2006 WW IX RS 396/404 - SOLD
Old 06-19-2012   #19
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
Same.
Old 06-20-2012   #20
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
I thought there was a few members on here or remember the same thread a yr or so ago about mobil 1s quality going to shit. A few locals I know for sure blamed mobil one for spinning bearings.
Me personally when the car is running I use rotella w/ wix filter
