Old 07-10-2012   #1
spoolin d dub
spoolin d dub's Avatar
Drives: 1990 eagle talon tsi awd
Chaos! Project phoenix
Been running same setup basically since 08 so i decided to make a few changes. I had bad machine work on the head so I had to change all the valves and seals and the head work had to be redone. At the point I said might as well go balls out lol.
Sold my FP4r and went with FFWD KING KAMS and FFWD Bee-Mads
Cams Specs are level of a GSC3 or Kelford 280 but more duration and just better all around specs period. I have the last of these cams.
I decided to go all out with the block. Setup is is hush hush.
Block is half filled though
Got new header Shearer topmount
Got new turbo. Comp Turbo TBB with new ETT compressor. Got a divided 1.0 a/r T4 6767
And just got this back yesterday. My modified Forrester intake manni sanded down and polished. Plenum is 5 3/4"!
spoolin d dub is offline   Reply With Quote
Old 07-10-2012   #2
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
Re: Chaos! Project phoenix
some pretty toys there
2006 WW IX RS 396/404 - SOLD
Old 07-11-2012   #3
Sounds like fun! Did you do any figuring of the helmholtz resonance when you extended the plenum on the Forrester?
Old 07-11-2012   #4
spoolin d dub
Actually there was a phenolic plenum spacer that Forrester made for the manifold a few years ago. He did all the testing. Think it made like 35whp more at same boost on a 35r with almost no low end loss etc. Mine just had the spacer cnc'd to exact same specs and welded on.
Old 07-13-2012   #5
spoolin d dub
This is how the car is currently sitting.
Old 07-14-2012   #6
diggin it!
Old 07-14-2012   #7
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
I used to have a 91 fwd tsi just like that one, im jealous as fuck. congrats man it looks good!!!
Old 07-15-2012   #8
spoolin d dub
Thanks. I can't wait to see how she is with the new setup. On street tires and no 2step car ran 10.5 135mph on old setup @ 31psi.
Here's Old setup at 38psi. 70mph pull in Mexico. not the best vid but you get the idea.
http://www.youtube.com/watch?v=6rtIgLdhmjw
I got a hookup on that motor in 08. May sound crazy but but I was never really happy with it. So i said fuck it and decided to do a rebuild the exact way i've always wanted to. I drove 135 miles (One Way) a few times a week to sit with the machine shop to ask questions, listen, take in info, and learn to figure out a great street setup. I didn't go with the direction anyone I knew wanted me to. This is not the typical build.
Here is my crank.
Old 07-15-2012   #9
Looks nice!!
Old 07-15-2012   #10
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
you ever sell that car lmk
Old 07-15-2012   #11
Wow, did FFWD do the crank too? How much does it weigh?
Old 07-15-2012   #12
spoolin d dub
No FFWD didn't do the crank. Not sure how much it weighs but it has alot of hours in it. I mean a whole lot!!
Old 07-17-2012   #13
spoolin d dub
Just a pic tease of the block and head. If you are wondering whats on the block that's a neutral balance shaft. Yes... I'm running a balance shaft lol.
driveline parts on standby just waiting for the trans
Devo2ning Race tcase
DSS 3.5" 1000hp drive shaft
Old 07-17-2012   #14
golden763
Drives: 95talon tsi
that car is sick!!!!
Old 07-17-2012   #15
dsmghost
dsmghost's Avatar
Drives: 1gb Talon TSi AWD
Nice!
Old 07-17-2012   #16
Mark Leasure
Mark Leasure's Avatar
“Hush Hush” setups suck balls. Care to elaborate why, some new found tech in the land of 20 year old DSM's? Enough with the hate on my part, just a pet peeve of mine.
Nice crank & turbine, what have people made on that 6767 and what are your goals, with car and power level? Looks good!
www.maperformance.com
Old 07-18-2012   #17
spoolin d dub
Thanks. no 4cl I know of personally has ran this 67mm. but i know of v8's that have had great results switching to other ett comp turbos. Goal is to run 9's on street tires at or near the boost the car ran mid 10's on 31psi. They said turbo flows a lil over 100lbs/min. Once its dyno'd i'll know off wastegate spring where i'm at.
Old 07-18-2012   #18
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
9's on street tires, you crazy!!
Old 07-19-2012   #19
spoolin d dub
Yep 9's on regular street tires.
Old 07-19-2012   #20
Setup looks sick. Agreed that hush hush on a Dsm is dumb. Either way good luck with it, should be sweet once its done.
