Old 07-06-2012   #181
TalonFiero
moonshine power
TalonFiero's Avatar
Drives: 08 Saab 9-7x Aero
Re: Mark's 1G Winter Projects
Originally Posted by Mark Leasure View Post
Time Slip:
You did take a nap on the line!
Old 07-17-2012   #182
Mark Leasure
Mark Leasure's Avatar
Yes Jim, sleeping at the line, my 9.40 was a .68 reaction time. In the final my reaction was 1.4 lol. I have a lot to improve on with pro trees! This is an easy thing to fix.
So what's next with my talon? Well I might as well make the car faster, so I'm going to put it on a diet and set a goal to remove about 150-200lbs! This should make it much faster.
1. First off I'm going to install the light weight STM brakes up front. Un-sprung weight is king!
2. My father in law has a CNC in his garage and is going to scallop and drill rear OEM rotors.
3. Next MAP helped me source some Flex a Lite Lexan molded glass in the rear of the car.
4. I will also put a new fuel cell in the car, going with a 5 gallon model instead of the 16. I typically race with about 8-10 gallons to avoid cavitation on the deceleration, since the tank is only like 10 inches tall.
5. Fuel Lab fixed and upgraded my fuel pump from the 1500hp to the 1800hp version.
6. I have the new upgraded transfer case on the way.
7. I'm going to gut the front doors, remove the carpet, door panels and center console.
8. Over the winter I will take more extreme measures on weight reduction, but still keep it a street capable car!
I’ll take some pics as I go. Should be fun, I will be getting out to the track before the end of the season. Stay tuned!
www.maperformance.com
Old 07-17-2012   #183
Balls out!
Old 07-17-2012   #184
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
Sweet!!
2006 WW IX RS 396/404 - SOLD
Old 07-17-2012   #185
Constant_Project21
Constant_Project21's Avatar
Drives: E36
Awesome, when are you thinking your next passes will be? I'd like to see this thing in action again.
Old 07-17-2012   #186
Tachyon
Tachyon's Avatar
Drives: Icarus
I love your idea of a "street car."
-Sebastian Vettel
Old 07-17-2012   #187
x2.
I'd like to see it and chat with you a bit.
I've heard the door crash bars are pretty heavy and most of the weight on the hatch is the glass not the hatch itself.
Old 07-17-2012   #188
Mark Leasure
It's a very loose interpretation! The 6266 powered Evo is a true street car with all creature comforts. On the other hand the talon has head lights, turn signals, brake lights, and windshield wipers....”Street Car” right? My wife disagrees though!
Old 07-17-2012   #189
tubular engine subframe!
Old 07-19-2012   #190
Mark Leasure
It's a good idea. Looks like a serious winter project, seems like a pain in the ass to design and get right.
Old 08-07-2012   #191
Mark Leasure
Fuel Cell fab:
Old 08-07-2012   #192
noice!
Old 08-07-2012   #193
I like how the pump is mounted right on it. Makes it look simple and clean.
Old 08-07-2012   #194
What's it made out of? Are you going to get it anodized or anything? If it's aluminum I though e98/e85 would eat through it pretty quick?
Old 08-07-2012   #195
Very nice!
Old 08-07-2012   #196
Fucking awesome. Are you gonna do any coating?
Old 08-07-2012   #197
Think you need to anodize Mark.
Old 08-07-2012   #198
Capinoy123
Capinoy123's Avatar
I don't know what the guys name is, but he put his go pro in my car.
http://www.youtube.com/watch?v=G8B81d60fos&hd=1
That guys name is AJ. Or capinoy123.
Old 08-07-2012   #199
Mark Leasure
Thanks for posting the vid AJ!
Old 08-07-2012   #200
Mark Leasure
The plan is to hard anodize the tank. I will show a finished picture next week when it returns. I need to make a change to the pump mount to eliminate the steel PEM studs. I learned that I cannot have it anodized with them installed. I'm going to spin up some aluminum pump mounts on my lathe tomorrow. What’s cool about this project is that going to the aluminum tank alone shaved off 5.2 pounds and changing the way the tank and pump was mounted eliminated another 8.5 pounds. I will also be running 3-5 gallons less fuel when racing, with the old setup I needed to run 8+ gallons so the pump would not cavitate while slowing down at the strip. Bottom line about a total 40 pound total weight savings!
