Old 09-24-2012   #41
awd-drifter
'2of9'
awd-drifter's Avatar
Drives: Racer Van V6
Re: Project Stormtrooper TK1204
fits perfectly nice and that grill is pretty cool, where'd you get it? lmao. Lookin' awesome man.
ლ(ಠ益ಠლ)
Old 09-24-2012   #42
Constant_Project21
Constant_Project21's Avatar
Drives: E36
Sweet shit dude, did VRSF ever get back to you, or did you just acquire some different intercooler piping?
Old 09-24-2012   #43
Just got a refund from them. Not going to wait for it forever. Seems like a one man show.
Old 09-24-2012   #44
Awesome update!
Old 09-25-2012   #45
Giggity fuckin goooooooo!!!!! I must see this on Friday.
Old 09-25-2012   #46
Awesome update!
Old 09-25-2012   #47
T-25 to 50 trim, nice "conversion".
Should do much better than that high 15 next time at the track.
Old 09-25-2012   #48
Hopefully he will find out on saturday at RF!
Old 09-25-2012   #49
haha I was for serious.
That'd be sweet to see it out at the track on Saturday
Old 09-25-2012   #50
I agree, he could tune it on the drive down and then tune WOT once we get close.
Old 09-25-2012   #51
Me and jungy are planning on tuning this tomorrow on the MAF which will probably be a limiting factor along with my injectors and pump. But don't worry, My Omni power 4 bar map sensor is on it's way Thanks brown, never mind on maxing it.
Old 09-25-2012   #52
why would you be maxing out the maf?
Old 09-27-2012   #53
Guess who's on ceddy mods!
<-----This guy!
Install was flawless minus one hiccup. Again, this car has never failed me. I think it truly loves me.
Today, we started at 12ish and the first mod was Vals(burger joint on the cheap).
Then we installed an AEM uego. Next up was ecu, while jungy was under the dash working his soldering magic, I was up front and installed a grimspeed mbc and the 1g CAS.
Later on, jungy put the ecu in after pinning 79 for the reflash adapter.
Read the ecu using ECUFlash and after calling spaz to reconfirm things, got ceddymods flashed on the ecu(SD version with big maps). I'm still running on the MAF until my MAP sensor comes in and we are ready to go SD.
1st try, fuel pump wasn't turning on. We remembered that it's a N/T spyder ecu and it triggers the fuel relay differently. After a little research we tapped into a power wire off the ecu to trigger the pump, flawless.
2nd try, no spark. This is where we were stumped, tried researching and jungy came to the conclusion that he forgot to solder a wire, DOH!
Re soldered our harness and the car ran perfectly.
Set the base timing to 5* and we are ready to swap injectors and fuel! That won't happen til this weekend because we are so busy with school. Unfortunately, I have to work on my birthday from 3-11 so, I will not be going to the track. Always next time.
So until we have time again, I can't wait to mash on this damn peddle and jizzinmahpants! I <3 my DSM!
On that note, sorry for breaking the cruise rules but it'll be done with how installs have been going!
Old 09-27-2012   #54
cmspaz
Walls need hugs too
cmspaz's Avatar
Nice!
Good to hear, glad I could be of service too for the little technical things.
Originally Posted by Trogdor
Old 09-27-2012   #55
Awesome!
Old 09-27-2012   #56
How bout me bitch?
Old 09-27-2012   #57
^who the hell are you?
Old 09-27-2012   #58
I was going to give thanks at the end when it's all said and done....I guess i'll start now.
I'd also like to thank Goodhard, Cornfed2.4, Jungy, Spaz, Ceddy, and my g/f for putting up with my sh*t and being patience.
But especially Goodhard because without him, i would of never been able to flash. +11111!!!11111
Old 09-27-2012   #59
You aren't real friends until you thank each other on the interwebz
Old 09-28-2012   #60
Lmao I just wanna ride in it tomorrow foo
