Old 11-06-2012   #21
Trogdor
Trogdor's Avatar
Drives: people crazy
Re: New Short Block
You guys think I can get away with doing a stock block and new internals? The stock block is $2500 with my discount.
Old 11-06-2012   #22
Re: New Short Block
Can you stick a 4b11 out of another car and tell mitsu to suck it?
Old 11-06-2012   #23
Re: New Short Block
$7500 yeow! Penny pinch man, penny pinch. I saved $$ on my motor build by doing as much myself as I felt comfortable with but it still bit me in the butt in a few spots.
I'm down with the full stage1 setup, good solid motor setup. Clean up the head. Pray none of the valves are bent--I had 6 bent IIRC and it cost me a pretty penny to fix. Send the cams AND valve tappets with to the machine shop as I wasted probably TEN days waiting for stupid new tappets and other misc delays....anyways strap it down with standard ARP headstuds torqued with a good solid torque wrench, don't forget the little oil filter screen that sits on the top of the block.
More spots I saved cash on:
The gasket kit--listed as $310 above idk what's in it so I just ordered peice-by-piece from mitsu (looked back at my notes for this) for $121.85:
intake manifold
headgasket
head-to-waterpump
head-to-tstat housing
turbo coolant hose (mine was a little iffy)
turbo drain-to-block o-ring
4x oil filter housing-to-oil cooler copper washers
This leaves room for cheapo o'reily 10w30 oil for break-in, coolant, a small pile of oil filters and a fresh set of plugs.
That reminds me, I have lomker's HKS spark plugs to use during your break-in if you want....no big boost on them but you can do all the vacuum pulls you want on them and then swap in a set of fresshie gapped plugs once you're ready to tune.
Also I put in a fresh clutch disc in for my HDG6 to give it some extra life for something super cheap like $150.
I'll post up anythign else I can think of.
Also be SMART and don't go more than a few miles once you get it back together without double and maybe triple-checking ALL fluids in the car--engine oil, coolant, trans fluid, xfer case fluid, brake fluid, clutch fluid. I see people turn a blind eye to this shit...if you had a hand in assembly or not be smart and check these!
Old 11-07-2012   #24
Re: New Short Block
That's what a stage 1 "built" engine is...stock block/crank plus aftermarket rods/pistons/bearings.
Old 11-07-2012   #25
Trogdor
Trogdor's Avatar
Re: New Short Block
And this will safely take me up to the mid 400's?
Old 11-07-2012   #26
Re: New Short Block
Mid 400's is doable with a stock shortblock, stage 1 will take you safely to 600.
Old 11-07-2012   #27
Re: New Short Block
4g63 swap it.
Old 11-07-2012   #28
93gtpeater
Drives: cbr 1000rr repsol
Re: New Short Block
Kracka is making alot of power on stock motor on pump gas. stage 1 will be more then enough for what your going to throw at it.
Old 11-07-2012   #29
Re: New Short Block
I still think throwing in a 4b11 out of something else would be dirt and they you put a bow on it and tell mitsu to suck it.
Old 11-07-2012   #30
Re: New Short Block
Hell ya, look at my car I have weakened mine by getting the stock sleeves bored .020" over and it's rocking 600@MAP no problem.
The stage 1 h-beam rods are technically not as strong but for the price difference it's way worth it, they will be plenty strong!
Old 11-07-2012   #31
Re: New Short Block
So you want him to break his lease and attempt to defraud Mitsubishi? Damaged credit and a bill for a longblock + labor at retail...sounds smart.
Old 11-07-2012   #32
Re: New Short Block
Sounds cheap to me.
I didn't see where he mentioned he can't do that, but ok.
Oh my bad, turns out I should know every detail of the lease before I make suggestions.
Being serious, i just think that would be funny and the cheapest way.
Old 11-07-2012   #33
Re: New Short Block
Cheapest way to do what, exactly?
Old 11-07-2012   #34
Re: New Short Block
Put a motor in the car that works.
Old 11-07-2012   #35
Re: New Short Block
Yes, finding a junkyard 4B11T from a 2008-2013 Evo X would probably be his cheapest alternative, but he has expressed no interest in replacing his blown up engine with another stock one.
Old 11-07-2012   #36
Re: New Short Block
Apart from you, they do seem to blow-up pretty easily.
Old 11-07-2012   #37
Re: New Short Block
Not really, but Minnesota does seem to have more than the rest. I'm at 49k miles already, and I have a friend at 55k miles making power in the high-400's with the stock block. From my personal experience, I've driven my X more miles than I drove my IX, and have done less maintenance and repairs on it.
Old 11-07-2012   #38
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
Re: New Short Block
X's blowing up happen a lot less now a days. I think people have learned their lesson and enough info is now out there on what not to do.
I agree, besides self inflicted injuries my car hasn't had any like problems that would happen to a stock car, like suspension issues or any of that crap.
Old 11-07-2012   #39
Re: New Short Block
well i'm only really subjected to them on style.
But apart from this random that troggy has experienced sounds like they are pretty good.
high 400s is damn good too.
Old 11-07-2012   #40
Re: New Short Block
Word. Come down to Texas I'll we attempt to get BBQ again!
