Old 11-16-2012   #21
Re: My New 98 gsx build
How much power have you made on the 16g?
You should be able to make 400 Dynojet on that, so you are looking for 100 extra HP right?
Fuck a map short block. Put in a stock 2.0, cams, keep 16g, get a cheap smim and spray a 100 shot at. Done and done
Old 11-16-2012   #22
^This.
That was my plan for my old car, hence why I have a direct port nitrous kit that happens to be for sale.
Old 11-16-2012   #23
Yiddie
Yiddie's Avatar
Drives: 98GSX
This is why i'm asking questions n such...
I'm not aiming for a certain number, I'd just be happy with anything past 500+ all i'm saying
If I'm gonna put an engine back in, It's gonna be built just so I don't have to worry about it later on.
The Jm Fab drag mani was just a suggestion, I don't know which mani to use yet, why I asked eariler Basically I was trying to figure out which turbo would be best for the fb manifold if I did wanna go that route(which the 5858 ball bearing seems to be my best bet)
I'm gonna do a new fuel system, probably fic 2150s so I'm set with injectors and don't have to worry that later on. Probably get the GSC S2 camshafts also.
Old 11-17-2012   #24
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
What I'd do for 500hp
Stock 6 bolt or 98-99 7 bolt arp hardware on connecting rods
Gasket matched head with Evo beehives with GSC1 cams
L19s with permatorque
Billet 5858 cea
SS o2 housing w/gate provision
FP race mani
1100 FIC hi-z
255 rewired w/ BAP
Evo3 intake
N/T throttle body
I didn't add link, vrsf fmic, ect. Assuming you have that stuff
I think that would get to to 500 at DB.
As far as the manifold, go with the JMF street or Race if you plan on a 6266.
Old 11-17-2012   #25
A built motor would be nice for high compression ratio or for a stroker.
Old 11-20-2012   #26
Yiddie
Yiddie's Avatar
Drives: 98GSX
Definitely be a 2.0 built engine,
More research im doing.. I'm leaning more towards the 6266BB t3 not sure between .63 or .82
And which tubular mani to choose from. The MAP mani kit is real nice.
Old 11-20-2012   #27
I watched a 5858 do 450 at 25psi with 2.5" exhaust, stock tb, im, small cams, small intake pipe.
6266 is a beast though, I vote you do it asap!
Old 11-20-2012   #28
Shearer non-divided T4 manifold, S300sx 91-80 .88 divided T4, QSV, AMS SMIM, AEM Infinity, stock trans.
Old 11-20-2012   #29
^DSM sick build right der
Old 11-20-2012   #30
Shearer divided T6 front facing manifold, S500 88 .85 divided T6, Supra SMIC, nitrous, FTW Purple, RVR intake manifold, AEM Infinity, stock trans, stock 1G BOV.
Old 11-20-2012   #31
Tachyon
Tachyon's Avatar
Drives: Icarus
Can't go wrong with a Billet wheel HX35 with Mitsu hot side for a budget turbo.
Teaser video
http://www.youtube.com/watch?v=h_LkbIKBTu0
That had to have been the slowest 500 hp car I've ever seen.
What are your actual goals with the car? Not having a defined goal often times leads to an over-turbo'd, over-manifolded lag-fest that a good 16g setup would eat for lunch, and be a lot more fun to drive.
It sounds like you're building a street car, but is there a specific 1/4 time or trap speed you are shooting for?
-Sebastian Vettel
Old 11-20-2012   #32
New craze = the coolest bestest thing evar!
holset ftw especially at new turbo prices!
Old 11-21-2012   #33
Yiddie
Yiddie's Avatar
Drives: 98GSX
The car will be street/Drag
I've already done the 16g setup.. I wanna upgrade, I have to put a new engine in, my 7bolt blew up. So I'm gonna put a built 6 bolt in with Wiseco HD pistons 10.5:1 Then a new 2g built head probably use GSC S2 cams, JM Fab intake most likely or a magnus we'll see. I have a new fp mani but probably gonna sell it and pick up a tubular and get the 6266 dbb turbo for it, So I'll be good for around 700hp. I'm assuming with that setup and a new fuel system to support e85 I'll be hitting around 600-700 hp mark. Which by far exceeds what I'll be happy with. I'd be happy with anything past 500+.
With an upgraded intake and that turbo.. I don't see much lag there.
But I'm new to all this.. Never had a car past 500+ hp
Old 11-21-2012   #34
Not much lag with a 62mm turbo on a 2.0? roflcopters.
Old 11-21-2012   #35
Yiddie
Yiddie's Avatar
Drives: 98GSX
Well obviously they'll be some lag.. but not terrible..
Old 11-21-2012   #36
I lol'ed
Old 11-21-2012   #37
I know we live in a world today where on the internet, anything smaller than a 61mm is "small". Forget that bullshit, a 62mm is a fairly large turbo to 99% of us. That turbo is going to shift your power band quite a bit to the right. Add in a SMIM, not sure what you're reading but that will also likely move your power band even more right. Add in larger cams, more right. Add in some tubular manifold instead of the short runner cast one (that EVERYONE is telling you to keep but for some reason you have a hard-on for tubular), and that may move it a tad more right.
By the time you're all said n done, I would predict your setup to hit 30psi around 5k+ RPM. I say that because that's about where my similar setup on my Talon hit 30psi (built 2.0, T3 tubular mani, S362, JMF intake, 272 cams). It's a world of a difference from a 16g as far as lag goes. Which may very well have a negative affect on how "enjoyable" the car is to drive. And this is EXACTLY why all of us are saying to stick with the FP manifold, and go with as small of a turbo that reaches your power goals.
Kerry on here had an FP manifold, and a bolt on SCM61, he out-spooled me and kept up up-top.
Old 11-21-2012   #38
No 62mm+ = we no care.
5858 will do what you want it too. or FP HTA76 has trapped 138.
I vote 16g/50 trim and spray 100 shot.
Old 11-21-2012   #39
Tachyon
Tachyon's Avatar
Drives: Icarus
Well said!
I am a little rusty on my 10+ year old turbo knowledge, but isn't a bolt-on SCM61 known as the original 'Red' ?
-Sebastian Vettel
Old 11-21-2012   #40
Well said!
I dont think so. If my memory serves i think the original red was a 60-1 compressor and a td06 turbine in a 7 or 8cm housing.
