Old 01-16-2013   #1
99gsxjoel
Drives: 1999 GSX
joel's build
It is winter so now it is time to pull the car in the garage and make some more power.
My setup as it sits now is very basic.
Stock block
Stock head
Stock intake.
Evo3 16g
3" Turbo back
Fmic
950fic injectors
255 walbro fuel pump.
Very simple yet very effective. I couldent have been any more happy with how the car performed. 349whp. Ans squeezed out a 11.95.
Now for the plans over the next month or so.
At the end of last year I beleave I either snapped a shift fork, or broke the shift rail to the trans is going to get sent out for a jack's stage 2 rebuild.
The turbo as well was on its way out burning a little oil. So i am going to send it to turbo lab and have them rebuild it, and also put a 20g wheel in it.
I have also accumulated someother thing as well.
Mitsumoto radiator
H11 head studs
Head gasket
Water pump
Timing belt
Egr block off.
Now the only things I can really think of that I need is a set of cams, retainers, and springs.
I am trying to make the car as efficient as possible with what I have. If you have any guess to what my next step is minus building the block please inform me.
So I plan on taking some pics and posting them as it goes. I am sure I will be posting some questions after the engine and everything is removed from the car.
Thanks. Joel
99gsxjoel is offline   Reply With Quote
Old 01-16-2013   #2
Re: joel's build
You going to have TL put that extended tip billet 20g wheel in it?
Old 01-16-2013   #3
Re: joel's build
SMIM!
Old 01-16-2013   #4
93gtpeater
Drives: cbr 1000rr repsol
Re: joel's build
349 whp is that dyno jet numbers or db? Iam guessing dynojet. You have any power goals? come spring time I want more videos of you beating down vettes
Old 01-16-2013   #5
Re: joel's build
^This.
I know a white vette you can run.....
Old 01-16-2013   #6
dsmolition
chemist
dsmolition's Avatar
Drives: RR Evo 8
Re: joel's build
Any reason you are going to run H11 head studs? I don’t see the point on your mod list. Unless you got them for a good deal. Also I would bump up the tranny build to a 2.2 hd so you won’t have to worry about maxng it out in the future.
dsmolition is offline   Reply With Quote
Old 01-17-2013   #7
99gsxjoel
Drives: 1999 GSX
Re: joel's build
That is the plan
that is dyno jet. it made 298 at DB
^This.
like this one??? lol 2009 ls3 vette. http://www.youtube.com/watch?v=Q3Owy_-AMgk
I just wanted no chance in hell to lift the head. I already have them, and got them in a group buy for a good price. I ran 28 lbs all last summer on stock head studs and gasket, and every time I hit the gas i was worried i was going to lift the head.
Also to add to the list I have a stock rear bumper, and side skirts. Excited for the car to go back to stock looking. For the tail lights I have not decided if I want to tint the tails I have now or just get a set of oem.
Old 01-17-2013   #8
Re: joel's build
That's awesome. 298whp and walking C6 Vette's and running 11's. I know of another white c5 vette you can run if you come on the spring cruise.
Old 01-17-2013   #9
99gsxjoel
Drives: 1999 GSX
Re: joel's build
I am always down for some highway runs.
I am very moderate on my HP goals. On DB's dyno uncorrected any where between 350 and 400, and 400 to 450 on a dyno jet. So shooting for 50 to 100 more than it sits now.
I think with the 20G wheel and having cams I hope I can see gains like that.
Old 01-17-2013   #10
Re: joel's build
I would think so. That is a super fun power level. Especially if you start dropping a little bit of weight here and there.
Old 01-17-2013   #11
Re: joel's build
Nice work on that C6.
Old 01-17-2013   #12
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Re: joel's build
Yeah buddy! Glad to see you put a thread up.
Old 01-18-2013   #13
99gsxjoel
Drives: 1999 GSX
Re: joel's build
Just a pic of some of the parts I have. Still need cams, springs, and retainers.
Old 01-29-2013   #14
99gsxjoel
Drives: 1999 GSX
Re: joel's build
Well I just found something that will help my down time.
My original plan was to take out my trans, and send it out to jack's trans to get a stage 2 rebuild. Then I found this.
He is going to send it to me for $1600 shipped to my door with a 4 spider diff. So I personally think I am coming out on top. I am going to sell my trans and good diff as a core.
Transmission:
Built 2G AWD Transmission with TRE 4-Spider Center Differential (TRE Stage 2.5 rebuild by ATX Motorsports, see: http://www.teamrip.com/WHAT%20HAPPEN...20REBUILD.html) - $1600
- Complete Trans Overhaul
- New Gears, Hubs, Bearings and Slider 1-4
- New Syncros
- Double Synchro Second
- Torrington Bearing Upgrade
- 4-Spider Center Differential
Old 01-29-2013   #15
Re: joel's build
So you're getting a TRE trans or what was that bit about ATX whatever?
Old 01-29-2013   #16
99gsxjoel
Drives: 1999 GSX
Re: joel's build
Its a tre rebuild parts assembled by atx is what I understand. It is under the part out section on tuners.
The partout car was a shop car with under 1000 miles on everything. The seller is "v-tec this" and from what I can tell is a reputable seller.
Old 01-29-2013   #17
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Re: joel's build
I believe she's a chick and just buys cars for cheap then flips them for a pretty penny. I'm not sure I would believe the mileage that is actually on the trans but the sooner you get it in and find out it works or doesn't for buyer protection the better.
She does have a very good reputation though so it's possible that the part is in good working condition and is exactly what she says it is.
Old 01-29-2013   #18
Re: joel's build
Yeah she is good shit to work with.
Old 01-29-2013   #19
99gsxjoel
Drives: 1999 GSX
Re: joel's build
this is what she sent me.
The transmission is a TRE Stage 2.5, what TRE now calls a Stage 3 transmission. TRE renamed the Stage 2.5 transmission to a Stage 3 transmission. The transmission was built by ATX Motorsports using TRE's parts
Old 01-29-2013   #20
Re: joel's build
New parts are always nice to look at! I've seen that person list all kinds of stuff on the link forums and never heard anything bad.
You plan on tracking it at all again this summer?
