Old 01-18-2013   #781
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
Re: Project Lex
WTF at that lip lmfao! Are they serious???? This time ebay has failed you. haha
haha omg rofl
2006 WW IX RS 396/404 - SOLD
Old 01-19-2013   #782
Re: Project Lex
Considering you want it to be as quiet as possible.. twin mufflers will be the better option for you.
NSX - S480/Built motor
GSX - 571whp/490wtq
Sienna
Old 01-19-2013   #783
Re: Project Lex
Duals are badass, just ask the good 'ol boys in dem saweet pick'em up trucks!
Seriously though I like the look of duals, but less weight of a single is appealing.
If quiet is what you want, I'd have to agree with mo.
Old 01-22-2013   #784
Re: Project Lex
Rideskinz wrote back and said that's how they package all poly stuff because it will return to normal shape once it reaches a more normal temperature. Well he was right, the lip is sitting in the room and looks normal! So that's good
Went and worked on the motor for a couple hours today. It's taking me awhile since I'm new to this thing. The wire harness is a god aweful mess, but I got it all disconnected and out of the way. Intake and exhaust manifolds are off. Fuel rail off. Valve covers off. Serpentine belt off.
So at this point, I guess I need to figure out how the timing belt works and what all it takes to get that thing off. Seems like I'll have to remove a bunch of shit to get the cover off. Then take the cams out, head bolts off, and that should be it I think.
Once the head is off I plan on calling up Northern Cylinder Head in Andover to see if they'll go ahead and clean it up, put new valve seals, valve springs, and cams in for me (and shim). Nice little tin shed po-dunk feeling shop that's done a lot of head work for me on my DSM in the past!
So that's it for now. here's a couple pics.
ID:	13258   Click image for larger version
ID:	13259   Click image for larger version
Old 01-22-2013   #785
95talonracer
Finally Tuned...
95talonracer's Avatar
Drives: Spyder GSX
Re: Project Lex
Are you going to need to take off your damper? That thing is a completr beoch and is tq'd to 239ft lbs.
Amsoil Dealer
Old 01-22-2013   #786
4seasons69
4seasons69's Avatar
Re: Project Lex
Looks good! If you ever want any help let me know since I'm close! Plus I have access to alldata at work and have just about every tool you'd need if you ever need to borrow anything.
Old 01-22-2013   #787
Re: Project Lex
Electric fan/s in your future?
GSX - 571whp/490wtq
Sienna
Old 01-22-2013   #788
Re: Project Lex
^lol.
What was the leakdown on your old DSM head like?
Old 01-22-2013   #789
Re: Project Lex
I guess I'm assuming I'll have to take the dampener off, but no idea yet.
Thanks for the offer on helping. I'll let ya know if I ever do. I'm kind of a do it myselfer though, just go out there an hour here and an hour there.
Electric fan sure would be nice. The stocker is a monster that I'd love to ditch. However I think I'm going to leave it on for now, and it must work pretty well because I never come close to overheating
Old 01-22-2013   #790
Re: Project Lex
^lol.
Never did a leakdown on my dizzm
Old 01-22-2013   #791
Re: Project Lex
oh ok.
Old 01-22-2013   #792
polishmafia
Smells like cat poop
polishmafia's Avatar
Re: Project Lex
I'm a bit late, but I guess the King of Ricers needs to speak up.
My JDM bumper was shipped to me bent like a pretzel. Leaving it out where its warm allows it to shape itself into its original form.
The picture of it folded up didn't worry me one bit.
Old 01-24-2013   #793
Re: Project Lex
Got the head off. I have it all boxed up along with the new BC springs, and new stem seals. Just waiting for the new cams to arrive and then will be delivering it to the shop to get worked.
Engine looks pretty good. Going to try and clean some of the crud off the tops of the pistons. Cleaned of the middle two with a little brake cleaner and paper towel. Will move onto the other 4 another day.
ID:	13262   Click image for larger version
ID:	13263   Click image for larger version
Old 01-25-2013   #794
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
Re: Project Lex
Mmmm, I want 6 of them! Nice, can't wait to see this back up and running tip top. Good work.
Old 01-25-2013   #795
dsmolition
chemist
dsmolition's Avatar
Drives: RR Evo 8
Re: Project Lex
Got the head off. I have it all boxed up along with the new BC springs, and new stem seals. Just waiting for the new cams to arrive and then will be delivering it to the shop to get worked..
I thought you were a do it yourselfer? Or are you having them do a valve job?
dsmolition is offline   Reply With Quote
Old 01-25-2013   #796
Re: Project Lex
Having them clean it up. Check to see if anything looks old/worn such as guides and what not. If everything looks good, they will be installing new valve stem seals, the new BC springs, and I will have them shim for the new cams.
I've never done much internal head work (valves, seals, springs), and I don't have the tools for it. So I source that kinda stuff out.
Old 01-26-2013   #797
Re: Project Lex
Think I found my mysterious oil leak. Shouldn't there be more than 1 bolt holding the upper oil pan on?
Old 01-26-2013   #798
Re: Project Lex
1 out of 4 isn't bad, looks like its cracked on that front side.
Old 01-27-2013   #799
95talonracer
Finally Tuned...
Drives: Spyder GSX
Re: Project Lex
Wonder how long it has been like that for?
Amsoil Dealer
Old 01-27-2013   #800
Re: Project Lex
Bolts are so over-rated in engines.
