Old 02-11-2013   #121
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
Re: Rebuilding motor, need suggestions
Originally Posted by tmosser View Post
I should be sleeping, but I'm wide awake lol
2006 WW IX RS 396/404 - SOLD
Old 02-16-2013   #122
Took a look today, results are kinda screwy:
Compression: 130 110 86 121
Leakdown: 18% 23% 33% 20%
This is using my cheap harbor freight leak down tester, I usually remove about 10% from the leak down results.
Edit forgot to add: leak down on #3 was *really* hard to tell where it was going. Maybe rings but sound in the valve cover was ever-so-slight.
Old 02-16-2013   #123
tmosser
Drives: 06 Evo IX
What he ^ said. Thanks again scheides, I think I may go with with we talked about just getting it tuned and go from there seeing what happens.
But everyones feedback on my cars results are very welcome as I am no expert.
14 PB GSR
tmosser is offline   Reply With Quote
Old 02-17-2013   #124
Honestly I would get something done soon, it probably won't last very long and when it goes it will probably take out more. I hate waiting for an engine to go, then you have to deal with metal shavings in the system or it may even punch a hole in the block.
Old 02-17-2013   #125
4seasons69
4seasons69's Avatar
I agree with jet. Do something before it let's go. It's so much more hassle to deal with.
Old 02-19-2013   #126
tmosser
Drives: 06 Evo IX
I think im just going to get it on the dyno in the next two weeks to see if it puts any power down. Since it doesnt burn oil and yet still runs and drives like a champ.
14 PB GSR
Old 02-22-2013   #127
tmosser
Drives: 06 Evo IX
machine shops
Anyone know any shops that have a 4g63 torque plate? I cant find anything around here to bore over my block if I decide to build it
14 PB GSR
Old 02-22-2013   #128
Re: machine shops
MAP should or Gosh.
Old 02-22-2013   #129
Merged, you don't need two threads regarding the same topic
Old 02-22-2013   #130
Wagamon's has one too, but I would recommend the other 2 first.
Old 02-22-2013   #131
tmosser
Drives: 06 Evo IX
Yeah map has one but their out like 8 weeks I was hoping on having it done in 2 to 3
14 PB GSR
Old 02-22-2013   #132
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
I am not saying necessarily to use MAP, but good machine work is important. Just make sure to use a quality place.
Good luck.
Old 02-22-2013   #133
tmosser
Drives: 06 Evo IX
Yeah I hear ya. I actually am just going to look for a 2.0 rebuild with standard pistons and have tc automotive in Mankato clean and prep the block etc. I dont need a 2.3 like I wanted so a 2.0 will save me a hassle and some $. Plus I could always just rev the 2.0 higher so If I wsnted I still could do a bigger turbo. Loss of spool but gain of a longer band.
14 PB GSR
Old 02-22-2013   #134
Gosh, right next to DB.
Old 02-22-2013   #135
tmosser
Drives: 06 Evo IX
Well now I see wesico makes std size 2.3l pistons. Hrm...
14 PB GSR
Old 02-22-2013   #136
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
you need a magic 8 ball to decide man
Old 02-22-2013   #137
tmosser
Drives: 06 Evo IX
I do. My gf even said you have the money so just f'ing do it I want to see this thing done! But I still just don'tknow what I wanna do argh!!!!!
14 PB GSR
Old 02-22-2013   #138
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
I'll help you. And this will be the final approach you must decide tonight. Do you want high revving where the turbo kicks in at 5000+ or do you want a stock like feel torque monster?
Old 02-22-2013   #139
tmosser
Drives: 06 Evo IX
Wait since im getting slight blow by on a cyl or two dont I need to bore it out to straighten the cylinders or will new rings seal her up?
14 PB GSR
Old 02-22-2013   #140
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
That is a good question, I'd say a 2.3 would certainly take care of it. Or you can get a new 2.0 block if you desire that setup more but the 2.0's are getting way more expensive every second
