Old 03-31-2013   #461
Mark Leasure
Mark Leasure's Avatar
Re: Mark's 1G Winter Projects
Kind of funny, I have one that is aluminum too, it was the test part. The SS will hold up better, its much thinner and weigh about the same as the test part.
I almost have the ecu ready to go, I have the AEM serial gauge all setup now too. The CAN communication is all configured to read all of the widebands. I can display them on the serial gauge too to check them out.
www.maperformance.com
Old 04-03-2013   #462
Mark Leasure
Started it yesterday, not easy to get all of the 12 tooth stuff figured out. Lots of timing light time required. The 12 tooth wheel makes the car start instantly, and the timing is dead on with no drift like it had before at idle! It started faster than factory did, although my settings need adjustment big time as it starts harder when warm. The tune needs a ton of work, not even close, setup the injectors copied over the fuel map, set the micro-bits/second and it runs super pig rich. Lots of work to be done on the tune, that sucks.
Today I drove it around the block, the tilton clutch is the best thing ever, the engagement is super smooth, like street car semi metalic smooth. The dog box shifts like butter, the noise from the straight cut gears is awesome. 5th gear is quiet, since it’s factory. I cannot wait to get it all tuned up and get it down the track. The 4 wide bands are cool too, the only thing I need to get figured out is the idle solenoid, I have a feeling that the series 2 ecu is limited on a PWM output like the series one had support for. Fail
Also my car is on the main page of DSMTuners, highlighted as the build of the month. Kind of cool!
Old 04-03-2013   #463
That sounds amazing.
Old 04-03-2013   #464
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Awesome work. Crazy we have a guy like you local.
Also I got another t-case you can have use as a back up.
Old 04-03-2013   #465
DSMINMN
Mitsus for days!
DSMINMN's Avatar
Drives: '08 Chrysler 300C
Congrats again on the Build of the month!
Old 04-03-2013   #466
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
Congrats sir!!!
2006 WW IX RS 396/404 - SOLD
Old 04-03-2013   #467
punxnotdead185
Drives: 95 AWD Mirage Coupe with AIDS
Definitely deserves car of the month
punxnotdead185 is offline   Reply With Quote
Old 04-03-2013   #468
4seasons69
4seasons69's Avatar
Awesome work! And congrats on build of the month! I really hope I get to see this thing in person sometime this summer!!!!
Old 04-03-2013   #469
Very cool, the switch from vs1 to vs2 is not easy and will require a complete retune, idk why they have it so you can convert the maps when it doesn't work. Good luck.
Old 04-04-2013   #470
URV8SUX
URV8SUX's Avatar
Congrats on build of the month, did the v1 have a lot of drift in timing in the upper RPM's? Wonder if the v1 would have any drift with the 12 tooth?
None the less car is beautiful and I'm sure the feeling of doing everything yourself is the best part!
Old 04-04-2013   #471
The drift problem is more due to the 1G not having a sensor/trigger wheel on the crank, and just one on the cam, which is effected by belt stretch/slack.
Old 04-22-2013   #472
Mark Leasure
Quick update:
I finished off the dash last week by adding a USB bulkhead connector to make it easy to interface with my laptop.
I'm also going to remove the AVCO rear swaged tube lower control arms. They broke on the dyno last time and I just replaced the broken ones with the same Afco replacements. I would like to dyno the car at some point, so I need to beef up the lower control arm to handle the additional load due to how it is strapped down to the dyno.
old ones:
To insure that this doesn’t happen again I ordered 1.25” diameter, .120 wall, 4130 tubing and weld in inserts for the female threading. I’m also replacing the cheap Afco heim joints with some QA1 Teflon / Kevlar heat treated heim joints to remove any play in the joint. I’ll snap a pic when all is finished up. I have an alignment appointment Friday to dial everything back in.
Old 04-25-2013   #473
Mark Leasure
And done!
Lower control arm is way way stronger now!
Old 04-25-2013   #474
Did you weigh before/after? That must have added at least a few ounces!
Old 04-25-2013   #475
Mark Leasure
Yep a little safety weight added, +3lbs, I weighed them but the scale is not the most accurate thing in the world. No biggie, a lot of weight came out of the car this year, it's very light now!
Old 04-26-2013   #476
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Since you added weight there... Remove it here: http://bulfab.com/bf-mustachebar.html
Make one of those!!
Car looks good! Cant wait to see this thing go down the track!
Originally Posted by shoutbox
Old 04-26-2013   #477
^Where is the front subframe?
Old 05-20-2013   #478
Any progress on this beast? Done any tuning yet with the 4 widebands?
Old 05-21-2013   #479
Mark Leasure
Yeah it’s been a little while since my last update. The car would breakup at 4K RPM and 6K RPM super bad. I couldn’t even get a full pull in at the lowest boost level. The culprit was that I converted to that Kiggley 12 tooth crank trigger wheel and the cam sensor was not adjusted correctly. The signals were overlapping and the cam signal was very very close to a crank signal event. At 4K and 6K the signal would overlap causing ignition errors. I think it was due timing belt harmonics??
I also put back in my wideband in the down pipe, since I don’t fully trust the readings of the individual widebands yet. They are all off from one another by almost a full point of AFR! Also they seem to be a little nonlinear at idle. So to gain confidence in their readings I need to play around by swapping injectors around and seeing if AFR’s track to the change or remain the same and then do the same with the widebands themselves. Lots of BS to prove it out.
I also just added a 2G VSS sending unit, so I can control my 2-step on launch vs. gear to gear shifting. Both John and I have seen lazy recovery times when the 2step kicked in between our shifts at the track.
And to wrap it up I’m planning on bringing the car to BIR this weekend for its maiden voyage down the track! I'm going to be forced to enter it in King Street due to it being too light for Unlimited Street. Lots of changes this year, I'm crossing my fingers that don't have any major bugs to work out. I just want a good clean pass deep in the 9's or maybe even 8's who knows!
Old 05-21-2013   #480
Good luck with it all, interesting to hear about the timing error's at 4/6k.
