Old 04-08-2013   #121
Re: joel's build
This cool a weather you shouldn't have any issues, I know a guy selling a dual water temp/oil psi gauge.....
Old 04-08-2013   #122
93gtpeater
Drives: cbr 1000rr repsol
Re: joel's build
I have a computer that should plug into your car that lets me look at your sensors and will tell me what your temp really is. Its obd2. I use it check engine code and air bag codes. It reads every engine sensor.
Old 04-08-2013   #123
Re: joel's build
What FMIC are you running? Mine always ran hot. I ran around a 75/25 water to coolant mix with water wetter to try and help keep temps low. I switched to a less dense (ETS) FMIC which also helped.
Old 04-08-2013   #124
4seasons69
4seasons69's Avatar
Re: joel's build
I also have a scan tool that should work we could plug in and see what's going on
Old 04-09-2013   #125
99gsxjoel
Drives: 1999 GSX
Re: joel's build
I have a punishment racing fmic. It's not a very thick core.
The weather never played a big part in it. Even in the winter. It has done it forever. it really sucks on the road coarse I have to lift and coast because it gets really warm when beating the shit out of it.
4seasons69, let me know when you could hook it up. My cel is on but I have a feeling it's because I deleted all the egr sensors.
99gsxjoel is offline   Reply With Quote
Old 04-09-2013   #126
Re: joel's build
Are you just tuned on the stock 99 ecu? If so and you have a laptop I'd pick up a tactrix cable so you can log and look at stuff. You can usually find them for sale used on evom or if you're cheap like me you can search nationally through craigslist and hopefully find a good deal from an honest guy who will ship.
Either way nice job on getting it going, hopefully makes some good numbers!
Old 04-09-2013   #127
Re: joel's build
I have a Tactrix 2.0 floating around somewhere. I think Pat still has it.
Old 04-09-2013   #128
4seasons69
4seasons69's Avatar
Re: joel's build
I should be up there on Thursday evening to work on my car so we can on Thursday. My number is 651-983-1230 text me Thursday and remind me to bring it home from work with me.
Old 04-09-2013   #129
99gsxjoel
Drives: 1999 GSX
Re: joel's build
I am going to look into the tractrix cable that would be really nice to be able to
do.
Also ill look like Brian Spilner.
Old 04-21-2013   #130
99gsxjoel
Drives: 1999 GSX
Re: joel's build
Well turbo will be here sometime this week. I am excited to bolt it on and see what Shane can do with it on Monday.
Extended tip billet 20g wheel
tdo6h4 turbine with a machined hot side.
Hx 35 W/G
It should be able to pack some heat.
Old 04-21-2013   #131
99gsxjoel
Drives: 1999 GSX
Re: joel's build
Old 04-21-2013   #132
Re: joel's build
Nice, monday as in tomorrow?
Text me with some updates!
Old 04-21-2013   #133
93gtpeater
Re: joel's build
4seasons is getting his car tuned tomorrow. What you hoping to make?
Old 04-21-2013   #134
99gsxjoel
Drives: 1999 GSX
Re: joel's build
No sorry Monday the 29th.
On DB's dyno I am hoping 370-400ish...
To be honest I have no clue what it is going to make. I have not seen any numbers out of this kind of turbo. Ill be happy with anything over 350.
Old 04-27-2013   #135
99gsxjoel
Drives: 1999 GSX
Re: joel's build
Well turbo is installed and ready to go messed with the boost controller a little to see how it responded. I backed it way out thinking it would creep like crazy and it only made 10lbs. Turned it in a few turns an am making 17.
The boost seems to come on very gradually. I am running a very rich 10.5 afr so all seems well. Excited to strap it on the rollers and start cranking up the boost.
Old 04-27-2013   #136
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
Re: joel's build
NIIIIICCCCCEEEE!!!!
2006 WW IX RS 396/404 - SOLD
Old 04-29-2013   #137
99gsxjoel
Drives: 1999 GSX
Re: joel's build
No good today on the dyno. Couldn't make any more then 22lbs of boost on the dyno and was spooling as bas bad as a 6262. Waste gate was opening by itself even with tue wastegate unplugged.
Anyone have a torch? We could have a dsm bonfire!!!
I have two hx wastegates that I am doing to try. Hope it will work.
Old 04-29-2013   #138
Re: joel's build
Hole in the wastegate actuator rubber? That sucks man, hope you get the issue resolved. How much power did it make on 22psi?
Old 04-29-2013   #139
Re: joel's build
That sucks Joel, hopefully it's an easy fix!
Old 04-29-2013   #140
99gsxjoel
Drives: 1999 GSX
Re: joel's build
299hp.
I have a holset wastegate I am going to use. I am going to drop the car back off at DB and just have them fab up a shaft and bracket. I am so tired of working on it.
