Old 04-15-2013   #121
Re: 2007 Lotus Exige S
http://www.ebay.com/itm/12V-DC-CAR-A...-/220798190787
Old 04-15-2013   #122
If only I had a cigarette lighter power source in the car...
Old 04-15-2013   #123
This car is soo badass, it's nutty how comfy it is.
I want one with a bigger blower on E85, it would be a 10 sec car and have insane handling.
Old 04-16-2013   #124
I had the dash apart to install gauges in the center vents, and I remembered the SRS dash light was bothering me, so I pulled out that pin from the dash harness, no more airbag light! (next to battery)
But here is the real reason I took apart the dash, to install an oil temp gauge I got from Nate (thanks again!). The center part is exactly 52mm so gauges fit perfectly without any cutting.
Now I have to decide if I want white or black. I originally decided on black, but I think in the car the white with silver bezel looks better.
Old 04-16-2013   #125
White with black bezel? Looking good though!
Old 04-16-2013   #126
white gauge, matchy-matchy.
Old 04-17-2013   #127
4seasons69
4seasons69's Avatar
You could always wire one in
I like the white gauge. It just seems more natural with the other gauges being white
Old 04-17-2013   #128
White, i love that old school white face look.
Old 04-28-2013   #129
Vanilla face oil temp gauge installed, works nice.
Got the car weighed, 1900 lbs with the big battery and harnesses/bar installed. Race weight will probably be in the 1860 range if I take off the roof and have the small battery.
I also got some stainless steel caliper pistons, the heat transfer on these is about 5% of the stock aluminum pistons, which equals lower brake fluid temps and fewer changes. They are also vented.
New pistons:
Installed:
Old ones:
Brakes were really spongy after that so I bled the entire clutch/brake system with super blue. Excited to see how it drives tomorrow, hopefully I got all the air out.
Old 04-28-2013   #130
LingLing
AznKraut
LingLing's Avatar
1900 lbs is wicked light! I can't even imagine how well this thing turns and brakes.
Out of curiosity, what kind of pads are you going to replace them with?
Old 04-28-2013   #131
Still using the Pagid RS14 the car came with, they have a lot of life left so I probably won't change them until next year.
Old 04-28-2013   #132
Very nice.
Old 04-29-2013   #133
:drool:
Old 04-29-2013   #134
Awesome. I've never heard of non-oem brake pistons, but your explanation makes sense. Very cool!
Old 04-29-2013   #135
That is awesome! Can't wait to see it on a course sometime. I have always loved those cars.
Old 04-29-2013   #136
Thanks everyone for the positive comments, I'm excited to see how I can do with a fully prepped car, the only thing left is driver mod which I hope to improve a little this year.
Yea, Doug Rippie (in Minneapolis) also makes SS caliper pistons for vettes, I have read many reviews that say you can use the cheap ATE fluid with these over the Castrol SRF so it saves money in the long run for cars that see the track a lot. Two less fluid changes and you break even basically.
Old 05-01-2013   #137
New Bosch EV-14 525cc injectors installed with adapter harnesses:
Also doing a 3" maf and CAI:
When I was bleeding the clutch I noticed the slave cylinder moved a bit and I discovered it was only being held in with 1 of the 2 bolts. I thought the previous owner broke the head off of one and said screw it, but it was completely missing. Found a matching one in my box of bolts, glad I caught that.
Car is all buttoned up and ready to drive down to KC friday for a dyno tune. Will post results after this weekend.
Old 05-01-2013   #138
EFF YEAH!!
Old 05-01-2013   #139
rose0529
Who has my man-card?
rose0529's Avatar
Drives: a red car
Very nice. What are you expecting for it to put down power wise? What kind of dyno?
I really want a ride in this somehow! Maybe this summer when we are down in Iowa?
Old 05-01-2013   #140
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
Looking good mang, can't wait to see this thing in action.
Tags
carbon fibre errrthang, jdm wiper
