Old 04-27-2013   #61
93gtpeater
Drives: cbr 1000rr repsol
Re: Chaos! Project phoenix
Hope I can see this in person come June. Its nice to see a well built 1g. Will this car be at the half mile races?
Old 04-27-2013   #62
spoolin d dub
spoolin d dub's Avatar
Drives: 1990 eagle talon tsi awd
Yes i'll be there. I'm with Devo2ning in the vendor 1/2 mile shootout.
Like my Crew FB page
https://www.facebook.com/BeyondBoostCrew
spoolin d dub is offline   Reply With Quote
Old 05-02-2013   #63
spoolin d dub
Swapped out the 2 blue hoses. Should be getting the car by Sunday for motor break in!!!
Old 05-07-2013   #64
spoolin d dub
A lil 2step setup teaser . Builds to 10psi and Boost is on wastegate spring (14psi).
https://www.facebook.com/photo.php?v...type=2&theater
When you have time feel free to go thru Devo2nings FB page and if you like what you see please comment and like their page.
Old 05-10-2013   #65
spoolin d dub
Old 05-29-2013   #66
spoolin d dub
A lil more tuning and she'll be ready for 1/2 mile event.
Old 05-30-2013   #67
spoolin d dub
Old 05-30-2013   #68
Nice car.
Old 05-30-2013   #69
Car looks good!
Old 05-30-2013   #70
93gtpeater
Wanna race a 600? Haha. Car looks nice. Hopefully I can check it out this weekend
Old 05-30-2013   #71
spoolin d dub
Thanks everyone. Its almost that time and I'm so damn pumped lol. I wanted to get it painted but after I thought about it I changed my mind. This isn't exactly the kind of event you want to run with a fresh paint job lol
Old 05-31-2013   #72
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
dats hawt
2006 WW IX RS 396/404 - SOLD
Old 05-31-2013   #73
Mark Leasure
Mark Leasure's Avatar
Is the car all tuned up and ready to go? Good luck.
www.maperformance.com
Old 06-01-2013   #74
spoolin d dub
car was tuned at 29psi on just a couple street pulls for safe afr's. Im happy at results looking at the amount time of tuning. I know it would have hit 160+ on 2nd pass but throttle cable bracket broke and that was it for me..
Old 07-20-2013   #75
spoolin d dub
We finally got to the dyno today. Everyone been waiting to see what this lil turbo can do lol. Reichen and the shop were asked what did I think the car was going to put down. They said 500ish. I never told anyone but in my mind I figured 600ish and I stood firm on that lol. It wasn't the best day to hit the rollers since temps in dyno showed 97* but oh well. 1st pull tach didn't give good signal and numbers were off showing 695whp and 900ft/lbs lol. The Afr were at 11.1 but someone at a meet/car show i went to turned up my boost to 33psi (it was at 29psi). the tune was conservative so it didnt hurt the motor but we noticed a little knock so mike pulled 1* of timing. 2nd pull afr leaned out to 11.7, 12* peak timing @ 33psi car made 693whp 527ft/lbs but then oil pump took a shit . We're pretty sure the engine noise logged was from oil pump going bad. With a little more tuning I'm hoping for around 730-750ish at 33psi then we turn boost up to 40-42psi . For the record this is a dynojet. i'll be back to update once we get back on the rollers.
http://www.youtube.com/watch?v=Z50mO...ature=youtu.be
Old 07-20-2013   #76
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
Mother f'ers, glad it didnt blow up your car. Making some awesome numbers though
Old 07-21-2013   #77
spoolin d dub
thanks.
Right at the end of pull a little cloud of smoke appeared. Fan blew oil onto downpipe. It may not even be the oil pump. Oil Pressure didn't drop but it was leaking a very tiny trail of oil. I had that issue before when the 10an aluminum fitting to the oil cooler cracked. I just can't find a steel one. But it is one of the two issues and we just didn't want to chance it. It wasn't worth it.
Old 07-29-2013   #78
spoolin d dub
Well i was incorrect about the dyno pull. It was to 10,000rpm. The shop found the oil leak and it wasn't the oil pump. The car vibrated the fittings to the oil cooler loose. They modded the fittings with wires so they wont come loose again. I went out and did some pulls immediately after that and a saw a oil leak again. This shit is crazy. The leak was now coming from the oil pressure sending unit. they go to try to tighten in in and it falls off and hits the ground lol. The brass fitting broke in the middle of the threads with the other half was still in the block!!!! that is now fixed. Im getting phantom knock in the logs. I know its not the motor so once I find what is causing it i'll hit the rollers again.
Old 07-29-2013   #79
Race car problems.
Old 07-29-2013   #80
spoolin d dub
Race car problems.
Yeah lol. the real issue is the car is setup to drive on the street. It actually drives much better then the average dsm. But its so damn loud and vibrates so much it's almost not worth driving on the street. And the way it revs can't help. revs like a damn motorcycle.
