Old 05-15-2013   #861
Re: Project Lex
http://www.youtube.com/watch?v=Aq8TWS5-GRU&hd=1
Old 05-15-2013   #862
Re: Project Lex
sweeT!
Old 05-15-2013   #863
4seasons69
4seasons69's Avatar
Re: Project Lex
nice!
Old 05-15-2013   #864
Re: Project Lex
woooo!
Old 05-15-2013   #865
Re: Project Lex
It didn't start on fire, WIN!
Old 05-16-2013   #866
Re: Project Lex
It's alive!!
Old 05-16-2013   #867
Re: Project Lex
Broke down two houses away?! :P
NSX - S480/Built motor
GSX - 571whp/490wtq
Sienna
Old 07-14-2013   #868
Re: Project Lex
Wife and I took a test drive around our block. All 6 gears and Reverse work. Drove and shifted smooth as butter.
http://www.youtube.com/watch?v=trrgh...pJ8af-tRd1gBwQ
http://www.youtube.com/watch?v=trrghQtAkzg&hd=1
Old 07-15-2013   #869
Re: Project Lex
Looks good, when you turning up the boost?
Old 07-15-2013   #870
Re: Project Lex
Nice job getting it all back together!
Old 07-15-2013   #871
Re: Project Lex
peemp.
Old 07-15-2013   #872
Re: Project Lex
Car so far is still running OK. I think I have some sort of fuel issue though because everyday when I start it, the fuel pressure is different.
Anyhow with it mostly running, I figured I'd give this new buffer and goop a try. First time ever attempting to do this on my own, and figured this is a good test subject since I'm pretty sure it needs new paint, so if I do any damage no harm no foul.
So far I've done: NoRinse wash, clay bar, NoRinse wash, M105 w/ Orange pad, water/isopro wipe down. Tomorrow will be M205, water/isopro wipe, then some Zaino Z5. Car already looks way better, but still not as good as I'd hope. Pretty sure new paint is the only end all cure.
Old 07-15-2013   #873
19TsiAwd90
2stepadepaaadepaaadep
19TsiAwd90's Avatar
Drives: myself crazy
Re: Project Lex
Shiny..
Originally Posted by 311evo
Old 07-15-2013   #874
Re: Project Lex
Nice, I need to get some of those lights.
Did you do a dawn wash at the start?
Old 07-15-2013   #875
Re: Project Lex
No dawn wash. Dan told me my order was good so far. I started with a NoRinse wash. Then used NoRinse for claybar lube, followed by NoRinse wash. Then M105. Then water/isopropyl wash (which could be substituted for dawn wash).
Old 07-15-2013   #876
Tachyon
Tachyon's Avatar
Drives: Icarus
Re: Project Lex
Did you get your partial RPM sync issues figured out?
-Sebastian Vettel
Old 07-16-2013   #877
Re: Project Lex
I didn't get it 100% fixed, however I redid some of my grounding to be setup more like this:
http://www.msextra.com/doc/general/grounding.html
That seemed to help a bit. So I think what I'm going to do is add some better grounding to the car in general. I bought a 25' spool of 4awg wire from Fleet Farm so I'll just be creating some new ground, replacing the old stock cracked stuff. Hopefully that will help more.
Old 07-16-2013   #878
Re: Project Lex
Nice find on teh grounding cable.
Old 07-16-2013   #879
Re: Project Lex
So I completed my first ever full on exterior detail I've ever done. I'm pretty much a perfect example of an exterior detailing newb. And I seriouslly mean newb, like wash my cars with dish soap, stack shit on top of my cars, never seen a claybar in my life. That all changed a month ago, thanks to Aaron's detail day with Randy and Dan of Northstar Detail. So I picked up some new stuff from then, and this week decided to give it a go. Here's basically what I did.
1) NoRinse wash with MF wash mitts, and dried with MF towel.
2) Zaino Clay Bar using NoRinse as lube.
3) NoRinse wash and dry again.
4) Using Griots buffer and Orange pad, applied Meguiars M105 to entire car.
5) Wiped off with MF towel.
6) Spray/wipe car down with 50/50 water and isopropyl alchol mix and MF towel.
7) Using Griots buffer and White pad, applied Meguiars M205 to entire car.
8) Wiped off with MF towel.
9) Spray/wipe car down with 50/50 water and isopropyl alchol mix and MF towel.
10) Applied light coat of Zaino Z5 sealer using MF applicator.
11) Wiped off with MF towel.
12) Final wipe down using Zaino Z6 detail spray and MF towel.
Here's some pics of the results. Pretty much the best looking job I've ever done. Don't think Teh Bean has ever looked this good since I've owned it. It took me about 3 days, 2hrs per day, so 6hrs total. I learned a lot doing it, so I think next time I could probably do a better job, and do it faster. Key take away, if my newb ass can do it, anyone can do it!
Note: in the 2nd pic, that big white chip in the middle of my hood, that's not actually a chip, that's the mufukin reflection of the moon!!!
ID:	13818   Click image for larger version
ID:	13819   Click image for larger version
ID:	13821   Click image for larger version
ID:	13822   Click image for larger version
ID:	13824   Click image for larger version
ID:	13825   Click image for larger version
Name:	Z6 Applied_1.jpg
Old 07-16-2013   #880
DSMINMN
Mitsus for days!
DSMINMN's Avatar
Drives: '08 Chrysler 300C
Re: Project Lex
It looks damn nice to me. If only I had a nice car to clean up like that, then drive! lol
Good job.
