05-15-2013
#181
Re: 1g 6 bolt 4g63 tsi build
You should of bought my badass radiator and fan setup!!!
28psi with HKS 272s. I'd expect nothing less that 400whp, but to be honest even a solid 370-380.
Get some cams, they will make or break a car.
05-15-2013
#182
I just skimmed through your thread. are you still on a stock exhaust manifold?? if so a cast fp would probably help some too
05-16-2013
#183
Drives: 1gb Talon TSi AWD
I had my eye on your fans, but I saw that you didn't want to split them from the radiator.
I was hoping for 400, I should have taken your fp manifold with the turbo. Ill plan on picking up some cams.
I have Carl's old 2g exhaust manifold, I'm 95% it's not ported at all.
05-18-2013
#184
I got down to the last 5.8 gallons of the E76 I was tuned on earlier this week. I just filled the tank with 10.1 gallons from Holiday on hwy 100 and minnetonka blvd. When I got home, I used the tester I bought from DB it shows E80. So with the mix it may have been pretty close to E85 at that Holiday.
05-18-2013
#185
Good to know! That will be the main station I use when my car is up and running again since it's the closest station to my work with e85
05-18-2013
#186
Good to know! Thanks will be the main station I use when my car is up and running again since it's the closest station to my work with e85
Where do you work? I work at Firestone on hwy 7. Is it youngsteds?
05-18-2013
#187
Nice! And yeah I work at youngstedts.
05-19-2013
#188
Yeah my Mac guy told me there is someone who works at youngstedts with a talon too.
05-19-2013
#189
Got Boost o_O'' m
Did you say you are right of 62 by the airport? Hmm we might not live to far apart. Im over by taft park bloomington exit...I thought i might ove seen your talon driving the other day but i dont remember. I know there is a red 1G that drives up and down ceder usually after 8 during the week.
05-19-2013
#190
Yup that's me. Same mac guy lol
05-19-2013
#191
Woot! I'm glad to see this car putting down some solid numbers again! Enjoy it!
05-22-2013
#192
Yeah, swing by or hit me up if you need a hand or anything. I'd like to see your car sometime.
Haha yeah he's pretty cool. So do you have to deal with Scott as your Snap-On guy?
I definitely enjoy it (most of the time)
05-23-2013
#193
Nope. Our Snap-On guy is Gary couch. He's good shit
07-12-2013
#194
Ok so I'm having issues with the evo3 conversion/welded diff transmission. Mainly due to driving with a dragging clutch for the past 10 months. So I picked up a backup trans, a new 2600 pressure plate, new release fork/pivot ball, new oem TOB, and a new 6 puck sprung disc. Also picked up a fidanza flywheel and put a new friction surface on it.
I'm going to swap in the new clutch and backup trans then repair/upgrade my current transmission.
07-12-2013
#195
Damn. Nice.
08-02-2013
#196
OK I was putting off changing out the clutch and transmission. Ive been daily driving with the 2nd gear pop-out and grinding 3rd gear. I drove to ham lake to drop off a Saturn cylinder head (other project in my garage), when I was arriving to my destination, the trans got stuck in 4th gear. Any other gear but 4th it would stall immediately.
Since at my house waiting for me was a fidanza flywheel, new pressure plate, new disc, new tob, new release fork, AND a back up trans/tcase, I said screw it and took off in 4th gear for the 40 mile trip back home at 3:30 in the afternoon, just as traffic was picking up in 4th gear only.
Last night after work I pulled the trans. This morning I changed the clutch and reinstalled the trans. With the lightweight flywheel, six puck disc, and without a welded diff/EvoIII parts it is definitely different to drive. Still got to break it in though. Now I'll have to start setting aside money to fix my main transmission.
08-02-2013
#197
Drives: 95 Talon TSI
I bet that was fun..Looks good. I love the way a new clutch disc looks.
BW8776, e-85
08-03-2013
#198
Haha that's some fun drivin there!
08-03-2013
#199
Yeah major clutch slippage required to take off in 4th gear, here are some pics of the flywheel, 2600 PP, ACT street disc after 1 year and only about 16k miles, and many launches, no lift to shifts etc.
08-03-2013
#200
I also put on some new rubber, I went with the Bridgestone Potenza RE970AS. 225/45/17. Although I will most likely be putting on some Bridgestone Blizzaks come snow time, I wanted to stick with an all season tire for daily driving. Huge improvement from the Falken ZE912s that I had before.
| Thread Tools |
| Display Modes |
Linear Mode
