Old 07-14-2013   #1
blesi660r
blesi660r's Avatar
valve spring Q
I am currently doing a build for my new talon and starting with the head
my Q is : I am installing a set of delta 272 regrinds, I have the head fully disassemble for decking and am wondering if I should up grade the valve springs while its apart, im thinking yes but im not positive. Lil help lol
Just couldn't stay away.
Old 07-14-2013   #2
4seasons69
4seasons69's Avatar
Re: valve spring Q
What are your goals for the car? How much power do you want to make? How high do you want to rev? As far as I know you need to upgrade with 272s but in my opinion if you can afford it since you have it apart I would just do it. I'd up grade the valves and the springs and retainers.
Old 07-14-2013   #3
blesi660r
blesi660r's Avatar
Re: valve spring Q
Im shooting for 450 on e85, stock block, mild head build, I will look into the cost of valves but might have to just stick with upgraded springs,
Old 07-15-2013   #4
4seasons69
4seasons69's Avatar
Re: valve spring Q
A set of valves is like 200 to 400. But that sounds like a solid plan
Old 07-15-2013   #5
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Re: valve spring Q
What deltas are you going with. There are a ton of 272 options. You can get away with stock valves but you'll 95% of the time need to upgrade your springs. I Think evo springs and retainers should suffice unless they are high lift 272s
Old 07-15-2013   #6
blesi660r
blesi660r's Avatar
Re: valve spring Q
To be honest im not sure which really sucks, they came with the car and they are regrinds... I have some of the specs on them at home like lobe base diameter and hight and all the calculations.
Old 07-15-2013   #7
blesi660r
blesi660r's Avatar
Re: valve spring Q
Ok I found my specs that I was able to get by measuring the cam lobe
intake and exhaust.
cam lift- .221
net lift- .375/9.525 mm
exhaust is only a few thousandths different from the intake
I was looking at maybe the BC springs and titanium retainers.
valves are not in the buget as of right now ,but I might be able to get a set if I hold off on assembly for a month or two...
Old 07-15-2013   #8
Re: valve spring Q
OEM valves and done basic beehive springs that use stock retainers as an upgrade. Get some Evo valves if you must, but save going with oversized valves for when you need to repair damage. It's a DSM,keep it simple, keep the budget nice and goals realistic.
Old 07-15-2013   #9
Re: valve spring Q
That doesn't seem like it'd be that aggressive of a cam. However there is no black and white answer to whether or not you need or don't need to upgrade springs. Just have to measure out the risk and decide for yourself if it's worth it or not.
So just think through it. These cams, while not overly aggressive, are still more aggressive than factory, so they're going to be a little harder on the factory springs. They can probably take it, but how many miles are on these springs, how many of those miles are with the more aggressive cams? If this was a head with 50k miles on it, I'd probably just keep the stockers in and not rev it to the moon. However if you're talking a head with 100k+ miles, 20k of those are with the more aggressive cams, well then you're risk of inducing some sort of failure is going to start increasing.
From what I gather, you're on a tight budget. Beehives are great, but for your goals and what seems to be a tight budget, I'd just go with a single spring upgrade like Crowers. They are very affordable and should perform well enough for a mild cam setup like you have. That is probably what I'd personally do if I were in your shoes.
Or just stick with the stockers, but understand there's some risk involved, especially if the springs are in unknown condition/high milage. If you're willing to take that risk in an effort to conserve some money, that's your call. You may end up being completely fine, or you may end up floating a valve.
Old 07-15-2013   #10
Re: valve spring Q
^Very good advice.
If it were me I'd let it buck if the valve springs didn't have a ton of miles on them. If they did, I'd reaplace them with something cheap but will get the job done. No need to go crazy for your goals.
I rocked the dks regrind 272s on stock valve springs for a while making 450ish + on DB's dyno for what its worth without any problems.
Old 07-15-2013   #11
blesi660r
blesi660r's Avatar
Re: valve spring Q
Thanks for the input guys!!! for 200 bones I think I will take the high road and pick up a set of BC springs and titanium retainers and run stock valves.
Old 07-15-2013   #12
blesi660r
blesi660r's Avatar
Re: valve spring Q
Also I have no clue on milage of the head, had stockers in it when i got it , so far the head is getting decked and cleaned, and will have all new seals around, only thing im not doing is guides "well not yet at least"
Old 07-15-2013   #13
Re: valve spring Q
FP has their beehives on sale right now.
Old 07-15-2013   #14
blesi660r
blesi660r's Avatar
Re: valve spring Q
Besides map who do you guys go through... where are the fp ones on sale?.
Old 07-15-2013   #15
Re: valve spring Q
Hit up Jason at DB. They can usually get really good deals on stuff too, plus closer to you being north.
Old 07-15-2013   #16
blesi660r
blesi660r's Avatar
Re: valve spring Q
Will do thank you.
Old 07-15-2013   #17
Re: valve spring Q
I only read your goals and cam size.
I'd say 100% evo valve stuff and that will have you covered for good amount of RPM and even cam. It's what I'm going to be getting here shortly.
Old 07-15-2013   #18
blesi660r
blesi660r's Avatar
Re: valve spring Q
Im going to do some searching in dsmtuners on both the evo springs and BC.
Old 07-15-2013   #19
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Re: valve spring Q
You can get evo springs for dirt and you'll be fine.
Old 07-15-2013   #20
blesi660r
blesi660r's Avatar
Re: valve spring Q
I was doing some reading up on the evo springs , and I think im going to go bc with titanium retainers
