Old 09-17-2013   #1
s1ngletracker
s1ngletracker's Avatar
Drives: A BMW
Does anyone have the cobra front caliper kit?
For a 1g dsm. If so, can I take measurements of the adapter bracket?
I could compensate you for the service.
LMK!
Style's automotive engineer
Old 09-18-2013   #2
Re: Does anyone have the cobra front caliper kit?
I had the kit, and I traced them onto a piece of paper and took a bunch of measurements. I can look around when I get home and send you it if I can find it.
Old 09-18-2013   #3
s1ngletracker
Drives: A BMW
Awesome, thanks!
Old 09-18-2013   #4
I scanned it and attached it. Only problem is proportions staying the same. To check, I printed it and held it up to the light against the original, and for some reason it was stretched longer just a hair (maybe an 1/8th if I were to guess). Width wise it's fine. But length wise, is stretched just a hair. I dunno what I'm doing wrong.
Shoot me a PM if you have any ideas, or maybe this is close enough to get you there.
Old 09-19-2013   #5
s1ngletracker
Drives: A BMW
I don't need it to be to scale, since you provided dims.
This is awesome, Brandon. Thanks a million for doing this.
Another question - know what thickness material they used?
I might have a bunch of these made on a CNC. If anyone is interested, LMK.
Old 09-19-2013   #6
I can't remember the thickness, but they were beefy. Does 1/2" sound about right maybe? Just straight carbon steel. You could ask Blageo if he still has any of that info because I think they were considering making some at one point to several years ago.
Old 09-19-2013   #7
Also, not sure if you saw this thread but it may be useful to you.
http://mitsustyle.com/forums/showthr...ighlight=cobra
Only thing wrong is I think I ended up switching the calipers around. I initially installed them so the bleeders were on the bottom. Then later realized I did it backwards, bleeders should be on top (where the air would be).
Old 09-19-2013   #8
I might be interested, I need to upgrade to something bigger than 2G brakes over the winter.
Old 09-19-2013   #9
s1ngletracker
Drives: A BMW
NVM - thanks for the link to your install thread. Got the info I need.
Also I confirmed that *the other guy* uses 1/2" steel for the brackets. Gonna draw up a model and send it to my CNC guy today.
Old 09-19-2013   #10
Those are the bolts and lengths I used. I'm not an ME so you may want to use different lengths. RTM didn't sell a kit with bolts and lines when I did this, so I actually helped them pick out the bolt sizes and brake lines, and helped them put together the complete kit they sell now a days (look at their pics, notice how their lines look strangely identical to my ebay ones ). I think we ended up choosing slightly longer bolts (35 and 45) for their kit, but I can't remember. Minor stuff but hopefully that info helps get you 95% of the way there. I forget the site, but if you dug hard enough you could find our conversations on some Canadian DSM site.
Old 09-19-2013   #11
s1ngletracker
Drives: A BMW
look about right?
Old 09-19-2013   #12
Got a 3D printer? Might be worth making one out of plastic or whatever for testing fitup before running a batch made from steel.
Old 09-19-2013   #13
s1ngletracker
Drives: A BMW
Do you know the size of the spacers? Just realized I need those, might integrate into the bracket.
Old 09-19-2013   #14
s1ngletracker
Drives: A BMW
Might see if I can use one...
Old 09-19-2013   #15
the spacers for the calipers? I don't know, but before they made those people just stacked washers. Also you'll need that hub-centric ring.
Old 09-19-2013   #16
s1ngletracker
Drives: A BMW
Yeah, i'll probably figure out what thickness I need and incorporate that into the final design.
Old 09-19-2013   #17
Lol, found it. Might be some more useful info in there for ya.
http://www.ca.dsm.org/forums/ubbthre...=304116&page=1
Old 09-19-2013   #18
s1ngletracker
Drives: A BMW
oooh, i might redesign them so they dont' rotate the caliper. I think it looks a tad bit funny.
Old 09-19-2013   #19
So like these?
http://i214.photobucket.com/albums/c...ale/brake1.jpg
Old 09-19-2013   #20
s1ngletracker
Drives: A BMW
yes, absolutely. Maybe without the threaded holes.
Also going to try to make them out of aluminum, weight savings and easier to machine.
