Old 09-01-2013   #521
Re: Mark's 1G Winter Projects
Nice work man! 8s are coming soon!!!!
On a side note i commented on someone's pic of a BIR announcer asking if it was the guy that can't say mitsubishi.
so 8s at PG?
Old 09-01-2013   #522
That announcer should be kicked in the nuts. He's a fuckin moron.
Great pass though man, so close to 8's!
Old 09-01-2013   #523
4seasons69
4seasons69's Avatar
Nice pass! I bet the announcer felt like a jackass after he saw what you ran lol
Old 09-02-2013   #524
dsmreck
dsmreck's Avatar
Drives: 98 gsx
killer video would love to see that in slow mo
Old 09-23-2013   #525
blackrosenova400
blackrosenova400's Avatar
How do you like that kiggly crank trigger setup? I notice when im logging my engine speed is somewhat erratic. I take it the kiggly setup fixes that?
20g Mafia
Old 09-23-2013   #526
Mark Leasure
Mark Leasure's Avatar
You need an EMS to use it. The ignition timing is dead on, that's the biggest effect. Also starting time is greatly improved. I don't know on the engine speed variation.
www.maperformance.com
Old 11-03-2013   #527
Mark Leasure
I'm going to do some stuff this winter to the Talon. I had a good time this year minus cutting some of my finger off. 9.5 racing FTW. I'm in the process of figuring out the scope of the winter project this year. Front tubular K-member is on the list, who knows! Here is the biggest upgrade, no more horse cock shifter....
And the new:
Old 11-03-2013   #528
You are joking right?
You didn't really use the stock one all this time?
Old 11-05-2013   #529
Mark Leasure
No joke the stock one is the joint I've been using up to now! I'm so use to the EVO shift knob now it just makes sense to switch...
Old 11-05-2013   #530
Is that a delrin one off ebay, looks similar to the one i recently got
Old 11-07-2013   #531
Mark Leasure
That's the one! It should make for some easier shifting!
Old 11-07-2013   #532
carltalon
carltalon's Avatar
Drives: 98 Eclipse GSX Auto
That's a 1/2 second mod right there. The stock 1g knob makes it like a truck shifter.
11.35 @ 120mph
Old 11-07-2013   #533
Next is the air shifter.....
Old 11-24-2013   #534
Mark Leasure
Now that the season has been over for a while I’m looking at what I can improve over the winter. I’m going to focus on more weight reduction and driver assistance modifications.
I’m sticking with the dog box, my only real issue at this point is to get the car off of the line consistently. I need to be able to focus on the tree instead of a million things in the car. So I’m going to give a shot at a launch control solenoid on the clutch. I built one and have it installed now, I’m trying to figure out a way to have it fully automated/controlled by the EMS series 2. I’m also going to add a hydraulic e-brake for staging, circuited in just like the CNC ONE, so left front / right rear or something like that.
I purchased a rear brake kit, TCE’s drag rear kit and I added brakeman revolution light weight rotors. Thanks again Drew at MAP for hooking me up on the rotors!
I’m going to down size to 15” rims with wider and stickier MT slicks they are from Vassil’s setup. I plan on keeping the QTP's for my EVO.
I’m looking at acquiring or fabricating a Tubular K-member too.
I'll update this thread as I go.
Old 11-25-2013   #535
Mark Leasure
The rear brakes shaved off 19.5 pounds! The majority of the savings came from the calipers. They look sick too.
Old 11-25-2013   #536
mondale
Drives: 1g dsm
20 lbs off is awesome! Do you know if those rear calipers have dust boots on the pistons? I would like to get a kit for the rear, but am leery of using a kit that doesn't have dust boots for the street driving the car sees. I also need to ask what has become of your old rear rotors that had work done to them pm me!
8.59 @ 158
mondale is offline   Reply With Quote
Old 11-25-2013   #537
They recommend a normal rotor for street driving too....
Old 11-25-2013   #538
Mark Leasure
I don't think they have dust boots, not sure? At least they are cheap aprox 100.
Old 11-25-2013   #539
Mark Leasure
Recommendations are just that! I wouldn't have any issues running them on the street for the rear, fronts are another story.
Old 11-25-2013   #540
Mark Leasure
I took this snapshot at the BIR track scale last time I was there. This is my starting point for weight, without me in the car. I don't remember if I had the door panels installed or not. I know this is with carpet too!
