Old 02-09-2014   #41
dsmreck
dsmreck's Avatar
Drives: 98 gsx
Re: team ab drag race and street builds
never considered ron before to be honest. may be worth a call. Yes we did the powder coating ourselves. tools for trans rebuild? I would absolutely consider doing my own rebuild if I had more knowledge of it or at least more write ups or vids to do the research.
Old 02-09-2014   #42
wow those coated parts look awesome
Old 02-10-2014   #43
The trans is pretty easy as long as you have a press and a nice "seperator plate" thing. Also, you'll need a few specialty tools like a 36mm socket. I believe the interwebs has a detailed trans guide somewhere.
Old 02-10-2014   #44
Rick Shindley from Big Lake can rebuild your DSM tranny. Oh, wait this isn't 2004.
Old 02-10-2014   #45
jeremy1375
jeremy1375's Avatar
If you're considering rebuilding your trans, here are the resources I found useful.
Service Manual: http://www.dsmtuners.com/forums/freq...e-manuals.html
TMZ preload specs: http://www.galantvr4.org/ubbthreads/...25&Main=862594
Jack's bronze synchro rings: http://www.jackstransmissions.com/pages/mits-parts
Old 02-10-2014   #46
dsmreck
dsmreck's Avatar
Drives: 98 gsx
^ yup old news to me, but thanks. I'm saying until I know I could trust myself i'm not chancing my first rebuild on a car with as much power as i'll be throwing at it. I'd rather spend the money to have a pro do this for now and be money ahead. If a reputable person was willing to let me sit in on a session hell yeah i'd be into that for sure. I have 3 motors to build and install into cars not to mention tuning etc. I just don't think I have enough information for the way my brain works to have serious thoughts of doing it myself yet. I do appreciate the comments and effort from all so far.
Old 02-10-2014   #47
dsmghost
dsmghost's Avatar
Drives: 1gb Talon TSi AWD
If you can spec out and assemble a motor you'll find the trans is cake. Just crack one open and disassemble it you will find it's very simple.
Old 02-10-2014   #48
dsmreck
dsmreck's Avatar
Drives: 98 gsx
I've always been under the impression the trans is much more difficult to master or more people would be doing it. That's why I assumed most people with wild builds use a reputable trans shop
Old 02-10-2014   #49
jeremy1375
jeremy1375's Avatar
I always thought it was a big deal because it requires a press. I bought the one in the pic for around $170 with coupon at Harbor Freight. It worked great.
Old 02-10-2014   #50
dsmreck
dsmreck's Avatar
Drives: 98 gsx
Edit no worries here we will see how funding goes. Project list is long at this point. Trans, clutch, injectors, boston hatcher, wheels tires, maybe turbo upgrade. Kiggly crank sensor, 3 inch intercooler piping for cold side, q45 tb, timing belt, etc etc
Old 02-10-2014   #51
dsmreck
dsmreck's Avatar
Drives: 98 gsx
Can't get much better powder coat yesterday, New cams today. I can't wait to try these s3 out
ID:	14210   Click image for larger version
ID:	14211   Click image for larger version
Old 02-11-2014   #52
Damn, that's a lot of cam lift on a DSM.
Old 02-16-2014   #53
dsmreck
dsmreck's Avatar
Drives: 98 gsx
^ gonna be sick high lift, high compression, and boost.
Didn't really take any pics, but it was a crazy weekend for me. I specked out andre and jessie's short blocks out, ended up being three blocks in total. Jessie needs and 6 bolt crank, and a rod. andre needs a seven bolt crank, and a rod. The other 6 bolt is good to go for a refresh and kingly main girdle. Also if anyone has info on how to shave the rods to create more side clearance on the crank I wouldn't mind hearing opinions
Old 02-22-2014   #54
dsmreck
dsmreck's Avatar
Drives: 98 gsx
and some more powder coating, you know just incase they don't move they will still look pretty
ID:	14226   Click image for larger version
ID:	14227   Click image for larger version
ID:	14229   Click image for larger version
Old 02-22-2014   #55
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
Looks great where are you doing this powdercoating at?
2006 WW IX RS 396/404 - SOLD
Old 02-22-2014   #56
dsmreck
dsmreck's Avatar
Drives: 98 gsx
in the garage
Old 03-02-2014   #57
dsmreck
dsmreck's Avatar
Drives: 98 gsx
ok i have my trans torn down. I can tell the gear on the fort shaft that connects to the forward gear is toasted as parts or the gear are missing, so that is $185 from jacks. What I don't know is how to inspect the syncros, hubs, forks.. The rest of the gears are all pretty good looking. I was grinding 2nd and 3rd like it was religion on sunday so I know there is a problem
Old 03-02-2014   #58
Synchros should have a sharp point on them. If they are rounded over then you should change them.
Old 03-02-2014   #59
dsmghost
dsmghost's Avatar
Replace all synchros while in there, they are cheap. Double synchros are a little more I think $67. Also inspect both hub/sliders for wear but I would just replace them too.
Old 03-02-2014   #60
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
Originally Posted by dsmreck View Post
in the garage
Sorry I'm just interested in the process, I'd love to learn how to do it
